[PATCH 03/25] score: Add i386 CPU architecture group
Fri Mar 29 10:52:48 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/i386/include/rtems/asm.h              | 11 +++++++++++
 cpukit/score/cpu/i386/include/rtems/score/cpu.h        | 11 +++++++++++
 cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h    | 12 ++++++++++++
 cpukit/score/cpu/i386/include/rtems/score/i386.h       |  2 ++
 cpukit/score/cpu/i386/include/rtems/score/idtr.h       |  2 ++
 cpukit/score/cpu/i386/include/rtems/score/interrupts.h | 10 ++++++++++
 cpukit/score/cpu/i386/include/rtems/score/paravirt.h   |  9 +++++++--
 cpukit/score/cpu/i386/include/rtems/score/registers.h  |  2 ++
 8 files changed, 57 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/i386/include/rtems/asm.h b/cpukit/score/cpu/i386/include/rtems/asm.h
index 50b0fd71a0..5db402c930 100644
--- a/cpukit/score/cpu/i386/include/rtems/asm.h
+++ b/cpukit/score/cpu/i386/include/rtems/asm.h
@@ -39,6 +39,15 @@
 #include <rtems/score/i386.h>
+ * @defgroup RTEMSScoreCPUi386ASM i386 Assembler Support
+ * @ingroup RTEMSScoreCPUi386
+ * @brief i386 Assembler Support
  *  Recent versions of GNU cpp define variables which indicate the
  *  need for underscores and percents.  If not using GNU cpp or
@@ -137,4 +146,6 @@
 #define PUBLIC(sym) .globl SYM (sym)
 #define EXTERN(sym) .globl SYM (sym)
 #endif
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 10614a72ee..19562e7623 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -32,6 +32,15 @@ extern "C" {
 #include <rtems/score/paravirt.h>
 #endif
+ * @defgroup ScoreCPUi386 i386 Specific Support
+ * @brief i386 specific support.
 /* conditional compilation parameters */
@@ -649,6 +658,8 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
 /** Type that can store a 32-bit integer or a pointer. */
 typedef uintptr_t CPU_Uint32ptr;
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
index 78b87ef981..a89b1fedfb 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUi386 i386
+ * @brief i386 Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifndef ASM
@@ -53,4 +63,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/i386/include/rtems/score/i386.h b/cpukit/score/cpu/i386/include/rtems/score/i386.h
index 4b94e6feeb..549011055e 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/i386.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/i386.h
@@ -2,6 +2,8 @@
  * @file
  * @brief Intel I386 CPU Dependent Source
+ * @addtogroup RTEMSScoreCPUi386
  * This include file contains information pertaining to the Intel
  * i386 processor.
diff --git a/cpukit/score/cpu/i386/include/rtems/score/idtr.h b/cpukit/score/cpu/i386/include/rtems/score/idtr.h
index a79af40792..c40fce1fba 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/idtr.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/idtr.h
@@ -3,6 +3,8 @@
  * @brief Intel I386 Data Structures
  * This file contains definitions for data structure related
  *          to Intel system programming. More information can be found
  *          on Intel site and more precisely in the following book :
diff --git a/cpukit/score/cpu/i386/include/rtems/score/interrupts.h b/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
index b682772617..cac9ba9b42 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
@@ -16,6 +16,15 @@
  *  Applications must not include this file directly.
+ * @defgroup RTEMSScoreCPUi386Interrupt Processor Dependent Interrupt Management
+ * @brief i386 Interrupt Management
 #ifndef _RTEMS_SCORE_INTERRUPTS_H
 #define _RTEMS_SCORE_INTERRUPTS_H
@@ -81,5 +90,6 @@ uint32_t i386_get_interrupt_level( void );
 #endif
 #endif
diff --git a/cpukit/score/cpu/i386/include/rtems/score/paravirt.h b/cpukit/score/cpu/i386/include/rtems/score/paravirt.h
index 40eddb84be..1b26226ad0 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/paravirt.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/paravirt.h
@@ -25,10 +25,12 @@
 #define _RTEMS_SCORE_PARAVIRT_H
- * @defgroup Paravirti386 Paravirtualization i386 Support
+ * @defgroup RTEMSScoreCPUi386Paravirt i386 Paravirtualization Support
- * @ingroup Score
  * This handler encapulates the functionality (primarily conditional
  * feature defines) related to paravirtualization on the i386.
@@ -40,6 +42,7 @@
  *     hosting environment.
 #ifndef ASM
 #ifdef __cplusplus
@@ -61,3 +64,5 @@ extern "C" {
 #define I386_DISABLE_INLINE_ISR_DISABLE_ENABLE
 #endif
diff --git a/cpukit/score/cpu/i386/include/rtems/score/registers.h b/cpukit/score/cpu/i386/include/rtems/score/registers.h
index 254fef701b..79c0ec3e81 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/registers.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/registers.h
@@ -3,6 +3,8 @@
  * @brief Intel CPU Constants and Definitions
  * This file contains definition and constants related to Intel Cpu
2.16.4
