[PATCH 0/3] Fixed ability to enable console polling for certain BSPs
Joel Sherrill
joel at rtems.org
Tue Mar 26 15:17:43 UTC 2019
On Tue, Mar 26, 2019 at 9:36 AM Sebastian Huber <
> On 26/03/2019 14:56, Lou Woods wrote:
> > From: Lou Woods <Lou.Woods at OARCorp.com>
> > I discovered that I was not able to turn off interrupt-based console
> mode on the
> > Xilinx Zynq BSP under Qemu via the configure command. The fix simply
> exchanges
> > #ifdef XXX_CONSOLE_USE_INTERRUPTS for
> > #if XXX_CONSOLE_USE_INTERRUPTS for the BSP specific console code.
> You can disable it via the configure command line, just use
> XXX_CONSOLE_USE_INTERRUPTS=
> I have never seen setting it to nothing ever documented anywhere in
the RTEMS pantheon of material. All examples I have ever seen set
these to a value
> These feature defines are not uniformly used, some use #if other use
> #ifdef.
Changing these ifdef CONSOLE_USE to #if ensures they work if the value
is set to nothing or 0. I don't see how this isn't an improvement.
--joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190326/0ee77186/attachment.html>
