Help Needed with arm/lm4f120 tcfg Check
Joel Sherrill
joel at rtems.org
Wed Mar 13 12:17:31 UTC 2019
On Wed, Mar 13, 2019, 2:12 AM Sebastian Huber <
> On 12/03/2019 17:24, Joel Sherrill wrote:
> > I have a puzzling issue after updating the lm4f120 tcfg file. I added
> > cxx_iostream but it still tries to build it and fails.
> > Can anyone spot why this one exclude is not working?
> You have to use the name of the Automake condition which is
> TEST_iostream, so the name is "iostream"
Thanks.
This is the only test I have seen where the automake condition doesn't
match the exe name minus the extension. Should we change it?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190313/62c29541/attachment.html>
