[PATCH] RSB: upgrade to sis 2.13 (was: Issue with sis and Leon3)
Sat Mar 2 21:53:04 UTC 2019
Jiri.. can't you push this yourself? :)
FWIW The hash on rtems-tools needs a bump if it doesn't reflect the mailer
fix I committed.  Might as well have the next tools to catch both.
On Sat, Mar 2, 2019, 2:50 PM Jiri Gaisler <jiri at gaisler.se> wrote:
> The attached patch for RSB solves the problem of output not being flushed
> in gdb/sis and run/sis.  Note that I would discourage the use of run as it
> cannot run the SMP tests. I have also experienced some random hangs in
> rtems-test when using run, but never with sis.
> Jiri.
> On 3/1/19 4:53 PM, Joel Sherrill wrote:
> Thank you for being so responsive.
> I suspected a missing flush but had no idea where to look. I hopedyou
> would spot the missing line of code quickly and was right. :)
> --joel
> On Thu, Feb 28, 2019 at 1:01 PM Jiri Gaisler <jiri at gaisler.se> wrote:
>> I have found the problem, stdout is not flushed when the simulator stops
>> and it has been invoked by gdb. The run command uses the gdb interface to
>> call sis, so this is why it happens there too. I will make a new sis patch
>> (2.13) with some additional (speed) improvements...
>> Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190302/dd2327d0/attachment-0002.html>
