[PATCH 1/1] eng: Add software test framework chapter
Thu Mar 14 10:23:27 UTC 2019
Update #3199.
 eng/index.rst          |    3 +
 eng/test-framework.rst | 2077 ++++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 2080 insertions(+)
 create mode 100644 eng/test-framework.rst
diff --git a/eng/index.rst b/eng/index.rst
index fe51e91..f29d0f3 100644
--- a/eng/index.rst
+++ b/eng/index.rst
@@ -11,6 +11,8 @@ RTEMS Software Engineering (|version|)
 .. topic:: Copyrights and License
+    | |copy| 2018, 2019 embedded brains GmbH
+    | |copy| 2018, 2019 Sebastian Huber
     | |copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
     .. include:: ../common/license.rst
@@ -26,6 +28,7 @@ RTEMS Software Engineering (|version|)
     stakeholders
     management
     test-plan
+    test-framework
     release-mgmt
     users-manuals
     license-requirements
diff --git a/eng/test-framework.rst b/eng/test-framework.rst
new file mode 100644
index 0000000..dda13bc
--- /dev/null
+++ b/eng/test-framework.rst
@@ -0,0 +1,2077 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2018, 2019 embedded brains GmbH
+.. Copyright (C) 2018, 2019 Sebastian Huber
+Software Test Framework
+.. _TheTTestFramework:
+The T Test Framework
+The `T Test Framework` helps to write test suites.  A `test suite` is a
+collection of test cases.  A `test case` consists of individual test actions
+and checks.  A `test check` determines if the outcome of a test action meets
+its expectation.  A `test action` is a program sequence with an observable
+outcome, for example a function invocation with a return status.  If the test
+action outcome is all right, then the test check passes, otherwise the test
+check fails.  The test check failures of a test case are summed up.  A test
+case passes, if the failure count of this test case is zero, otherwise the test
+case fails.  The test suite passes if all test cases pass, otherwise it fails.
+Test Cases
+You can write a test case with the `T_TEST_CASE()` macro followed by a function
+body:
+.. code-block:: c
+   T_TEST_CASE(name)
+      /* Your test case code */
+The test case `name` must be a valid C designator.  The test case names must be
+unique within the test suite.  Just link modules with test cases to the test
+runner to form a test suite.  The test cases are automatically registered via
+static constructors.
+.. code-block:: c
+    :caption: Test Case Example
+    #include <t.h>
+    static int add(int a, int b)
+        return a + b;
+    T_TEST_CASE(a_test_case)
+        int actual_value;
+        actual_value = add(1, 1);
+        T_eq_int(actual_value, 2);
+        T_true(false, "a test failure message");
+.. code-block:: none
+    :caption: Test Case Report
+    B:a_test_case
+    P:0:8:UI1:test-simple.c:13
+    F:1:8:UI1:test-simple.c:14:a test failure message
+    E:a_test_case:N:2:F:1:D:0.001657
+The `B` line indicates the begin of test case `a_test_case`.  The `P` line
+shows that the test check in file `test-simple.c` at line 13 executed by task
+`UI1` on processor 0 as the test step 0 passed.  The invocation of `add()` in
+line 12 is the test action of test step 0.  The `F` lines shows that the test
+check in file `test-simple.c` at line 14 executed by task `UI1` on processor 0
+as the test step 1 failed with a message of `"a test failure message"`.  The
+`E` line indicates the end of test case `a_test_case` resulting in a total of
+two test steps (`N`) and one test failure (`F`).  The test case execution
+duration (`D`) was 0.001657 seconds.  For test report details see:
+:ref:`Test Reporting <TheTTestFrameworkTestReporting>`.
+Test Fixture
+You can write a test case with a test fixture with the `T_TEST_CASE_FIXTURE()`
+macro followed by a function body:
+.. code-block:: c
+   T_TEST_CASE_FIXTURE(name, fixture)
+unique within the test suite.  The `fixture` must point to a statically
+initialized read-only object of type `T_fixture`.  The test fixture
+provides methods to setup, stop and tear down a test case.  A context is passed
+to the methods.  The initial context is defined by the read-only fixture
+object.  The context can be obtained by the `T_fixture_context()`
+function.  It can be set within the scope of one test case by the
+`T_set_fixture_context()` function.  This can be used for example to
+dynamically allocate a test environment in the setup method.
+.. code-block:: c
+    :caption: Test Fixture Example
+    #include <t.h>
+    static int initial_value = 3;
+    static int counter;
+    static void
+    setup(void *ctx)
+        int *c;
+        T_log(T_QUIET, "setup begin");
+        T_eq_ptr(ctx, &initial_value);
+        T_eq_ptr(ctx, T_fixture_context());
+        c = ctx;
+        counter = *c;
+        T_set_fixture_context(&counter);
+        T_eq_ptr(&counter, T_fixture_context());
+        T_log(T_QUIET, "setup end");
+    static void
+    stop(void *ctx)
+        int *c;
+        T_log(T_QUIET, "stop begin");
+        T_eq_ptr(ctx, &counter);
+        c = ctx;
+        ++(*c);
+        T_log(T_QUIET, "stop end");
+    static void
+    teardown(void *ctx)
+        int *c;
+        T_log(T_QUIET, "teardown begin");
+        c = ctx;
+        T_eq_int(*c, 4);
+        T_log(T_QUIET, "teardown end");
+    static const T_fixture fixture = {
+        .setup = setup,
+        .stop = stop,
+        .teardown = teardown,
+        .initial_context = &initial_value
+    T_TEST_CASE_FIXTURE(fixture, &fixture)
+        T_assert_true(true, "all right");
+        T_assert_true(false, "test fails and we stop the test case");
+        T_log(T_QUIET, "not reached");
+    :caption: Test Fixture Report
+    B:fixture
+    L:setup begin
+    P:0:0:UI1:test-fixture.c:13
+    P:1:0:UI1:test-fixture.c:14
+    P:2:0:UI1:test-fixture.c:18
+    L:setup end
+    P:3:0:UI1:test-fixture.c:55
+    F:4:0:UI1:test-fixture.c:56:test fails and we stop the test case
+    L:stop begin
+    P:5:0:UI1:test-fixture.c:28
+    L:stop end
+    L:teardown begin
+    P:6:0:UI1:test-fixture.c:40
+    P:7:0:UI1:test-fixture.c:42
+    L:teardown end
+    E:fixture:N:8:F:1
+Test Case Planning
+Each non-quiet test check fetches and increments the test step counter
+atomically.  For each test case execution the planned steps can be specified
+with the `T_plan()` function.
+.. code-block:: c
+    void T_plan(unsigned int planned_steps);
+This function must be invoked at most once in each test case execution.  If the
+planned test steps are set with this function, then the final test steps after
+the test case execution must be equal to the planned steps, otherwise the test
+case fails.
+Use the `T_step_*(step, ...)` test check variants to ensure that the test case
+execution follows exactly the planned steps.
+.. code-block:: c
+    :caption: Test Planning Example
+    #include <t.h>
+    T_TEST_CASE(wrong_step)
+        T_plan(2);
+        T_step_true(0, true, "all right");
+        T_step_true(2, true, "wrong step");
+    T_TEST_CASE(plan_ok)
+        T_plan(1);
+    T_TEST_CASE(plan_failed)
+        T_plan(2);
+        T_step_true(0, true, "not enough steps");
+        T_quiet_true(true, "quiet test do not count");
+    T_TEST_CASE(double_plan)
+        T_plan(99);
+        T_plan(2);
+    T_TEST_CASE(steps)
+        T_step(0, "a");
+        T_plan(3);
+        T_step(1, "b");
+        T_step(2, "c");
+    :caption: Test Planning Report
+    B:wrong_step
+    P:0:0:UI1:test-plan.c:6
+    F:1:0:UI1:test-plan.c:7:planned step (2)
+    E:wrong_step:N:2:F:1
+    B:plan_ok
+    P:0:0:UI1:test-plan.c:13
+    E:plan_ok:N:1:F:0
+    B:plan_failed
+    P:0:0:UI1:test-plan.c:19
+    F:*:0:UI1:*:*:actual steps (1), planned steps (2)
+    E:plan_failed:N:1:F:1
+    B:double_plan
+    F:*:0:UI1:*:*:planned steps (99) already set
+    E:double_plan:N:0:F:1
+    B:steps
+    P:0:0:UI1:test-plan.c:31
+    P:1:0:UI1:test-plan.c:33
+    P:2:0:UI1:test-plan.c:34
+    E:steps:N:3:F:0
+Test Case Resource Accounting
+The framework can check if various resources are leaked during a test case
+execution.  The resource checkers are specified by the test run configuration.
+On RTEMS, checks for the following resources are available
+* workspace and heap memory,
+* file descriptors,
+* POSIX keys and key value pairs,
+* RTEMS barriers,
+* RTEMS user extensions,
+* RTEMS message queues,
+* RTEMS partitions,
+* RTEMS periods,
+* RTEMS regions,
+* RTEMS semaphores,
+* RTEMS tasks, and
+* RTEMS timers.
+.. code-block:: c
+    :caption: Resource Accounting Example
+    #include <t.h>
+    #include <stdlib.h>
+    #include <rtems.h>
+    T_TEST_CASE(missing_sema_delete)
+        rtems_status_code sc;
+        rtems_id id;
+        sc = rtems_semaphore_create(rtems_build_name('S', 'E', 'M', 'A'), 0,
+            RTEMS_COUNTING_SEMAPHORE, 0, &id);
+        T_rsc_success(sc);
+    T_TEST_CASE(missing_free)
+        void *p;
+        p = malloc(1);
+        T_not_null(p);
+    :caption: Resource Accounting Report
+    B:missing_sema_delete
+    P:0:0:UI1:test-leak.c:14
+    F:*:0:UI1:*:*:RTEMS semaphore leak (1)
+    E:missing_sema_delete:N:1:F:1:D:0.004013
+    B:missing_free
+    P:0:0:UI1:test-leak.c:22
+    F:*:0:UI1:*:*:memory leak in workspace or heap
+    E:missing_free:N:1:F:1:D:0.003944
+Test Case Scoped Resources
+You can allocate resources which are automatically destroyed after the test
+case execution.
+.. code-block:: c
+   void *T_malloc(size_t size);
+   void *T_calloc(size_t nelem, size_t elsize);
+   void *T_zalloc(size_t size);
+   void T_free(void *ptr);
+.. code-block:: c
+    :caption: Test Case Scoped Resource Example
+    #include <t.h>
+    T_TEST_CASE(malloc_free)
+        void *p;
+        p = T_malloc(1);
+        T_assert_not_null(p);
+        T_free(p);
+    T_TEST_CASE(malloc_auto)
+        void *p;
+        p = T_malloc(1);
+    :caption: Test Case Scoped Resource Report
+    B:malloc_free
+    P:0:0:UI1:test-malloc.c:8
+    E:malloc_free:N:1:F:0
+    B:malloc_auto
+    P:0:0:UI1:test-malloc.c:17
+    E:malloc_auto:N:1:F:0
+Test Case Destructors
+You can add test case destructors with `T_add_destructor()`.  They are called
+automatically at the test case end before the resource accounting takes place.
+Optionally, a registered destructor can be removed before the test case end
+with `T_remove_destructor()`.  The `T_destructor` structure of a destructor
+must exist after the return from the test case body.  Do not use stack memory
+or dynamic memory obtained via `T_malloc()`, `T_calloc()` or `T_zalloc()` for
+the `T_destructor` structure.
+.. code-block:: c
+    void T_add_destructor(T_destructor *destructor,
+       void (*destroy)(T_destructor *));
+    void T_remove_destructor(T_destructor *destructor);
+.. code-block:: c
+    :caption: Test Case Destructor Example
+    #include <t.h>
+    static void
+    destroy(T_destructor *dtor)
+        (void)dtor;
+        T_step(0, "destroy");
+    T_TEST_CASE(destructor)
+        static T_destructor dtor;
+        T_plan(1);
+        T_add_destructor(&dtor, destroy);
+    :caption: Test Case Destructor Report
+    B:destructor
+    P:0:0:UI1:test-destructor.c:7
+    E:destructor:N:1:F:0:D:0.003714
+Test Checks
+A `test check` determines if the actual value presented to the test check meets
+its expectation.  The actual value should represent the outcome of a test
+action.  If the actual value is all right, then the test check passes,
+otherwise the test check fails.  A failed test check does not stop the test
+case execution immediately unless the `T_assert_*()` test variant is used.
+Each test check increments the test step counter unless the `T_quiet_*()` test
+variant is used.  The test step counter is initialized to zero before the test
+case begins to execute.  The `T_step_*(step, ...)` test check variants verify
+that the test step counter is equal to the planned test step value, otherwise
+the test check fails.
+Test Check Parameter Conventions
+The following names for test check parameters are used throughout the test
+checks:
+step
+    The planned test step for this test check.
+a
+    The actual value to check against an expected value.  It is usually the
+    first parameter in all test checks, except in the `T_step_*(step, ...)`
+    test check variants, here it is the second parameter.
+e
+    The expected value of a test check.  This parameter is optional.  Some test
+    checks have an implicit expected value.  If present, then this parameter is
+    directly after the actual value parameter of the test check.
+fmt
+    A printf()-like format string.  Floating-point and exotic formats may be
+    not supported.
+Test Check Condition Conventions
+The following names for test check conditions are used:
+eq
+    The actual value must equal the expected value.
+ne
+    The actual value must not equal the value of the second parameter.
+ge
+    The actual value must be greater than or equal to the expected value.
+gt
+    The actual value must be greater than the expected value.
+le
+    The actual value must be less than or equal to the expected value.
+lt
+    The actual value must be less than the expected value.
+If the actual value satisfies the test check condition, then the test check
+passes, otherwise it fails.
+Test Check Variant Conventions
+The `T_assert_*()` test check variants stop the current test case execution if
+the test fails.
+The `T_quiet_*()` test check variants do not increment the test step counter
+and only print a message if the test check fails.  This is helpful in case a
+test check appears in a tight loop.
+The `T_step_*(step, ...)` test check variants check that the test step counter
+is equal to the specified test step value, otherwise the test check fails.
+The following names for test check type variants are used:
+ptr
+    The test value must be a pointer (`void *`).
+mem
+    The test value must be a memory area with a specified length.
+str
+    The test value must be a null byte terminated string.
+nstr
+    The length of the test value string is limited to a specified maximum.
+char
+    The test value must be a character (`char`).
+schar
+    The test value must be a signed character (`signed char`).
+uchar
+    The test value must be an unsigned character (`unsigned char`).
+short
+    The test value must be a short integer (`short`).
+ushort
+    The test value must be an unsigned short integer (`unsigned short`).
+int
+    The test value must be an integer (`int`).
+uint
+    The test value must be an unsigned integer (`unsigned int`).
+long
+    The test value must be a long integer (`long`).
+ulong
+    The test value must be an unsigned long integer (`unsigned long`).
+ll
+    The test value must be a long long integer (`long long`).
+ull
+    The test value must be an unsigned long long integer (`unsigned long long`).
+i8
+    The test value must be a signed 8-bit integer (`int8_t`).
+u8
+    The test value must be an unsigned 8-bit integer (`uint8_t`).
+i16
+    The test value must be a signed 16-bit integer (`int16_t`).
+u16
+    The test value must be an unsigned 16-bit integer (`uint16_t`).
+i32
+    The test value must be a signed 32-bit integer (`int32_t`).
+u32
+    The test value must be an unsigned 32-bit integer (`uint32_t`).
+i64
+    The test value must be a signed 64-bit integer (`int64_t`).
+u64
+    The test value must be an unsigned 64-bit integer (`uint64_t`).
+iptr
+    The test value must be of type `intptr_t`.
+uptr
+    The test value must be of type `uintptr_t`.
+ssz
+    The test value must be of type `ssize_t`.
+sz
+    The test value must be of type `size_t`.
+Boolean Expressions
+The following test checks for boolean expressions are available:
+.. code-block:: c
+    void T_true(bool a, const char *fmt, ...);
+    void T_assert_true(bool a, const char *fmt, ...);
+    void T_quiet_true(bool a, const char *fmt, ...);
+    void T_step_true(unsigned int step, bool a, const char *fmt, ...);
+    void T_false(bool a, const char *fmt, ...);
+    void T_assert_false(bool a, const char *fmt, ...);
+The message is only printed in case the test check fails.  The format parameter
+is mandatory.
+.. code-block:: c
+    :caption: Boolean Test Checks Example
+    #include <t.h>
+    T_TEST_CASE(example)
+        T_true(true, "test passes, no message output");
+        T_true(false, "test fails");
+        T_quiet_true(true, "quiet test passes, no output at all");
+        T_quiet_true(false, "quiet test fails");
+        T_step_true(2, true, "step test passes, no message output");
+        T_step_true(3, false, "step test fails");
+        T_assert_false(true, "this is a format %s", "string");
+    :caption: Boolean Test Checks Report
+    B:example
+    P:0:0:UI1:test-example.c:5
+    F:1:0:UI1:test-example.c:6:test fails
+    F:*:0:UI1:test-example.c:8:quiet test fails
+    P:2:0:UI1:test-example.c:9
+    F:3:0:UI1:test-example.c:10:step test fails
+    F:4:0:UI1:test-example.c:11:this is a format string
+    E:example:N:5:F:4
+Generic Types
+The following test checks for data types with an equality (`==`) or inequality
+(`!=`) operator are available:
+.. code-block:: c
+    void T_eq(T a, T e, const char *fmt, ...);
+    void T_assert_eq(T a, T e, const char *fmt, ...);
+    void T_quiet_eq(T a, T e, const char *fmt, ...);
+    void T_step_eq(unsigned int step, T a, T e, const char *fmt, ...);
+    void T_ne(T a, T e, const char *fmt, ...);
+    void T_assert_ne(T a, T e, const char *fmt, ...);
+    void T_quiet_ne(T a, T e, const char *fmt, ...);
+    void T_step_ne(unsigned int step, T a, T e, const char *fmt, ...);
+The type name `T` specifies an arbitrary type which must support the
+corresponding operator.  The message is only printed in case the test check
+fails.  The format parameter is mandatory.
+Pointers
+The following test checks for pointers are available:
+.. code-block:: c
+    void T_eq_ptr(const void *a, const void *e);
+    void T_assert_eq_ptr(const void *a, const void *e);
+    void T_quiet_eq_ptr(const void *a, const void *e);
+    void T_step_eq_ptr(unsigned int step, const void *a, const void *e);
+    void T_ne_ptr(const void *a, const void *e);
+    void T_assert_ne_ptr(const void *a, const void *e);
+    void T_quiet_ne_ptr(const void *a, const void *e);
+    void T_step_ne_ptr(unsigned int step, const void *a, const void *e);
+    void T_null(const void *a);
+    void T_assert_null(const void *a);
+    void T_quiet_null(const void *a);
+    void T_step_null(unsigned int step, const void *a);
+    void T_not_null(const void *a);
+    void T_assert_not_null(const void *a);
+    void T_quiet_not_null(const void *a);
+    void T_step_not_null(unsigned int step, const void *a);
+An automatically generated message is printed in case the test check fails.
+Memory Areas
+The following test checks for memory areas are available:
+.. code-block:: c
+    void T_eq_mem(const void *a, const void *e, size_t n);
+    void T_assert_eq_mem(const void *a, const void *e, size_t n);
+    void T_quiet_eq_mem(const void *a, const void *e, size_t n);
+    void T_step_eq_mem(unsigned int step, const void *a, const void *e, size_t n);
+    void T_ne_mem(const void *a, const void *e, size_t n);
+    void T_assert_ne_mem(const void *a, const void *e, size_t n);
+    void T_quiet_ne_mem(const void *a, const void *e, size_t n);
+    void T_step_ne_mem(unsigned int step, const void *a, const void *e, size_t n);
+The `memcmp()` function is used to compare the memory areas.  An automatically
+generated message is printed in case the test check fails.
+Strings
+The following test checks for strings are available:
+.. code-block:: c
+    void T_eq_str(const char *a, const char *e);
+    void T_assert_eq_str(const char *a, const char *e);
+    void T_quiet_eq_str(const char *a, const char *e);
+    void T_step_eq_str(unsigned int step, const char *a, const char *e);
+    void T_ne_str(const char *a, const char *e);
+    void T_assert_ne_str(const char *a, const char *e);
+    void T_quiet_ne_str(const char *a, const char *e);
+    void T_step_ne_str(unsigned int step, const char *a, const char *e);
+    void T_eq_nstr(const char *a, const char *e, size_t n);
+    void T_assert_eq_nstr(const char *a, const char *e, size_t n);
+    void T_quiet_eq_nstr(const char *a, const char *e, size_t n);
+    void T_step_eq_nstr(unsigned int step, const char *a, const char *e, size_t n);
+    void T_ne_nstr(const char *a, const char *e, size_t n);
+    void T_assert_ne_nstr(const char *a, const char *e, size_t n);
+    void T_quiet_ne_nstr(const char *a, const char *e, size_t n);
+    void T_step_ne_nstr(unsigned int step, const char *a, const char *e, size_t n);
+The `strcmp()` and `strncmp()` functions are used to compare the strings.  An
+automatically generated message is printed in case the test check fails.
+Characters
+The following test checks for characters (`char`) are available:
+.. code-block:: c
+    void T_eq_char(char a, char e);
+    void T_assert_eq_char(char a, char e);
+    void T_quiet_eq_char(char a, char e);
+    void T_step_eq_char(unsigned int step, char a, char e);
+    void T_ne_char(char a, char e);
+    void T_assert_ne_char(char a, char e);
+    void T_quiet_ne_char(char a, char e);
+    void T_step_ne_char(unsigned int step, char a, char e);
+Integers
+The following test checks for integers are available:
+.. code-block:: c
+    void T_eq_xyz(I a, I e);
+    void T_assert_eq_xyz(I a, I e);
+    void T_quiet_eq_xyz(I a, I e);
+    void T_step_eq_xyz(unsigned int step, I a, I e);
+    void T_ne_xyz(I a, I e);
+    void T_assert_ne_xyz(I a, I e);
+    void T_quiet_ne_xyz(I a, I e);
+    void T_step_ne_xyz(unsigned int step, I a, I e);
+    void T_ge_xyz(I a, I e);
+    void T_assert_ge_xyz(I a, I e);
+    void T_quiet_ge_xyz(I a, I e);
+    void T_step_ge_xyz(unsigned int step, I a, I e);
+    void T_gt_xyz(I a, I e);
+    void T_assert_gt_xyz(I a, I e);
+    void T_quiet_gt_xyz(I a, I e);
+    void T_step_gt_xyz(unsigned int step, I a, I e);
+    void T_le_xyz(I a, I e);
+    void T_assert_le_xyz(I a, I e);
+    void T_quiet_le_xyz(I a, I e);
+    void T_step_le_xyz(unsigned int step, I a, I e);
+    void T_lt_xyz(I a, I e);
+    void T_assert_lt_xyz(I a, I e);
+    void T_quiet_lt_xyz(I a, I e);
+    void T_step_lt_xyz(unsigned int step, I a, I e);
+The type variant `xyz` must be `schar`, `uchar`, `short`, `ushort`, `int`,
+`uint`, `long`, `ulong`, `ll`, `ull`, `i8`, `u8`, `i16`, `u16`, `i32`, `u32`,
+`i64`, `u64`, `iptr`, `uptr`, `ssz`, or `sz`.
+The type name `I` must be compatible to the type variant.
+RTEMS Status Codes
+The following test checks for RTEMS status codes are available:
+.. code-block:: c
+    void T_rsc(rtems_status_code a, rtems_status_code e);
+    void T_assert_rsc(rtems_status_code a, rtems_status_code e);
+    void T_quiet_rsc(rtems_status_code a, rtems_status_code e);
+    void T_step_rsc(unsigned int step, rtems_status_code a, rtems_status_code e);
+    void T_rsc_success(rtems_status_code a);
+    void T_assert_rsc_success(rtems_status_code a);
+    void T_quiet_rsc_success(rtems_status_code a);
+    void T_step_rsc_success(unsigned int step, rtems_status_code a);
+POSIX Error Numbers
+The following test checks for POSIX error numbers are available:
+.. code-block:: c
+    void T_eno(int a, int e);
+    void T_assert_eno(int a, int e);
+    void T_quiet_eno(int a, int e);
+    void T_step_eno(unsigned int step, int a, int e);
+    void T_eno_success(int a);
+    void T_assert_eno_success(int a);
+    void T_quiet_eno_success(int a);
+    void T_step_eno_success(unsigned int step, int a);
+The actual and expected value must be a POSIX error number, e.g. EINVAL,
+ENOMEM, etc.  An automatically generated message is printed in case the test
+check fails.
+POSIX Status Codes
+The following test checks for POSIX status codes are available:
+.. code-block:: c
+    void T_psx_error(int a, int eno);
+    void T_assert_psx_error(int a, int eno);
+    void T_quiet_psx_error(int a, int eno);
+    void T_step_psx_error(unsigned int step, int a, int eno);
+    void T_psx_success(int a);
+    void T_assert_psx_success(int a);
+    void T_quiet_psx_success(int a);
+    void T_step_psx_success(unsigned int step, int a);
+The `eno` value must be a POSIX error number, e.g. EINVAL, ENOMEM, etc.  An
+actual value of zero indicates success.  An actual value of minus one indicates
+an error.  An automatically generated message is printed in case the test check
+fails.
+.. code-block:: c
+    :caption: POSIX Status Code Example
+    #include <t.h>
+    #include <sys/stat.h>
+    #include <errno.h>
+    T_TEST_CASE(stat)
+        struct stat st;
+        int status;
+        errno = 0;
+        status = stat("foobar", &st);
+        T_psx_error(status, ENOENT);
+    :caption: POSIX Status Code Report
+    B:stat
+    P:0:0:UI1:test-psx.c:13
+    E:stat:N:1:F:0
+Custom Log Messages
+You can print custom log messages with the `T_log()` function:
+.. code-block:: c
+    void T_log(T_verbosity verbosity, char const *fmt, ...);
+A newline is automatically added to terminate the log message line.
+.. code-block:: c
+    :caption: Custom Log Message Example
+    #include <t.h>
+    T_TEST_CASE(log)
+        T_log(T_NORMAL, "a custom message %i, %i, %i", 1, 2, 3);
+        T_set_verbosity(T_QUIET);
+        T_log(T_NORMAL, "not verbose enough");
+    :caption: Custom Log Message Report
+    B:log
+    L:a custom message 1, 2, 3
+    E:log:N:0:F:0
+Time Services
+The test framework provides two unsigned integer types for time values.  The
+`T_ticks` unsigned integer type is used by the `T_tick()` function which
+measures time using the highest frequency counter available on the platform.
+It should only be used to measure small time intervals.  The `T_time` unsigned
+integer type is used by the `T_now()` function which returns the current
+monotonic clock value of the platform, e.g. `CLOCK_MONOTONIC`.
+.. code-block:: c
+   T_ticks T_tick(void);
+   T_time T_now(void);
+The reference time point for these two clocks is unspecified.  You can obtain
+the test case begin time with the `T_case_begin_time()` function.
+.. code-block:: c
+   T_time T_case_begin_time(void);
+You can convert time into ticks with the `T_time_to_ticks()` function and vice
+versa with the `T_ticks_to_time()` function.
+.. code-block:: c
+    T_time T_ticks_to_time(T_ticks ticks);
+    T_ticks T_time_to_ticks(T_time time);
+You can convert seconds and nanoseconds values into a combined time value with
+the `T_seconds_and_nanoseconds_to_time()` function.  You can convert a time
+value into separate seconds and nanoseconds values with the
+`T_time_to_seconds_and_nanoseconds()` function.
+.. code-block:: c
+    T_time T_seconds_and_nanoseconds_to_time(uint32_t s, uint32_t ns);
+    void T_time_to_seconds_and_nanoseconds(T_time time, uint32_t *s, uint32_t *ns);
+You can convert a time value into a string represention.  The time unit of the
+string representation is seconds.  The precision of the string represention may
+be nanoseconds, microseconds, milliseconds, or seconds.  You have to provide a
+buffer for the string (`T_time_string`).
+.. code-block:: c
+    const char *T_time_to_string_ns(T_time time, T_time_string buffer);
+    const char *T_time_to_string_us(T_time time, T_time_string buffer);
+    const char *T_time_to_string_ms(T_time time, T_time_string buffer);
+    const char *T_time_to_string_s(T_time time, T_time_string buffer);
+.. code-block:: c
+    :caption: Time String Example
+    #include <t.h>
+    T_TEST_CASE(time_to_string)
+        T_time_string ts;
+        T_time t;
+        uint32_t s;
+        uint32_t ns;
+        t = T_seconds_and_nanoseconds_to_time(0, 123456789);
+        T_eq_str(T_time_to_string_ns(t, ts), "0.123456789");
+        T_eq_str(T_time_to_string_us(t, ts), "0.123456");
+        T_eq_str(T_time_to_string_ms(t, ts), "0.123");
+        T_eq_str(T_time_to_string_s(t, ts), "0");
+        T_time_to_seconds_and_nanoseconds(t, &s, &ns);
+        T_eq_u32(s, 0);
+        T_eq_u32(ns, 123456789);
+    :caption: Time String Report
+    B:time_to_string
+    P:0:0:UI1:test-time.c:11
+    P:1:0:UI1:test-time.c:12
+    P:2:0:UI1:test-time.c:13
+    P:3:0:UI1:test-time.c:14
+    P:4:0:UI1:test-time.c:17
+    P:5:0:UI1:test-time.c:18
+    E:time_to_string:N:6:F:0:D:0.005250
+You can convert a tick value into a string represention.  The time unit of the
+.. code-block:: c
+    const char *T_ticks_to_string_ns(T_ticks ticks, T_time_string buffer);
+    const char *T_ticks_to_string_us(T_ticks ticks, T_time_string buffer);
+    const char *T_ticks_to_string_ms(T_ticks ticks, T_time_string buffer);
+    const char *T_ticks_to_string_s(T_ticks ticks, T_time_string buffer);
+Code Runtime Measurements
+You can measure the runtime of code fragments in several execution environment
+variants with the `T_measure_runtime()` function.  This function needs a
+context which must be created with the `T_measure_runtime_create()` function.
+The context is automatically destroyed after the test case execution.
+.. code-block:: c
+    typedef struct {
+        size_t sample_count;
+    } T_measure_runtime_config;
+    typedef struct {
+        const char *name;
+        int flags;
+        void (*setup)(void *arg);
+        void (*body)(void *arg);
+        void (*teardown)(void *arg);
+        void *arg;
+    } T_measure_runtime_request;
+    T_measure_runtime_context *T_measure_runtime_create(
+        const T_measure_runtime_config *config);
+    void T_measure_runtime(T_measure_runtime_context *ctx,
+        const T_measure_runtime_request *request);
+The runtime measurement is performed for the `body` request handler of the
+measurement request (`T_measure_runtime_request`).  The optional `setup`
+request handler is called before each invocation of the `body` request handler.
+The optional `teardown` request handler is called after each invocation of the
+`body` request handler.  The runtime of the operational `setup` and `teardown`
+request handlers is not measured.
+You can control some aspects of the measurement through the request flags (use
+zero for the default):
+T_MEASURE_RUNTIME_ALLOW_CLOCK_ISR
+    Allow clock interrupts during the measurement.  By default, measurements
+    during which a clock interrupt happened are discarded unless it happens two
+    times in a row.
+T_MEASURE_RUNTIME_REPORT_SAMPLES
+    Report all measurement samples.
+T_MEASURE_RUNTIME_DISABLE_VALID_CACHE
+    Disable the `ValidCache` execution environment variant.
+T_MEASURE_RUNTIME_DISABLE_HOT_CACHE
+    Disable the `HotCache` execution environment variant.
+T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE
+    Disable the `DirtyCache` execution environment variant.
+T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD
+    Disable the `Load` execution environment variants with a load worker count
+    less than the processor count.
+T_MEASURE_RUNTIME_DISABLE_MAX_LOAD
+    Disable the `Load` execution environment variant with a load worker count
+    equal to the processor count.
+The execution environment variants (`M:V`) are:
+ValidCache
+    Before the `body` request handler is invoked a memory area with twice the
+    size of the outer-most data cache is completely read.  This fills the data
+    cache with valid cache lines which are unrelated to the `body` request
+    handler.
+    You can disable this variant with the
+    `T_MEASURE_RUNTIME_DISABLE_VALID_CACHE` request flag.
+HotCache
+    Before the `body` request handler is invoked the `body` request handler is
+    called without measuring the runtime.  The aim is to load all data used by
+    the `body` request handler to the cache.
+    `T_MEASURE_RUNTIME_DISABLE_HOT_CACHE` request flag.
+DirtyCache
+    size of the outer-most data cache is completely written with new data.
+    This should produce a data cache with dirty cache lines which are unrelated
+    to the `body` request handler.  In addition, the entire instruction cache
+    is invalidated.
+    `T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE` request flag.
+Load
+    This variant tries to get close to worst-case conditions.  The cache is set
+    up according to the `DirtyCache` variant.  In addition, other processors
+    try to fully load the memory system.  The load is produced through writes
+    to a memory area with twice the size of the outer-most data cache.  The
+    load variant is performed multiple times with a different set of active
+    load worker threads (`M:L`).  The active workers range from one up to the
+    processor count.
+    You can disable these variants with the
+    `T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD` and
+    `T_MEASURE_RUNTIME_DISABLE_MAX_LOAD` request flags.
+    On SPARC, the `body` request handler is called with a register window
+    setting so that window overflow traps will occur in the next level function
+    call.
+Each execution in an environment variant produces a sample set of `body`
+request handler runtime measurements.  The minimum (`M:MI`), first quartile
+(`M:Q1`), median (`M:Q2`), third quartile (`M:Q3`), maximum (`M:MX`), median
+absolute deviation (`M:MAD`), and the sum of the sample values (`M:D`) is
+reported.
+.. code-block:: c
+    :caption: Code Runtime Measurement Example
+    #include <t.h>
+    static void
+    empty(void *arg)
+        (void)arg;
+    T_TEST_CASE(measure_empty)
+        static const T_measure_runtime_config config = {
+            .sample_count = 1024
+        T_measure_runtime_context *ctx;
+        T_measure_runtime_request req;
+        ctx = T_measure_runtime_create(&config);
+        T_assert_not_null(ctx);
+        memset(&req, 0, sizeof(req));
+        req.name = "Empty";
+        req.body = empty;
+        T_measure_runtime(ctx, &req);
+    :caption: Code Runtime Measurement Report
+    B:measure_empty
+    P:0:0:UI1:test-rtems-measure.c:18
+    M:B:Empty
+    M:V:ValidCache
+    M:N:1024
+    M:MI:0.000000000
+    M:Q1:0.000000000
+    M:Q2:0.000000000
+    M:Q3:0.000000000
+    M:MX:0.000000009
+    M:MAD:0.000000000
+    M:D:0.000000485
+    M:E:Empty:D:0.208984183
+    M:B:Empty
+    M:V:HotCache
+    M:N:1024
+    M:MI:0.000000003
+    M:Q1:0.000000003
+    M:Q2:0.000000003
+    M:Q3:0.000000003
+    M:MX:0.000000006
+    M:MAD:0.000000000
+    M:D:0.000002626
+    M:E:Empty:D:0.000017046
+    M:B:Empty
+    M:V:DirtyCache
+    M:N:1024
+    M:MI:0.000000007
+    M:Q1:0.000000007
+    M:Q2:0.000000007
+    M:Q3:0.000000008
+    M:MX:0.000000559
+    M:MAD:0.000000000
+    M:D:0.000033244
+    M:E:Empty:D:1.887834875
+    M:B:Empty
+    M:V:Load
+    M:L:1
+    M:N:1024
+    M:MI:0.000000000
+    M:Q1:0.000000002
+    M:Q2:0.000000002
+    M:Q3:0.000000003
+    M:MX:0.000000288
+    M:MAD:0.000000000
+    M:D:0.000002421
+    M:E:Empty:D:0.001798809
+    [... 22 more load variants ...]
+    M:E:Empty:D:0.021252583
+    M:B:Empty
+    M:V:Load
+    M:L:24
+    M:N:1024
+    M:MI:0.000000001
+    M:Q1:0.000000002
+    M:Q2:0.000000002
+    M:Q3:0.000000003
+    M:MX:0.000001183
+    M:MAD:0.000000000
+    M:D:0.000003406
+    M:E:Empty:D:0.015188063
+    E:measure_empty:N:1:F:0:D:14.284869
+Test Runner
+You can call the `T_main()` function to run all registered test cases.
+.. code-block:: c
+    int T_main(const T_config *config);
+The `T_main()` function returns 0 if all test cases passed, otherwise it
+returns 1.  Concurrent execution of the `T_main()` function is undefined
+behaviour.
+You can ask if you execute within the context of the test runner with the
+`T_is_runner()` function:
+.. code-block:: c
+    bool T_is_runner(void);
+It returns `true` if you execute within the context of the test runner (the
+context which executes for example `T_main()`).  Otherwise it returns `false`,
+for example if you execute in another task, in interrupt context, nobody
+executes `T_main()`, or during system initialization on another processor.
+On RTEMS, you have to register the test cases with the `T_register()` function
+before you call `T_main()`.  This makes it possible to run low level tests, for
+example without the operating system directly in `boot_card()` or during device
+driver initialization.  On other platforms, the `T_register()` is a no
+operation.
+.. code-block:: c
+    void T_register(void);
+You can run test cases also individually.  Use `T_run_initialize()` to
+initialize the test runner.  Call `T_run_all()` to run all or `T_run_by_name()`
+to run specific registered test cases.  Call `T_case_begin()` to begin a
+freestanding test case and call `T_case_end()` to finish it.  Finally,
+call `T_run_finalize()`.
+.. code-block:: c
+    void T_run_initialize(const T_config *config);
+    void T_run_all(void);
+    void T_run_by_name(const char *name);
+    void T_case_begin(const char *name, const T_fixture *fixture);
+    void T_case_end(void);
+    bool T_run_finalize(void);
+The `T_run_finalize()` function returns `true` if all test cases passed,
+otherwise it returns `false`.  Concurrent execution of the runner functions
+(including `T_main()`) is undefined behaviour.  The configuration must be
+persistent throughout the test run.
+Test Verbosity
+Three test verbosity levels are defined:
+T_QUIET
+    Only the test suite begin, system, test case end, and test suite end lines
+    are printed.
+T_NORMAL
+    Prints everything except passed test lines.
+T_VERBOSE
+    Prints everything.
+The test verbosity level can be set within the scope of one test case with the
+`T_set_verbosity()` function:
+.. code-block:: c
+    T_verbosity T_set_verbosity(T_verbosity new_verbosity);
+The function returns the previous verbosity.  After the test case, the
+configured verbosity is automatically restored.
+An example with `T_QUIET` verbosity:
+    .. code-block:: none
+        A:xyz
+        S:Platform:RTEMS
+        E:a:N:2:F:1
+        E:b:N:0:F:1
+        E:c:N:1:F:1
+        E:d:N:6:F:0
+        Z:xyz:C:4:N:9:F:3
+The same example with `T_NORMAL` verbosity:
+        A:xyz
+        S:Platform:RTEMS
+        B:a
+        F:1:0:UI1:test-verbosity.c:6:test fails
+        E:a:N:2:F:1
+        B:b
+        F:*:0:UI1:test-verbosity.c:12:quiet test fails
+        E:b:N:0:F:1
+        B:c
+        F:0:0:UI1:test-verbosity.c:17:this is a format string
+        E:c:N:1:F:1
+        B:d
+        E:d:N:6:F:0
+        Z:xyz:C:4:N:9:F:3
+The same example with `T_VERBOSE` verbosity:
+        A:xyz
+        S:Platform:RTEMS
+        B:a
+        P:0:0:UI1:test-verbosity.c:5
+        E:a:N:2:F:1
+        B:b
+        E:b:N:0:F:1
+        B:c
+        E:c:N:1:F:1
+        B:d
+        P:0:0:UI1:test-verbosity.c:22
+        P:1:0:UI1:test-verbosity.c:23
+        P:2:0:UI1:test-verbosity.c:24
+        P:3:0:UI1:test-verbosity.c:25
+        P:4:0:UI1:test-verbosity.c:26
+        P:5:0:UI1:test-verbosity.c:27
+        E:d:N:6:F:0
+        Z:xyz:C:4:N:9:F:3
+.. _TheTTestFrameworkTestReporting:
+Test Reporting
+The test reporting is line based which should be easy to parse with a simple
+state machine. Each line consists of a set of fields separated by colon
+characters (`:`).  The first character of the line determines the line format:
+A
+    A test suite begin line.  It has the format:
+    **A:<TestSuite>**
+    A description of the field follows:
+    <TestSuite>
+        The test suite name.  Must not contain colon characters (`:`).
+S
+    A test suite system line.  It has the format:
+    **S:<Key>:<Value>**
+    A description of the fields follows:
+    <Key>
+        A key string.  Must not contain colon characters (`:`).
+    <Value>
+        An arbitrary key value string.  May contain colon characters (`:`).
+B
+    A test case begin line.  It has the format:
+    **B:<TestCase>**
+    <TestCase>
+        A test case name.  Must not contain colon characters (`:`).
+P
+    A test pass line.  It has the format:
+    **P:<Step>:<Processor>:<Task>:<File>:<Line>**
+    <Step>
+        Each non-quiet test has a unique test step counter value in each test case
+        execution.  The test step counter is set to zero before the test case
+        executes.  For quiet test checks, there is no associated test step and the
+        character `*` instead of an integer is used to indicate this.
+    <Processor>
+        The processor index of the processor which executed at least one
+        instruction of the corresponding test.
+    <Task>
+        The name of the task which executed the corresponding test if the test
+        executed in task context.  The name `ISR` indicates that the test executed
+        in interrupt context.  The name `?` indicates that the test executed in an
+        arbitrary context with no valid executing task.
+    <File>
+        The name of the source file which contains the corresponding test.  A
+        source file of `*` indicates that no test source file is associated
+        with the test, e.g. it was produced by the test framework itself.
+    <Line>
+        The line of the test statement in the source file which contains the
+        corresponding test.  A line number of `*` indicates that no test source
+        file is associated with the test, e.g. it was produced by the test
+        framework itself.
+F
+    A test failure line.  It has the format:
+    **F:<Step>:<Processor>:<Task>:<File>:<Line>:<Message>**
+    <Step> <Processor> <Task> <File> <Line>
+        See above **P** line.
+    <Message>
+        An arbitrary message string.  May contain colon characters (`:`).
+L
+    A log message line.  It has the format:
+    **L:<Message>**
+    <Message>
+E
+    A test case end line.  It has the format:
+    **E:<TestCase>:N:<Steps>:F:<Failures>:D:<Duration>**
+    <TestCase>
+    <Steps>
+        The final test step counter of a test case.  Quiet test checks produce
+        no test steps.
+    <Failures>
+        The count of failed test checks of a test case.
+    <Duration>
+        The test case duration in seconds.
+Z
+    A test suite end line. It has the format:
+    **Z:<TestSuite>:C:<TestCases>:N:<OverallSteps>:F:<OverallFailures>:D:<Duration>**
+    <TestSuite>
+    <TestCases>
+        The count of test cases in the test suite.
+    <OverallSteps>
+        The overall count of test steps in the test suite.
+    <OverallFailures>
+        The overall count of failed test cases in the test suite.
+    <Duration>
+        The test suite duration in seconds.
+M
+    A code runtime measurement line.  It has the formats:
+    **M:B:<Name>**
+    **M:V:<Variant>**
+    **M:L:<Load>**
+    **M:N:<SampleCount>**
+    **M:S:<Count>:<Value>**
+    **M:MI:<Minimum>**
+    **M:Q1:<FirstQuartile>**
+    **M:Q2:<Median>**
+    **M:Q3:<ThirdQuartile>**
+    **M:MX:<Maximum>**
+    **M:MAD:<MedianAbsoluteDeviation>**
+    **M:D:<SumOfSampleValues>**
+    **M:E:<Name>:D:<Duration>**
+    <Name>
+        A code runtime measurement name.  Must not contain colon characters
+    <Variant>
+        The execution variant which is one of **ValidCache**, **HotCache**,
+        **DirtyCache**, or **Load**.
+    <Load>
+        The active load workers count which ranges from one to the processor
+        count.
+    <SampleCount>
+        The sample count as defined by the runtime measurement configuration.
+    <Count>
+        The count of samples with the same value.
+    <Value>
+        A sample value in seconds.
+    <Minimum>
+        The minimum of the sample set in seconds.
+    <FirstQuartile>
+        The first quartile of the sample set in seconds.
+    <Median>
+        The median of the sample set in seconds.
+    <ThirdQuartile>
+        The third quartile of the sample set in seconds.
+    <Maximum>
+        The maximum of the sample set in seconds.
+    <MedianAbsoluteDeviation>
+        The median absolute deviation of the sample set in seconds.
+    <SumOfSampleValues>
+        The sum of all sample values of the sample set in seconds.
+    <Duration>
+        The runtime measurement duration in seconds.  It includes time to set
+        up the execution environment variant.
+    :caption: Example Test Report
+    A:xyz
+    S:Platform:RTEMS
+    S:Compiler:7.3.0 20180125 (RTEMS 5, RSB 30da0c720b78eba16a3f5272206c07415368617b, Newlib 2ab57ad59bc35dafffa69cd4da5e228971de069f)
+    S:Version:5.0.0.af5840fbb3d5e5aae24af3da84c75a011098f086
+    S:BSP:erc32
+    S:RTEMS_DEBUG:0
+    S:RTEMS_MULTIPROCESSING:0
+    S:RTEMS_POSIX_API:1
+    S:RTEMS_PROFILING:0
+    S:RTEMS_SMP:0
+    B:rsc
+    P:0:0:UI1:test-rtems.c:33
+    F:1:0:UI1:test-rtems.c:34:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
+    F:*:0:UI1:test-rtems.c:36:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
+    P:2:0:UI1:test-rtems.c:37
+    F:3:0:UI1:test-rtems.c:38:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
+    E:rsc:N:4:F:3
+    B:rsc_success
+    P:0:0:UI1:test-rtems.c:44
+    F:1:0:UI1:test-rtems.c:45:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
+    F:*:0:UI1:test-rtems.c:47:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
+    P:2:0:UI1:test-rtems.c:48
+    F:3:0:UI1:test-rtems.c:49:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
+    E:rsc_success:N:4:F:3
+    B:timer
+    P:0:0:UI1:test-rtems.c:74
+    P:1:0:UI1:test-rtems.c:78
+    P:2:0:ISR:test-rtems.c:61
+    P:3:0:UI1:test-rtems.c:83
+    P:4:0:UI1:test-rtems.c:84
+    P:5:0:UI1:test-rtems.c:87
+    E:timer:N:6:F:0
+    Z:xyz:C:3:N:14:F:6
+Supported Platforms
+The framework runs on FreeBSD, MSYS2, Linux and RTEMS.
+Test Framework Requirements for RTEMS
+The requirements on a test framework suitable for RTEMS are:
+License Requirements
+TF.License.Permissive
+    The test framework shall have a permissive open source license such as
+    BSD-2-Clause.
+Portability Requirements
+TF.Portability
+    The test framework shall be portable.
+    TF.Portability.RTEMS
+        The test framework shall run on RTEMS.
+    TF.Portability.POSIX
+        The test framework shall be portable to POSIX compatible operating
+        systems.  This allows to run test cases of standard C/POSIX/etc. APIs
+        on multiple platforms.
+        TF.Portability.POSIX.Linux
+            The test framework shall run on Linux.
+        TF.Portability.POSIX.FreeBSD
+            The test framework shall run on FreeBSD.
+    TF.Portability.C11
+        The test framework shall be written in C11.
+    TF.Portability.Static
+        Test framework shall not use dynamic memory for basic services.
+    TF.Portability.Small
+        The test framework shall be small enough to support low-end platforms
+        (e.g. 64KiB of RAM/ROM should be sufficient to test the architecture
+        port, e.g. no complex stuff such as file systems, etc.).
+    TF.Portability.Small.LinkTimeConfiguration
+        The test framework shall be configured at link-time.
+    TF.Portability.Small.Modular
+        The test framework shall be modular so that only necessary parts end up
+        in the final executable.
+    TF.Portability.Small.Memory
+        The test framework shall not aggregate data during test case executions.
+Reporting Requirements
+TF.Reporting
+    Test results shall be reported.
+    TF.Reporting.Verbosity
+        The test report verbosity shall be configurable.  This allows different
+        test run scenarios, e.g. regression test runs, full test runs with test
+        report verification against the planned test output.
+    TF.Reporting.Verification
+        It shall be possible to use regular expressions to verify test reports
+        line by line.
+    TF.Reporting.Compact
+        Test output shall be compact to avoid long test runs on platforms with
+        a slow output device, e.g. 9600 Baud UART.
+    TF.Reporting.PutChar
+        A simple output one character function provided by the platform shall be
+        sufficient to report the test results.
+    TF.Reporting.NonBlocking
+        The ouptut functions shall be non-blocking.
+    TF.Reporting.Printf
+        The test framework shall provide printf()-like output functions.
+        TF.Reporting.Printf.WithFP
+            There shall be a printf()-like output function with floating point
+            support.
+        TF.Reporting.Printf.WithoutFP
+            There shall be a printf()-like output function without floating
+            point support on RTEMS.
+    TF.Reporting.Platform
+        The test platform shall be reported.
+        TF.Reporting.Platform.RTEMS.Git
+            The RTEMS source Git commit shall be reported.
+        TF.Reporting.Platform.RTEMS.Arch
+            The RTEMS architecture name shall be reported.
+        TF.Reporting.Platform.RTEMS.BSP
+            The RTEMS BSP name shall be reported.
+        TF.Reporting.Platform.RTEMS.Tools
+            The RTEMS tool chain version shall be reported.
+        TF.Reporting.Platform.RTEMS.Config.Debug
+            The shall be reported if RTEMS_DEBUG is defined.
+        TF.Reporting.Platform.RTEMS.Config.Multiprocessing
+            The shall be reported if RTEMS_MULTIPROCESSING is defined.
+        TF.Reporting.Platform.RTEMS.Config.POSIX
+            The shall be reported if RTEMS_POSIX_API is defined.
+        TF.Reporting.Platform.RTEMS.Config.Profiling
+            The shall be reported if RTEMS_PROFILING is defined.
+        TF.Reporting.Platform.RTEMS.Config.SMP
+            The shall be reported if RTEMS_SMP is defined.
+    TF.Reporting.TestCase
+        The test cases shall be reported.
+        TF.Reporting.TestCase.Begin
+            The test case begin shall be reported.
+        TF.Reporting.TestCase.End
+            The test case end shall be reported.
+        TF.Reporting.TestCase.Tests
+            The count of test checks of the test case shall be reported.
+        TF.Reporting.TestCase.Failures
+            The count of failed test checks of the test case shall be reported.
+        TF.Reporting.TestCase.Timing
+            Test case timing shall be reported.
+        TF.Reporting.TestCase.Tracing
+            Automatic tracing and reporting of thread context switches and
+            interrupt service routines shall be optionally performed.
+Environment Requirements
+TF.Environment
+    The test framework shall support all environment conditions of the platform.
+    TF.Environment.SystemStart
+        The test framework shall run during early stages of the system start,
+        e.g. valid stack pointer, initialized data and cleared BSS, nothing
+        more.
+    TF.Environment.BeforeDeviceDrivers
+        The test framework shall run before device drivers are initialized.
+    TF.Environment.InterruptContext
+        The test framework shall support test case code in interrupt context.
+Usability Requirements
+TF.Usability
+    The test framework shall be easy to use.
+    TF.Usability.TestCase
+        It shall be possible to write test cases.
+        TF.Usability.TestCase.Independence
+            It shall be possible to write test cases in modules independent of
+            the test runner.
+        TF.Usability.TestCase.AutomaticRegistration
+            Test cases shall be registered automatically, e.g. via constructors
+            or linker sets.
+        TF.Usability.TestCase.Order
+            It shall be possible to sort the registered test cases (e.g. random,
+            by name) before they are executed.
+        TF.Usability.TestCase.Resources
+            It shall be possible to use resources with a life time restricted to
+            the test case.
+            TF.Usability.TestCase.Resources.Memory
+                It shall be possible to dynamically allocate memory which is
+                automatically freed once the test case completed.
+            TF.Usability.TestCase.Resources.File
+                It shall be possible to create a file which is automatically
+                unlinked once the test case completed.
+            TF.Usability.TestCase.Resources.Directory
+                It shall be possible to create a directory which is automatically
+                removed once the test case completed.
+            TF.Usability.TestCase.Resources.FileDescriptor
+                It shall be possible to open a file descriptor which is
+                automatically closed once the test case completed.
+        TF.Usability.TestCase.Fixture
+            It shall be possible to use a text fixture for test cases.
+            TF.Usability.TestCase.Fixture.SetUp
+                It shall be possible to provide a set up handler for each test case.
+            TF.Usability.TestCase.Fixture.TearDown
+                It shall be possible to provide a tear down handler for each test
+                case.
+        TF.Usability.TestCase.Context
+            The test case context shall be verified a certain points.
+            TF.Usability.TestCase.Context.VerifyAtEnd
+                After a test case exection it shall be verified that the context
+                is equal to the context at the test case begin.  This helps to
+                ensure that test cases are independent of each other.
+            TF.Usability.TestCase.Context.VerifyThread
+                The test framework shall provide a function to ensure that the
+                test case code executes in normal thread context.  This helps
+                to ensure that operating system service calls return to a sane
+                context.
+            TF.Usability.TestCase.Context.Configurable
+                The context verified in test case shall be configurable at link-time.
+            TF.Usability.TestCase.Context.ThreadDispatchDisableLevel
+                It shall be possible to verify the thread dispatch disable level.
+            TF.Usability.TestCase.Context.ISRNestLevel
+                It shall be possible to verify the ISR nest level.
+            TF.Usability.TestCase.Context.InterruptLevel
+                It shall be possible to verify the interrupt level (interrupts
+                enabled/disabled).
+            TF.Usability.TestCase.Context.Workspace
+                It shall be possible to verify the workspace.
+            TF.Usability.TestCase.Context.Heap
+                It shall be possible to verify the heap.
+            TF.Usability.TestCase.Context.OpenFileDescriptors
+                It shall be possible to verify the open file descriptors.
+            TF.Usability.TestCase.Context.Classic
+                It shall be possible to verify Classic API objects.
+                TF.Usability.TestCase.Context.Classic.Barrier
+                    It shall be possible to verify Classic API Barrier objects.
+                TF.Usability.TestCase.Context.Classic.Extensions
+                    It shall be possible to verify Classic API User Extensions
+                    objects.
+                TF.Usability.TestCase.Context.Classic.MessageQueues
+                    It shall be possible to verify Classic API Message Queue
+                    objects.
+                TF.Usability.TestCase.Context.Classic.Partitions
+                    It shall be possible to verify Classic API Partition objects.
+                TF.Usability.TestCase.Context.Classic.Periods
+                    It shall be possible to verify Classic API Rate Monotonic
+                    Period objects.
+                TF.Usability.TestCase.Context.Classic.Regions
+                    It shall be possible to verify Classic API Region objects.
+                TF.Usability.TestCase.Context.Classic.Semaphores
+                    It shall be possible to verify Classic API Semaphore
+                    objects.
+                TF.Usability.TestCase.Context.Classic.Tasks
+                    It shall be possible to verify Classic API Task objects.
+                TF.Usability.TestCase.Context.Classic.Timers
+                    It shall be possible to verify Classic API Timer objects.
+            TF.Usability.TestCase.Context.POSIX
+                It shall be possible to verify POSIX API objects.
+                TF.Usability.TestCase.Context.POSIX.Keys
+                    It shall be possible to verify POSIX API Key objects.
+                TF.Usability.TestCase.Context.POSIX.KeyValuePairs
+                    It shall be possible to verify POSIX API Key Value Pair
+                    objects.
+                TF.Usability.TestCase.Context.POSIX.MessageQueues
+                    It shall be possible to verify POSIX API Message Queue
+                    objects.
+                TF.Usability.TestCase.Context.POSIX.Semaphores
+                    It shall be possible to verify POSIX API Named Semaphores
+                    objects.
+                TF.Usability.TestCase.Context.POSIX.Shms
+                    It shall be possible to verify POSIX API Shared Memory
+                    objects.
+                TF.Usability.TestCase.Context.POSIX.Threads
+                    It shall be possible to verify POSIX API Thread objects.
+                TF.Usability.TestCase.Context.POSIX.Timers
+                    It shall be possible to verify POSIX API Timer objects.
+    TF.Usability.Assert
+        There shall be functions to assert test objectives.
+        TF.Usability.Assert.Safe
+            Test assert functions shall be safe to use, e.g. assert(a == b) vs.
+            assert(a = b) vs. assert_eq(a, b).
+        TF.Usability.Assert.Continue
+            There shall be assert functions which allow the test case to
+            continue in case of an assertion failure.
+        TF.Usability.Assert.Abort
+            There shall be assert functions which abourt the test case in case
+            of an assertion failure.
+    TF.Usability.EasyToWrite
+        It shall be easy to write test code, e.g. avoid long namespace prefix
+        rtems_test_*.
+    TF.Usability.Threads
+        The test framework shall support multi-threading.
+    TF.Usability.Pattern
+        The test framework shall support test patterns.
+        TF.Usability.Pattern.Interrupts
+            The test framework shall support test cases which use interrupts,
+            e.g. spintrcritical*.
+        TF.Usability.Pattern.Parallel
+            The test framework shall support test cases which want to run code
+            in parallel on SMP machines.
+        TF.Usability.Pattern.Timing
+            The test framework shall support test cases which want to measure
+            the timing of code sections under various platform conditions, e.g.
+            dirty cache, empty cache, hot cache, with load from other
+            processors, etc..
+    TF.Usability.Configuration
+        The test framework shall be configurable.
+        TF.Usability.Configuration.Time
+            The timestamp function shall be configurable, e.g. to allow test
+            runs without a clock driver.
+Performance Requirements
+TF.Performance.RTEMS.No64BitDivision
+    The test framework shall not use 64-bit divisions on RTEMS.
+Off-the-shelf Test Frameworks
+There are several
+`off-the-shelf test frameworks for C/C++ <https://en.wikipedia.org/wiki/List_of_unit_testing_frameworks#C>`_.
+The first obstacle for test frameworks is the license requirement
+(`TF.License.Permissive`).
+bdd-for-c
+In the `bdd-for-c <https://github.com/grassator/bdd-for-c>`_ framework the
+complete test suite must be contained in one file and the main function is
+generated.  This violates `TF.Usability.TestCase.Independence`.
+CBDD
+The `CBDD <https://github.com/nassersala/cbdd>`_ framework uses the
+`C blocks <https://clang.llvm.org/docs/BlockLanguageSpec.html>`_ extension from
+clang.  This violates `TF.Portability.C11`.
+Google Test
+`Google Test 1.8.1 <https://git.rtems.org/sebh/rtems-gtest.git/>`_
+is supported by RTEMS.  Unfortunately, it is written in C++ and is to heavy
+weight for low-end platforms.  Otherwise it is a nice framework.
+Unity
+The `Unity Test API <https://github.com/ThrowTheSwitch/Unity>`_ does not meet
+our requirements.  There was a `discussion on the mailing list in 2013
+<https://lists.rtems.org/pipermail/devel/2013-September/004499.html>`_.
+Standard Test Report Formats
+JUnit XML
+A common test report format is `JUnit XML <http://llg.cubic.org/docs/junit/>`_.
+.. code-block:: xml
+    <?xml version="1.0" encoding="UTF-8" ?>
+    <testsuites id="xyz" name="abc" tests="225" failures="1262" time="0.001">
+      <testsuite id="def" name="ghi" tests="45" failures="17" time="0.001">
+        <testcase id="jkl" name="mno" time="0.001">
+          <failure message="pqr" type="stu"></failure>
+          <system-out>stdout</system-out>
+          <system-err>stderr</system-err>
+        </testcase>
+      </testsuite>
+    </testsuites>
+The major problem with this format is that you have to output the failure count
+of all test suites and the individual test suite before the test case output.
+You know the failure count only after a complete test run.  This runs contrary
+to requirement `TF.Portability.Small.Memory`.  It is also a bit verbose
+(`TF.Reporting.Compact`).
+It is easy to convert a full test report generated by :ref:`The T Test
+Framework <TheTTestFramework>` to the JUnit XML format.
+Test Anything Protocol
+The
+`Test Anything Protocol <http://testanything.org/>`_
+(TAP) is easy to consume and produce.
+    1..4
+    ok 1 - Input file opened
+    not ok 2 - First line of the input valid
+    ok 3 - Read the rest of the file
+    not ok 4 - Summarized correctly # TODO Not written yet
+You have to know in advance how many test statements you want to execute in a
+test case.  The problem with this format is that there is no standard way to
+provide auxiliary data such as test timing or a tracing report.
+Framework <TheTTestFramework>` to the TAP format.
2.16.4
