[PATCH 12/25] score: Add RISC-V CPU architecture group
Fri Mar 29 10:52:57 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/riscv/include/rtems/asm.h           | 12 ++++++++++++
 cpukit/score/cpu/riscv/include/rtems/score/cpu.h     |  1 +
 cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h | 12 ++++++++++++
 cpukit/score/cpu/riscv/riscv-exception-handler.S     |  2 +-
 4 files changed, 26 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/cpu/riscv/include/rtems/asm.h b/cpukit/score/cpu/riscv/include/rtems/asm.h
index a2f483536f..4e09d16410 100644
--- a/cpukit/score/cpu/riscv/include/rtems/asm.h
+++ b/cpukit/score/cpu/riscv/include/rtems/asm.h
@@ -59,6 +59,16 @@
 #include <rtems/score/riscv.h>
+ * @defgroup RTEMSScoreCPURISCVASM RISC-V Assembler Support
+ * @ingroup RTEMSScoreCPURISCV
+ * @brief RISC-V Assembler Support
  *  Recent versions of GNU cpp define variables which indicate the
  *  need for underscores and percents.  If not using GNU cpp or
@@ -192,3 +202,5 @@
 .endm
 #endif
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index bb866d8b02..e08307d372 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -1,5 +1,6 @@
  * @file
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
index 5a256e8b75..c381cce110 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
@@ -34,6 +34,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPURISCV RISC-V
+ * @brief RISCV Architecture Support
 #if defined(__riscv_atomic) && __riscv_xlen == 64
 #define CPU_PER_CPU_CONTROL_SIZE 48
 #elif defined(__riscv_atomic) && __riscv_xlen == 32
@@ -418,4 +428,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/riscv/riscv-exception-handler.S b/cpukit/score/cpu/riscv/riscv-exception-handler.S
index ddb8f39d97..9330f246b1 100644
--- a/cpukit/score/cpu/riscv/riscv-exception-handler.S
+++ b/cpukit/score/cpu/riscv/riscv-exception-handler.S
@@ -1,7 +1,7 @@
  * @file
- * @ingroup RTEMSScoreCPU
+ * @addtogroup RTEMSScoreCPURISCV
  * @brief RISC-V exception support implementation.
2.16.4
