[PATCH] coverage: remove utf-8 encoding in symbolset names
Joel Sherrill
joel at rtems.org
Fri Mar 22 17:29:44 UTC 2019
This has been pushed. Thanks.
On Fri, Mar 22, 2019 at 10:26 AM Joel Sherrill <joel at rtems.org> wrote:
> I am testing this now and then will apply.
> On Fri, Mar 22, 2019 at 10:05 AM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> tester/rt/coverage.py | 3 +--
>> 1 file changed, 1 insertion(+), 2 deletions(-)
>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> index eef88f7..3e722cb 100644
>> --- a/tester/rt/coverage.py
>> +++ b/tester/rt/coverage.py
>> @@ -256,10 +256,9 @@ class symbol_parser(object):
>> self.ssets = self.symbol_set.split(',')
>> else:
>> self.ssets = config.get('symbol-sets', 'sets').split(',')
>> - self.ssets = [sset.encode('utf-8') for sset in
>> self.ssets]
>> for sset in self.ssets:
>> lib = path.join(self.build_dir, config.get('libraries',
>> sset))
>> - self.symbol_sets[sset] = lib.encode('utf-8')
>> + self.symbol_sets[sset] = lib
>> ss = self.symbol_sets[sset]
>> ss = ss.replace('@BSP@', self.bsp_name)
>> ss = ss.replace('@BUILD-TARGET@', self.target)
>> 2.20.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190322/bfceb28b/attachment-0001.html>
