[PATCH 01/25] score: Add Blackfin CPU architecture group
Fri Mar 29 10:52:46 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/bfin/include/rtems/score/cpu.h    | 36 ++++++++++++----------
 .../score/cpu/bfin/include/rtems/score/cpuimpl.h   | 12 ++++++++
 2 files changed, 32 insertions(+), 16 deletions(-)
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
index 481762d7b8..4b4e5b5868 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
@@ -191,7 +191,7 @@ extern "C" {
 #define CPU_STRUCTURE_ALIGNMENT
- * @ingroup CPUInterrupt
+ * @addtogroup RTEMSScoreCPUBfinCPUInterrupt
  * The following defines the number of bits actually used in the
  * interrupt field of the task mode.  How those bits map to the
  * CPU interrupt levels is defined by the routine @ref _CPU_ISR_Set_level.
@@ -217,7 +217,9 @@ extern "C" {
 #ifndef ASM
- * @defgroup CPUContext Processor Dependent Context Management
+ * @defgroup RTEMSScoreCPUBfinCPUContext Processor Dependent Context Management
+ * @ingroup RTEMSScoreCPUBfin
  * From the highest level viewpoint, there are 2 types of context to save.
@@ -312,9 +314,12 @@ typedef struct {
- * @defgroup CPUInterrupt Processor Dependent Interrupt Management
+ * @defgroup RTEMSScoreCPUBfinCPUInterrupt Processor Dependent Interrupt Management
  *  Nothing prevents the porter from declaring more CPU specific variables.
@@ -327,7 +332,7 @@ typedef struct {
 /* XXX: if needed, put more variables here */
- * @ingroup CPUContext
+ * @addtogroup RTEMSScoreCPUBfinCPUContext
  * The size of the floating point context area.  On some CPUs this
  * will not be a "sizeof" because the format of the floating point
  * area is not defined -- only the size is.  This is usually on
@@ -342,6 +347,7 @@ typedef struct {
 #endif /* ASM */
  * Amount of extra stack (above minimum stack size) required by
  * MPCI receive server thread.  Remember that in a multiprocessor
  * system this thread must exist and be able to process all directives.
@@ -353,7 +359,7 @@ typedef struct {
 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
  * This defines the number of entries in the @ref _ISR_Vector_table managed
  * by RTEMS.
@@ -364,22 +370,20 @@ typedef struct {
 #define CPU_INTERRUPT_NUMBER_OF_VECTORS      16
  * This defines the highest interrupt vector number for this port.
 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER  (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
  * This is defined if the port has a special way to report the ISR nesting
  * level.  Most ports maintain the variable @a _ISR_Nest_level.
 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
  * Should be large enough to run all RTEMS tests.  This ensures
  * that a "reasonable" small application should not have any problems.
@@ -450,7 +454,7 @@ typedef struct {
- * @addtogroup CPUInterrupt
@@ -555,7 +559,7 @@ uint32_t   _CPU_ISR_Get_level( void );
 /* Context handler macros */
  * Initialize the context to a state suitable for starting a
  * task after a context restore operation.  Generally, this
  * involves:
@@ -675,7 +679,7 @@ void _CPU_ISR_install_vector(
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
- * @addtogroup CPUContext
@@ -752,7 +756,7 @@ typedef CPU_Interrupt_frame CPU_Exception_frame;
 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
- * @ingroup CPUEndian
+ * @addtogroup CPUEndian
  * The following routine swaps the endian format of an unsigned int.
  * It must be static because it is referenced indirectly.
@@ -795,7 +799,7 @@ static inline uint32_t CPU_swap_u32(
  * This routine swaps a 16 bir quantity.
  * @param[in] value is the value to be swapped
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
index 78b87ef981..2140487fc3 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUBfin Blackfin
+ * @brief Blackfin Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifndef ASM
@@ -53,4 +63,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
2.16.4
