[PATCH 2/4] score: Rename ScoreCPU Doxygen group
Mon Mar 25 11:45:05 UTC 2019
Update #3706.
 cpukit/include/rtems/score/object.h                              | 2 +-
 cpukit/score/cpu/arm/arm_exc_abort.S                             | 2 +-
 cpukit/score/cpu/arm/arm_exc_interrupt.S                         | 2 +-
 cpukit/score/cpu/arm/cpu.c                                       | 2 +-
 cpukit/score/cpu/arm/cpu_asm.S                                   | 2 +-
 cpukit/score/cpu/arm/include/rtems/asm.h                         | 2 +-
 cpukit/score/cpu/arm/include/rtems/score/arm.h                   | 2 +-
 cpukit/score/cpu/arm/include/rtems/score/cpu.h                   | 6 +++---
 cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h               | 2 +-
 cpukit/score/cpu/epiphany/epiphany-exception-handler.S           | 2 +-
 cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h | 2 +-
 cpukit/score/cpu/mips/include/rtems/score/cpu.h                  | 2 +-
 cpukit/score/cpu/or1k/or1k-exception-handler-low.S               | 2 +-
 cpukit/score/cpu/riscv/riscv-exception-handler.S                 | 2 +-
 cpukit/score/src/objectshrinkinformation.c                       | 1 -
 15 files changed, 16 insertions(+), 17 deletions(-)
diff --git a/cpukit/include/rtems/score/object.h b/cpukit/include/rtems/score/object.h
index 92cfed83f9..eb21382c16 100644
--- a/cpukit/include/rtems/score/object.h
+++ b/cpukit/include/rtems/score/object.h
@@ -37,7 +37,7 @@ extern "C" {
- * @defgroup ScoreCPU CPU Architecture Support
+ * @defgroup RTEMSScoreCPU CPU Architecture Support
  * @ingroup Score
diff --git a/cpukit/score/cpu/arm/arm_exc_abort.S b/cpukit/score/cpu/arm/arm_exc_abort.S
index 35f08ee84f..c044c0a47f 100644
--- a/cpukit/score/cpu/arm/arm_exc_abort.S
+++ b/cpukit/score/cpu/arm/arm_exc_abort.S
@@ -1,7 +1,7 @@
  * @file
- * @ingroup ScoreCPU
+ * @ingroup RTEMSScoreCPU
  * @brief ARM data and prefetch abort exception prologue and epilogue.
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index daa7038b0f..5afd12d13c 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM interrupt exception prologue and epilogue.
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 63c31a598d..fe621a2192 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM architecture support implementation.
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index f58b99dc6c..ea6306ac03 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -1,7 +1,7 @@
  * @file
diff --git a/cpukit/score/cpu/arm/include/rtems/asm.h b/cpukit/score/cpu/arm/include/rtems/asm.h
index f72df32325..c868b45248 100644
--- a/cpukit/score/cpu/arm/include/rtems/asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/asm.h
@@ -46,7 +46,7 @@
  * @defgroup ScoreCPUARMASM ARM Assembler Support
  * @brief ARM Assembler Support
diff --git a/cpukit/score/cpu/arm/include/rtems/score/arm.h b/cpukit/score/cpu/arm/include/rtems/score/arm.h
index bff4044a99..f8a5470bfb 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/arm.h
@@ -25,7 +25,7 @@ extern "C" {
 #endif
- * @addtogroup ScoreCPU
+ * @addtogroup RTEMSScoreCPU
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index bb8270df10..3737246f9a 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -40,7 +40,7 @@
  * @defgroup ScoreCPUARM ARM Specific Support
  * @brief ARM specific support.
@@ -96,7 +96,7 @@
 #endif /* defined(ARM_MULTILIB_ARCH_V4) */
@@ -206,7 +206,7 @@ extern "C" {
 #endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
index c430911373..c910ae6821 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM Assembler Support API
diff --git a/cpukit/score/cpu/epiphany/epiphany-exception-handler.S b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
index 23f0947cb4..a65db17a5b 100644
--- a/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
+++ b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
@@ -1,7 +1,7 @@
  * @file
  * @brief Epiphany exception support implementation.
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h b/cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h
index 04cb2de28c..bc7ec42adf 100644
--- a/cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h
+++ b/cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h
@@ -1,7 +1,7 @@
  * @file
  * @brief This include file contains macros pertaining to the
  *  Epiphany processor family.
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index 6818fb49ec..1cb31983c7 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -45,7 +45,7 @@
 #define _RTEMS_SCORE_CPU_H
- *  @defgroup ScoreCPU CPU CPU
+ *  @defgroup RTEMSScoreCPU CPU CPU
  *  @ingroup Score
diff --git a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
index 96d0c8e740..cbf69df9fc 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
+++ b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
@@ -1,7 +1,7 @@
  * @file
  * @brief OR1K exception support implementation.
diff --git a/cpukit/score/cpu/riscv/riscv-exception-handler.S b/cpukit/score/cpu/riscv/riscv-exception-handler.S
index 897a15cd11..ddb8f39d97 100644
--- a/cpukit/score/cpu/riscv/riscv-exception-handler.S
+++ b/cpukit/score/cpu/riscv/riscv-exception-handler.S
@@ -1,7 +1,7 @@
  * @file
  * @brief RISC-V exception support implementation.
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index 964f3f5ef6..9498ea2716 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -2,7 +2,6 @@
  * @file
  * @brief Shrink an Object Class Information Record
2.16.4
