erc32 dl09 Failure
Fri Mar 15 17:43:12 UTC 2019
Hi
Is this the way this test fails when the BSP doesn't have enough memory?
*** BEGIN OF TEST libdl (RTL) 9 ***
*** TEST VERSION: 5.0.0.2defa94c4ce2204cf5cb86d2900d8c48e7d7d781
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_POSIX_API
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
38241392a4f96dabf2d1aba51a43dcb623db4dfb, Newlib 1d35a003f)
 Run: 0
Test source (link in strstr): testsuites/libtests/dl09/dl-load.c
load: /dl09-o1.o
handel: 0x206cc20: unresolved externals
handle: 0x206cc20 loaded
space alloc: /dl09-o1.o: 33554432: 0
../../../../../../rtems/c/src/../../testsuites/libtests/dl09/dl-load.c: 156
o->space != NULL
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.2defa94c4ce2204cf5cb86d2900d8c48e7d7d781
RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
executing thread ID: 0x08a010001
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190315/9de04ef4/attachment.html>
