RTEMS Requirement Management Tools
Fri Mar 22 13:03:35 UTC 2019
On 21/03/2019 14:32, Joel Sherrill wrote:
> 5. Is it possible to have custom fields? I worked on a project where
> requirements were
> tagged with project phase and HW/SW. Alternatively, can we add
> comments to the YAML
> files. Or who cares since the author information is in git.
According to the Doorstep documentation:
https://doorstop.readthedocs.io/en/latest/reference/items/
"Extended attributes
In addition to the standard attributes, Doorstop will allow any number
of custom attributes (key-value pairs) in the YAML file. The extended
attributes will not be part of a published document, but they can be
queried by a 3rd party application through the REST interface or the
Python API.
Example:
In this example, an extended attribute invented-by is added to the item.
invented-by: some.guy at email.com"
Use of a standard format such as YAML is nice since it enables us to
read these requirements files quite easily.
> Is the documentation and/or tutorial sufficient to get us started?
> Whatever tool is adopted,
> common tasks will have to be documented like we do with git use.
Similar to the Git overview in
https://docs.rtems.org/branches/master/eng/vc-authors.html
we need something similar for the requirements tool.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
