erc32 dl09 Failure
Tue Mar 19 04:30:34 UTC 2019
On 16/3/19 4:43 am, Joel Sherrill wrote:
> Hi
> Is this the way this test fails when the BSP doesn't have enough memory?
Correct, this is a test where a lot of memory is needed. The test has to make
sure the code is loaded at offsets that are greater than the relative offsets in
the generated code.
The problem with this failure is the arch, SPARC, does not need trampoline
support and so the test is actually a `nop`. I wonder if I need to handle this
better in the test by coding the archs that need to have a suitable load offset?
> *** BEGIN OF TEST libdl (RTL) 9 ***
> *** TEST VERSION: 5.0.0.2defa94c4ce2204cf5cb86d2900d8c48e7d7d781
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_POSIX_API
> *** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
> 38241392a4f96dabf2d1aba51a43dcb623db4dfb, Newlib 1d35a003f)
>  Run: 0
> Test source (link in strstr): testsuites/libtests/dl09/dl-load.c
> load: /dl09-o1.o
> handel: 0x206cc20: unresolved externals
> handle: 0x206cc20 loaded
> space alloc: /dl09-o1.o: 33554432: 0
> ../../../../../../rtems/c/src/../../testsuites/libtests/dl09/dl-load.c: 156
> o->space != NULL
> *** FATAL ***
> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> RTEMS version: 5.0.0.2defa94c4ce2204cf5cb86d2900d8c48e7d7d781
> RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
> executing thread ID: 0x08a010001
> devel mailing list
> devel at rtems.org
