rtems-libbsd build error
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Mar 15 14:48:12 UTC 2019
Hello,
I am trying to `./waf install` the libbsd but getting some error, need help
with that. The commands used and the errors are given below ...
configured using: `./waf configure --buildset=buildset/default.ini
--prefix=$HOME/development/rtems/5 --rtems-arch=arm`
configure was successful.
then : `./waf install`
Error ...
Build failed
 -> task in 'lex__nsyy' failed with exit status 1 (run with -v to display
more information)
 -> task in 'yacc__nsyy' failed with exit status 1 (run with -v to display
more information)
 -> task in 'lex_pcap' failed with exit status 1 (run with -v to display
more information)
 -> task in 'yacc_pcap' failed with exit status 1 (run with -v to display
more information)
 -> task in 'objs01' failed with exit status 1 (run with -v to display more
information)
information)
 -> task in 'yacc_pfctly' failed with exit status 1 (run with -v to display
more information)
Thanks
--vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190315/bcca67ca/attachment.html>
