How can I use the covoar tool?
Sebastian Huber
Wed Mar 20 12:16:23 UTC 2019
Hello,
the RTEMS project has a covoar tool:
https://git.rtems.org/rtems-tools/tree/tester/covoar
I have seen some reports generated by it, but I never used it myself. I
have trouble to find out how it works. There is nothing in the
documentation:
cd rtems-docs
grep -ri covoar .
There is some documentation available here:
https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage
If I invoke the rtems-test like this in the erc32 BSP build directory, I
get an error:
rtems-test --rtems-bsp=erc32-sis --rtems-tools=/build/rtems/5 --coverage
--target=sparc-rtems5 .
RTEMS Testing - Tester, 5.0.not_released
Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=erc32-sis
--rtems-tools=/build/rtems/5 --coverage --target=sparc-rtems5 .
Python: 3.6.5 (default, Mar 31 2018, 19:45:04) [GCC]
Host: Linux-4.12.14-lp150.12.48-default-x86_64-with-glibc2.3.4 (Linux
huber-nb-linux.suse 4.12.14-lp150.12.48-default #1 SMP Tue Feb 12
14:01:48 UTC 2019 (268f014) x86_64 x86_64)
Traceback (most recent call last):
File "/build/rtems/5/share/rtems/tester/rt/cmd-test.py", line 42, in
<module>
test.run(sys.argv[1:], command_path = base)
File "/build/rtems/5/share/rtems/tester/rt/test.py", line 300, in run
trace = cov_trace)
File "/build/rtems/5/share/rtems/tester/rt/coverage.py", line 363, in
__init__
self.target = self.macros['target']
File "/build/rtems/5/share/rtems/rtemstoolkit/macros.py", line 181,
in __getitem__
raise IndexError('key: %s' % (key))
IndexError: key: target
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
