[PATCH 0/3] Fixed ability to enable console polling for certain BSPs
Tue Mar 26 16:18:32 UTC 2019
----- Am 26. Mrz 2019 um 16:17 schrieb joel joel at rtems.org:
> On Tue, Mar 26, 2019 at 9:36 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 26/03/2019 14:56, Lou Woods wrote:
>> > From: Lou Woods <Lou.Woods at OARCorp.com>
>> > I discovered that I was not able to turn off interrupt-based console
>> mode on the
>> > Xilinx Zynq BSP under Qemu via the configure command.  The fix simply
>> exchanges
>> > #ifdef XXX_CONSOLE_USE_INTERRUPTS for
>> > #if XXX_CONSOLE_USE_INTERRUPTS for the BSP specific console code.
>> You can disable it via the configure command line, just use
>> XXX_CONSOLE_USE_INTERRUPTS=
>> I have never seen setting it to nothing ever documented anywhere in
> the RTEMS pantheon of material. All examples I have ever seen set
> these to a value
>> These feature defines are not uniformly used, some use #if other use
>> #ifdef.
> Changing these ifdef CONSOLE_USE to #if ensures they work if the value
> is set to nothing or 0. I don't see how this isn't an improvement.
I just wanted to point out that this patch changes something that works into something else that works also. The change is somewhat arbitrary.  It should be accompanied with a recommendation in the BSP developer documentation.  There should be also a ticket for this to change everything from #ifdef XYZ to #if XYZ, if we agree that this is actually better.  Only for BSP options, for stuff which is available via <bsp.h>, or does it stop, when we change all the #if defined(RTEMS_SMP) to #if RTEMS_SMP?
For example BSP_FDT_IS_SUPPORTED is also used in libbsd:
rtemsbsd/include/rtems/bsd/local/opt_platform.h
Some BSPs use a define in <bsp.h> another uses a BSP option.
