[PATCH] leon2-sis.ini, leon3-sis.ini: Correct run arguments
Joel Sherrill
joel at rtems.org
Thu Mar 14 18:57:40 UTC 2019
I will double check that it works without.
Thanks.
On Thu, Mar 14, 2019 at 8:44 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> I don't think this patch is necessary, the -r option is already present
> and does not need to be duplicated.
> Jiri.
> On 2019-03-14 14:21, Joel Sherrill wrote:
> > tester/rtems/testing/bsps/leon2-sis.ini | 2 +-
> > tester/rtems/testing/bsps/leon3-sis.ini | 2 +-
> > 2 files changed, 2 insertions(+), 2 deletions(-)
> > diff --git a/tester/rtems/testing/bsps/leon2-sis.ini
> b/tester/rtems/testing/bsps/leon2-sis.ini
> > index 61205ad..d0dd315 100644
> > --- a/tester/rtems/testing/bsps/leon2-sis.ini
> > +++ b/tester/rtems/testing/bsps/leon2-sis.ini
> > @@ -36,4 +36,4 @@ bsp = leon2
> > arch = sparc
> > tester = %{_rtscripts}/run.cfg
> > bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> > -bsp_run_opts = -leon2 -nouartrx -r -tlim 200 s
> > +bsp_run_opts = -r -leon2 -nouartrx -r -tlim 200 s
> > diff --git a/tester/rtems/testing/bsps/leon3-sis.ini
> b/tester/rtems/testing/bsps/leon3-sis.ini
> > index 2f933a7..9e8111f 100644
> > --- a/tester/rtems/testing/bsps/leon3-sis.ini
> > +++ b/tester/rtems/testing/bsps/leon3-sis.ini
> > @@ -36,4 +36,4 @@ bsp = leon3
> > arch = sparc
> > -bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -m 4
> > +bsp_run_opts = -r -leon3 -nouartrx -r -tlim 200 s -m 4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190314/77662f2c/attachment.html>
