rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Mar 19 19:37:35 UTC 2019
On Tue, 19 Mar 2019 at 02:44, Christian Mauderer <list at c-mauderer.de> wrote:
> Am 18.03.19 um 20:31 schrieb Vijay Kumar Banerjee:
> > On Tue, 19 Mar 2019 at 00:56, Vijay Kumar Banerjee
> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
> > Hi Christian,
> > (it got sent by mistake :) )
> > Thanks for telling about the script, now I have the code imported and
> > it's building successfully.
> > I have forked the repo and created a branch with my commits. Please have
> > a look and see if
> > It's going in the right direction.
> > https://github.com/thelunatic/rtems-libbsd/tree/hdmi_framer
> > I have also wrote a first draft of the proposal. Are we supposed to send
> > the draft proposals only after the the application period stars? or can
> > we just share it offlist with the mentors now?
> > Thanks
> Hello Vijay,
> first regarding the proposal:
> @Joel: Please correct me if I'm wrong!
> I think it should be OK to discuss the proposal as soon as you have
> something. I assume you already have completed the Hello world and sent
> it to at least one of our Org Admins?
> I have sent pictures in the offlist thread with Joel and you, where we
were dicussing the
hardwares. I can send again in an offlist thread, along with the proposal.
> Regarding the code:
> Although the commits need some polishing (see * at the end) it looks
> like a good start that you were already able to import and compile some
> of the necessary files.
> From what I've seen, you currently pulled in three parts:
> 1. Some part of videomode. There are some awk scripts in that directory
> too so some generated files might need some processing.
> the ediddevs and modelines.c needed the scripts. I added them and
imported, but
there's a strange error with modelines.c
(If I comment it out, it builds fine)
../../freebsd/sys/dev/videomode/modelines.c:13:19: error: expected
declaration specifiers or '...' before string constant
__KERNEL_RCSID(0, "$NetBSD$");
> 2. The iic headers. That looks good. An RTEMS implementation for the
> functions most likely is necessary.
> I have added this in the proposal.
> 3. The driver for the chip that converts from the LCD interface to an
> HDMI interface. That's good and necessary too.
> What is missing (which is entirely OK at the current phase) are the
> following parts:
> A. The LCD controller driver itself (am335x_lcd.c, ...).
> Added. Along with it, I had to import other fb codes that it depends on. I
can push it in my
forked branch for you to see.
Since it has already seen some trial and errors. I think it would be better
to create a new
branch after we're happy with what's imported, then we can squash it all
into a commit
and then start the porting work to get two clean commits.
> B. The driver isn't referenced anywhere (normally would be done in
> nexus-devices.h for devices that should be always there). So it isn't
> linked into the applications yet. That's the reason that you currently
> didn't get any `function not found` errors during the linking yet ;-)
> Is there any reference that I can follow to understand how the
nexusmodule is working,
and how to add the driver to it? I had a look into the libbsd.txt
> C. The framebuffer interface of FreeBSD. I haven't had a detailed look
> at that yet. But someone has to do something with the fb_getinfo
> DEVMETHOD that is defined in am335x_lcd.c. I'm also not sure whether we
> have some generic framebuffer code in RTEMS or whether we should use it
> completely from libbsd.
> We have the fb.h and framebuffer.h headers. The RPi seems to have
implemented those
functions using own implementation using the mailbox module.
> So most likely you will find some more problems when the real work
> starts. But it would be no fun if everything would run smoothly ;-)
> Best regards
> Christian
> (*) See hints in CONTRIBUTING.md in chapter "How to Import Code from
> FreeBSD". The final commits should be (for each sensible module) one
> import commit where unchanged files are imported and one port commit
> where the files are added to libbsd.py and necessary changes are made.
> > On Sun, 17 Mar 2019 at 14:30, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 16.03.19 um 23:52 schrieb Vijay Kumar Banerjee:
> > > On Sat, 16 Mar 2019 at 01:00, Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> wrote:
> > > Am 15.03.19 um 19:20 schrieb Vijay Kumar Banerjee:
> > > > On Fri, 15 Mar 2019 at 21:47, Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
> > > > > Hello,
> > > > > I am trying to `./waf install` the libbsd but
> > getting some
> > > error,
> > > > need help
> > > > > with that. The commands used and the errors are
> > given below ...
> > > > > configured using: `./waf configure
> > > --buildset=buildset/default.ini
> > > > > --prefix=$HOME/development/rtems/5
> --rtems-arch=arm`
> > > > > configure was successful.
> > > > > then : `./waf install`
> > > > > Error ...
> > > > > Build failed
> > > > > -> task in 'lex__nsyy' failed with exit status 1
> > (run with
> > > -v to
> > > > > display more information)
> > > > > -> task in 'yacc__nsyy' failed with exit status 1
> > (run with
> > > -v to
> > > > > -> task in 'lex_pcap' failed with exit status 1
> > (run with -v to
> > > > display
> > > > > more information)
> > > > > -> task in 'yacc_pcap' failed with exit status 1
> > (run with
> > > -v to
> > > > > -> task in 'objs01' failed with exit status 1
> > (run with -v
> > > to display
> > > > > more information)
> > (run with -v
> > > to display
> > > > > more information)
> > > > > -> task in 'yacc_pfctly' failed with exit status
> > 1 (run
> > > with -v to
> > > > > Thanks
> > > > > --vijay
> > > > Hello Vijay,
> > > > did you try to build before the install? I don't see
> > the call.
> > > > Normally it's
> > > > waf configure ...
> > > > waf
> > > > waf install
> > > > If you did that: It seems that some of the lex /
> > yacc files
> > > should be
> > > > regenerated. Did you enable --enable-auto-regen
> > somewhen during an
> > > > earlier configuration run (not necessary except if
> > you import
> > > yacc or
> > > > lex files)? Did you import some yacc or lex files?
> > > > I had to install `byacc` package using yum in fedora,
> > then I used the
> > > > --enable-auto-regen
> > > > option, that worked.
> > > > However, it's still not building and I'm seeing a lot of
> > warnings, I
> > > > think this is because of the
> > > > files I imported from the freebsd source, maybe they
> > depend on some
> > > > other headers that
> > > > I didn't include. Any suggestion on how to debug, if
> > this is the
> > > case?
> > > > Best regards
> > > > Christian
> > > Hello Vijay,
> > > normally you shouldn't need the --enable-auto-regen
> > option. It only
> > > changes a lot of files that you don't want to change.
> > Especially: If you
> > > use Fedora (or some other Linux) you get GPL licensed
> > output. We
> > > normally use FreeBSD for that step and check in the
> > generated files so
> > > that no user has to use --enable-auto-regen.
> > > Regarding how to start such a port: Normally it's a good
> > idea to get
> > > some overview over what's missing. For that you import the
> > files that
> > > you think are relevant (like you already did). Then you
> > can build with
> > > `waf -k -j1` which continues even if some files are not
> > compilable (-k
> > > is for continue, -j1 so that you receive the messages in
> > order). You
> > > should get a lot of compiler errors during that run.
> > > Now comes the hard part: You have to analyse the errors
> > and try to find
> > > out what's the reason for them. If some big part is
> > missing you most
> > > likely get a lot of similar errors (like "header xy.h not
> > found"). Most
> > > likely you can identify some groups. With that you can
> > estimate what has
> > > to be ported besides the files you already imported.
> > > Identifying these groups is a quite relevant step for
> > planning the
> > > amount of work for your GSoC proposal. If you are unsure,
> > try to ask on
> > > the mailing list. You can also post the build output and
> > an assumption
> > > what groups you estimate to get some feedback.
> > > Best regards
> > > Christian
> > > Hi
> > > I figured out that there were some unnecessary imports I was
> > doing and
> > > also some necessary
> > > header files that I'm missing, after adding those most of the
> > warnings
> > > vanished. The error I'm
> > > seeing now is due to a missing '.m' header file. The error
> > looks like
> > > this ...
> > > ../../freebsd/sys/arm/ti/am335x/tda19988.c:56:10: fatal
> error:
> > > rtems/bsd/local/iicbus_if.h: No such file or directory
> > > #include <rtems/bsd/local/iicbus_if.h>
> > > There's an iicbus_if.m file in the freebsd source which is
> > being included as
> > > ``#include "iicbus_if.h"``
> > > How to work with the .m files ?
> > > Thanks
> > Hello Vijay,
> > that sounds like somewhere during the FreeBSD build process at
> > least the
> > .h file is generated out of the .m file. As far as I can tell,
> > most .m
> > files are processed with the makeobjops.awk script.
> > That's something that isn't yet cleanly integrated into the waf
> > build
> > system yet. Instead there is a "Makefile.todo" in libbsd that is
> > used
> > for this cases. Most likely you can just add that .m file and
> call a
> > make on that target.
> > Some background for the "Makefile.todo": Originally the libbsd
> > has been
> > build using one big Makefile. Due to the decision that RTEMS
> > should go
> > toward waf, most parts of that Makefile has been replaced. The
> > "Makefile.todo" is the part that is left and should be
> > integrated into
> > waf as soon as someone feels like doing it or finds someone who
> > funds
> > the the time.
> > Regarding iicbus: Most likely that is an interfaces that needs a
> > translation layer so that the RTEMS i2c framework is used. So
> > importing
> > the header with the declarations is good and correct. But you
> > will need
> > to plan some time to implement the functions based on the RTEMS
> i2c
> > interface.
> > Best regards
> > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190320/09fad31d/attachment-0001.html>
