[PATCH 16/25] score: Add V850 CPU architecture group
Fri Mar 29 10:53:01 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/v850/include/rtems/asm.h          | 12 +++++++
 cpukit/score/cpu/v850/include/rtems/score/cpu.h    | 39 ++++++++++++----------
 .../score/cpu/v850/include/rtems/score/cpuimpl.h   | 12 +++++++
 3 files changed, 45 insertions(+), 18 deletions(-)
diff --git a/cpukit/score/cpu/v850/include/rtems/asm.h b/cpukit/score/cpu/v850/include/rtems/asm.h
index 265e4967ae..d9c21e1ea9 100644
--- a/cpukit/score/cpu/v850/include/rtems/asm.h
+++ b/cpukit/score/cpu/v850/include/rtems/asm.h
@@ -39,6 +39,16 @@
 #include <rtems/score/no_cpu.h>
+ * @defgroup RTEMSScoreCPUV850ASM V850 Assembler Support
+ * @ingroup RTEMSScoreCPUV850
+ * @brief V850 Assembler Support
 #ifndef __USER_LABEL_PREFIX__
  * Recent versions of GNU cpp define variables which indicate the
@@ -125,3 +135,5 @@
 #define EXTERN(sym) .globl SYM (sym)
 #endif
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index 7011366ffb..9c83a5442d 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -183,7 +183,7 @@ extern "C" {
 #define CPU_STRUCTURE_ALIGNMENT
- * @ingroup CPUInterrupt
+ * @addtogroup RTEMSScoreCPUV850CPUInterrupt
  * The following defines the number of bits actually used in the
  * interrupt field of the task mode.  How those bits map to the
  * CPU interrupt levels is defined by the routine @ref _CPU_ISR_Set_level.
@@ -197,7 +197,9 @@ extern "C" {
 #define CPU_MAXIMUM_PROCESSORS 32
- * @defgroup CPUContext Processor Dependent Context Management
+ * @defgroup RTEMSScoreCPUV850CPUContext Processor Dependent Context Management
  * From the highest level viewpoint, there are 2 types of context to save.
@@ -238,7 +240,7 @@ extern "C" {
  * On the v850, this port saves special registers and those that are
  * callee saved.
  * This defines the minimal set of integer and processor state registers
@@ -295,15 +297,7 @@ typedef struct {
     uint32_t   special_interrupt_register;
 } CPU_Interrupt_frame;
- * @defgroup CPUInterrupt Processor Dependent Interrupt Management
- * @ingroup CPUContext
  * The size of the floating point context area.  On some CPUs this
  * will not be a "sizeof" because the format of the floating point
  * area is not defined -- only the size is.  This is usually on
@@ -317,6 +311,15 @@ typedef struct {
 /* #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) */
 #define CPU_CONTEXT_FP_SIZE 0
+ * @defgroup RTEMSScoreCPUV850CPUInterrupt Processor Dependent Interrupt Management
  * Amount of extra stack (above minimum stack size) required by
  * MPCI receive server thread.  Remember that in a multiprocessor
@@ -338,7 +341,7 @@ typedef struct {
+ * @addtogroup RTEMSScoreCPUV850CPUContext
  * Should be large enough to run all RTEMS tests.  This ensures
  * that a "reasonable" small application should not have any problems.
@@ -408,9 +411,9 @@ typedef struct {
- * @addtogroup CPUInterrupt
  * Disable all interrupts for an RTEMS critical section.  The previous
@@ -516,7 +519,7 @@ uint32_t   _CPU_ISR_Get_level( void );
 /* Context handler macros */
  * Initialize the context to a state suitable for starting a
  * task after a context restore operation.  Generally, this
  * involves:
@@ -641,7 +644,7 @@ void _CPU_Initialize(void);
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
- * @addtogroup CPUContext
@@ -724,7 +727,7 @@ typedef CPU_Interrupt_frame CPU_Exception_frame;
 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
- * @ingroup CPUEndian
+ * @addtogroup CPUEndian
  * The following routine swaps the endian format of an unsigned int.
  * It must be static because it is referenced indirectly.
@@ -776,7 +779,7 @@ static inline uint32_t CPU_swap_u32(
  * This routine swaps a 16 bir quantity.
  * @param[in] value is the value to be swapped
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
index 78b87ef981..f7b02ccb6b 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUV850 V850
+ * @brief V850 Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifndef ASM
@@ -53,4 +63,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
2.16.4
