GSoC Proposal : BeagleBoard project
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Mar 31 18:41:08 UTC 2019
On Mon, Apr 1, 2019 at 12:01 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 31.03.19 um 19:33 schrieb Vijay Kumar Banerjee:
> > On Sun, Mar 31, 2019 at 1:25 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 31.03.19 um 09:08 schrieb Vijay Kumar Banerjee:
> > > On Sun, Mar 31, 2019 at 7:27 AM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>
> > > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > > On 31/3/19 5:05 am, Vijay Kumar Banerjee wrote:
> > > > On Sat, Mar 30, 2019 at 5:09 PM Gedare Bloom
> > <gedare at rtems.org <mailto:gedare at rtems.org>
> > > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>> wrote:
> > > > Remember you can submit your "Final" proposal many times
> on
> > > GSoC site.
> > > > I made a few comments just regarding the 'public' view
> > of your
> > > > project. I think the technical plan looks reasonable, and
> > > leave it to
> > > > the potential mentors to steer your technical path.
> > > > Gedare
> > > > Thank you for reviewing the proposal. I have made the changes
> > > according to the
> > > > comments and also have uploaded the final proposal in the
> summer
> > > of code site.
> > > How will this be tested?
> > > The target is to get a console on display. To test each step, I was
> > > planning to write some
> > > tests like to test the EDID reading, we can write a test that
> returns
> > > the EDID reading if the
> > > display is detected, or an error if it's not there.
> > > I think this point is very important and not very clear to me yet.
> Do
> > > you have any suggestions
> > > on testing each part of the project and if possible, include them
> > in the
> > > testsuite?
> > > Is https://github.com/littlevgl/lvgl of any value?
> > > I had a brief look and this looks really great and can be a nice
> > > addition to RTEMS.
> > > I think this will go in the "future improvements" (?)
> > > Chris
> > I would suggest a framebuffer console as the primary target for this
> > project. Maybe as an extended goal it could be nice to try the
> libraries
> > already in RSB:
> https://git.rtems.org/rtems-source-builder/tree/rtems/config/graphics
> > Adding a new library would be a very extended goal in my view
> because it
> > hast the potential to eat up a lot of time.
> > Vijay: I think you most likely need some test application already
> during
> > phase 2? So maybe you should add a point that you want to at least
> start
> > a fb-console there? Alternatively: Some simple test application that
> > just draws some dots or lines?
> > In phase 3 it would be great to have the graphics libraries as
> extended
> > goal (lower priority than cleanup and getting code merged).
> > Hi,
> > Thanks for the notes. I have added a point about writing a test
> > application in phase 2
> > and also mentioned the intention to use the RSB graphics library to get
> > a GUI after the
> > code gets merged.
> It would be great if you could explicitly mention the framebuffer
> console at end of phase 2 / begin of phase 3. Alternatively (if you
> don't want a console) a test application with <some graphics library>.
I added it as a point in the beginning of phase3.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190401/54fd9488/attachment.html>
