[PATCH 0/3] Fixed ability to enable console polling for certain BSPs
    Lou Woods
    irnhorse4 at gmail.com
    Tue Mar 26 13:56:04 UTC 2019
I discovered that I was not able to turn off interrupt-based console mode on the
Xilinx Zynq BSP under Qemu via the configure command.  The fix simply exchanges
#ifdef XXX_CONSOLE_USE_INTERRUPTS for
#if XXX_CONSOLE_USE_INTERRUPTS for the BSP specific console code.
The error pattern existed for to atsamv and imx7, so they were fixed as well.
I've tested the fix on the Zynq Qemu BSP and compiled the other two BSPs.
Lou Woods (3):
  Fixed ability to enable polling on the console using configure for
    Zynq
    atsamv
    imx7
 bsps/arm/atsam/console/console.c         | 28 ++++++++++++++--------------
 bsps/arm/imx/console/console-config.c    | 16 ++++++++--------
 bsps/arm/xilinx-zynq/console/zynq-uart.c | 12 ++++++------
 3 files changed, 28 insertions(+), 28 deletions(-)
1.8.3.1
