Question about PPPD Sample
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Thu Mar 7 14:46:58 UTC 2019
Hi Sebastian,
The example you provided definitely helps. I altered the samples/pppd example and I believe the connection is up, but I would like to try the telnet and ftpd to be sure.
Thanks,
Alan
On 3/7/19, 2:06 AM, "Sebastian Huber" <sebastian.huber at embedded-brains.de> wrote:
Hello Alan,
while porting the PPP support to libbsd I had some trouble to get it
working. Maybe the example in libbsd helps:
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dlibbsd_tree_testsuite_ppp01_test-5Fmain.c&d=DwIFaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=mW-jVVDIxBn4bZU1jogCo9FDuDuPszsoVj1mqBvCXzw&m=zzcP80iI_d34_3xAt8mVWKj-snBF0szdrOejnYhYMwk&s=B_2h1B1_XbtgYXJKVnt4DhVRJ8H5LdOx7GNrQ--2Uv0&e=
I was able to connect and RTEMS system with my Linux host and connect
via Telnet.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
