[PATCH] Add rtems_board_support_package()
Wed Mar 13 13:41:48 UTC 2019
On 13/03/2019 14:39, Joel Sherrill wrote:
> On Wed, Mar 13, 2019 at 2:38 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     What about this patch? The placement of rtems_board_support_package()
>     into <rtems/version.h> is a bit odd, but I think it fits into the
>     scope
>     of these functions. You normally include <rtems/version.h> if you
>     want
>     to print some system information. Another place would be <rtems.h>
>     right
>     after rtems_get_version_string().
> I think it is OK although I agree with you it is odd.
> If these are intended to be public APIs, I do not see any
> documentation for
> them in rtems-docs.
All functions in this header are not in rtems-docs so far. I guess the
primary use case is test meta-data output.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
