[PATCH] coverage: Add subdirectory name in HTML reports
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Mar 26 12:02:07 UTC 2019
Hi,
Have you had time to try this patch?
Does the HTML report (format) look alright to you after the addition?
On Sat, Mar 23, 2019 at 4:10 AM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> tester/rt/coverage.py | 18 ++++++++++++++++++
> 1 file changed, 18 insertions(+)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 3e722cb..bdf3c5f 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -211,6 +211,23 @@ class report_gen_html:
> path.copy_tree(covoar_css_path, symbol_set_dir)
> path.copy_tree(table_js_path, symbol_set_dir)
> + def add_dir_name(self):
> + for symbol_set in self.symbol_sets:
> + symbol_set_dir = path.join(self.build_dir,
> + self.bsp + '-coverage',
> symbol_set)
> + html_files = os.listdir(symbol_set_dir)
> + for html_file in html_files:
> + html_file = path.join(symbol_set_dir, html_file)
> + if path.exists(html_file) and 'html' in html_file:
> + with open(html_file, 'r') as f:
> + file_data = f.read()
> + text = file_data[file_data.find('<div
> class="heading-title">')\
> + +len('<div class="heading-title">') \
> + : file_data.find('</div')]
> + file_data = file_data.replace(text, text + '<br>' +
> symbol_set)
> + with open(html_file, 'w') as f:
> + f.write(file_data)
> class build_path_generator(object):
> Generates the build path from the path to executables
> @@ -406,6 +423,7 @@ class coverage_run(object):
> self.macros['bsp'])
> report.generate()
> report.add_covoar_css()
> + report.add_dir_name()
> def _cleanup(self):
> if not self.no_clean:
> 2.20.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190326/1281fb19/attachment.html>
