POSIX Compilance- #2966, GSoC Project 2019
Aditya Upadhyay
aadit0402 at gmail.com
Tue Mar 19 18:04:04 UTC 2019
On Tue, 19 Mar 2019, 22:42 Joel Sherrill, <joel at rtems.org> wrote:
> On Tue, Mar 19, 2019 at 10:29 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Mon, Mar 18, 2019 at 4:40 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Sun, Mar 17, 2019 at 2:24 PM Joel Sherrill <joel at rtems.org> wrote:
>>> > On Sun, Mar 17, 2019, 12:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>> >> I did cloned RTEM source, newlib and rtems-libbsd.
>>> >> Kept them in same folder so as to get easy with 'grep' and 'find'.
>>> >> $ ls
>>> >> newlib-cygwin rtems rtems-libbsd
>>> >> $ grep -r grantpt ./
>>> >> ./newlib-cygwin/winsup/doc/posix.xml: grantpt
>>> >> ./newlib-cygwin/winsup/doc/posix.xml:return -1 and set errno to
>>> ENOSYS. <function>grantpt</function> and
>>> >> ./newlib-cygwin/winsup/cygwin/tty.cc:grantpt (int fd)
>>> >> ./newlib-cygwin/winsup/cygwin/libc/bsdlib.cc: grantpt (master);
>>> >> ./newlib-cygwin/winsup/cygwin/common.din:grantpt NOSIGFE
>>> >> ./newlib-cygwin/winsup/cygwin/include/cygwin/stdlib.h:int grantpt
>>> (int);
>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-1997: *
>>> cygwin.din: srandom, ptsname, grantpt, unlockpt - new exports.
>>> (grantpt): new
>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2001: *
>>> tty.cc (grantpt): Fix definition.
>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2011: *
>>> tty.cc (grantpt): Check for valid fd.
>>> >> ./newlib-cygwin/newlib/ChangeLog-2015: * libc/include/stdlib.h:
>>> add ptsname, grantpt, unlockpt to cygwin
>>> >> ./rtems/testsuites/psxtests/Makefile.am:## lib_a_SOURCES +=
>>> psxhdrs/stdlib/grantpt.c See ticket #3645
>>> >> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c: * @brief
>>> grantpt() API Conformance Test
>>> >> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c: return_value
>>> = grantpt(fildes);
>>> >> As I analyzed the output, I find no file that contains implementation
>>> of 'grantpt()', means ticket #3645(https://devel.rtems.org/ticket/3645)
>>> still needs to be addressed.
>>> >> But then how this method is used in rtems testsuites?. (refer last
>>> two lines of output for grep command).
>>> >> Am I doing something wrong? or I am missing something.
>>> > You haven't done anything wrong.
>>> > The grantpt() method is in a winsup subdirectory which indicates it is
>>> a Cygwin specific implementation.
>>> > The psxhdrs test just checks that the prototype us right in the header
>>> file.
>>> > All said, I don't know if grantpt makes sense on RTEMS or not. That's
>>> a different discussion.
>>> >> Thanks
>>> >> Vaibhav Gupta
>>> >> On Fri, Mar 8, 2019 at 5:31 AM Joel Sherrill <joel at rtems.org> wrote:
>>> >>> I'm about to head home so not going to dig into each of those but I
>>> >>> will point out for GSoC, we need to get you where you can answer
>>> >>> these questions yourself.
>>> >>> 1) clone the newlib (sourceware.org/newlib) source, RTEMS source,
>>> and
>>> >>> rtems-libbsd source. rtems-libbsd is the source for networking
>>> APIs.
>>> >>> 2) use "grep -r" (recursive grep) and find (ex: find . -name "XXX")
>>> to help you
>>> >>> find implementations.
>>> >>> For #3676, RTEMS supports aio but aio.h is one of only a handful of
>>> POSIX
>>> >>> .h files in RTEMS and not in newlib. That's why the Google Code-In
>>> student
>>> >>> couldn't find it in newlib. Just scanning the cpukit/include, I see
>>> 3 POSIX .h
>>> >>> files which could be moved to newlib. This is worth discussing on
>>> devel@
>>> >>> For the rest, I think they are still open to be implemented. Now
>>> whether the
>>> >>> method makes sense or not on RTEMS or requires more infrastructure
>>> than
>>> >>> a simple method to be added is something to determine on a case by
>>> case
>>> >>> basis.
>>> >>> --joel
>>> >>> On Thu, Mar 7, 2019 at 5:51 PM Vaibhav Gupta <
>>> vaibhavgupta40 at gmail.com> wrote:
>>> >>>> It will be very helpful to know the current status of the following
>>> tickets, and if I can choose sub-tasks from them, for GSoC project.
>>> >>>> #3676 - Add support for aio.h
>>> >>>> #3642 - Add iswalnum(), iswalpha() ... (and 18 others) to <wchar.h>
>>> header
>>> >>>> #3371 - Add dirfd() and fdopendir() methods in dirent.h
>>> >>>> #3656 - Function prototypes for posix_fadvise() and
>>> posix_fallocate() missing in <fcntl.h> header file
>>> >>>> #3652- Add support for sys/resource.h method - getpriority
>>> >>>> #3653 - Add support for sys/resource.h method - getrlimit
>>> >>>> #3654 - Add support for sys/resource.h method - setpriority
>>> >>>> #3655 - Add support for sys/resource.h method - setrlimit
>>> >>>> #3644 - Add support for stdlib.h method - getsubopt
>>> >>>> #3645 - Add support for stdlib.h method - grantpt
>>> >>>> #3646 - Add support for stdlib.h method - posix_openpt
>>> >>>> #3647 - Add support for stdlib.h method - ptsname
>>> >>>> #3648 - Add support for stdlib.h method - unlockpt
>>> >>>> #3643 - Add support for uchar.h header
>>> >>>> #3633 - add getdelim() and getline() to stdio.h
>>> >>>> Vaibhav Gupta
>>> >>>> On Thu, 7 Mar, 2019, 9:57 PM Vaibhav Gupta <
>>> vaibhavgupta40 at gmail.com wrote:
>>> >>>>> Hello,
>>> >>>>> I was exploring open projects and got very much intrested in the
>>> following ticket:
>>> >>>>> #2966 - POSIX Compilance : https://devel.rtems.org/ticket/2966
>>> >>>>> As on the page, the project is divided into multiple sub-tasks.
>>> For many of them I am not able to find their current status and if enough
>>> work is left on them to be included as a GSoC project.
>>> >>>>> I would like to know the good combinations of sub-tasks which can
>>> compile into a good GSoC project under the "POSIX" ticket. I am very much
>>> interested to take this project. It would be great if someone mentors this
>>> project, I want to discuss further on this.
>>> >>>>> Also if there are new any new projects which are not mentioned on
>>> open-projects page? That can be taken up as GSoC project, I would love to
>>> explore them as well.
>>> >>>>> Thankyou
>>> >>>>> Vaibhav Gupta
>>> I also just wanted to follow-up that for this particular project, you
>>> will need to be able to build newlib and produce patches for it. I
>>> suggest you do that during the proposal-writing period. Also, make
>>> sure your mentor approves all patches that are intended for newlib
>>> BEFORE you post to their mailing list. We had some issues in the past
>>> when student patches were not in a great shape, and the newlib folks
>>> got a little upset about having to do a lot of work that was really
>>> the responsibility of an RTEMS Mentor.
>> Yes, I have successfully build newlib-cygwin,
>> by following steps from blog of Aditya https://adityupa.wordpress.com/
>> and as I have created git-patches before, for RTEMS, so I guess
>> I will have no problem creating patch for newlib. I just need to get
>> familiar with their code-formatting styles, comment-formatting style,
>> commit-formatting styles etc.
> Awesome!
> Aditya/Gedare.. wouldn't it be nice to get the newlib editing and autoconf
> maintenance instructions in the SW Engineering Guide?
Yes !! That would be helpful for others.
I am just looking through the previous mail from Corrinna and other
maintainers. I will update my blog with what is required to send a patch to
newlib and autoconf version related issues.
Last time, I was also facing the same issues with autoconf version and then
I had built that manually.
> --joel
>> Thanks
>> Vaibhav Gupta
>>> Gedare
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190319/4a20ff81/attachment-0001.html>
