[PATCH 3/3] ttest01: New test
    Sebastian Huber
    Thu Mar 14 10:24:16 UTC 2019
This is an example test using the T Test Framework.  It tests also the
framework itself.
Add T_FILE_NAME command line define to get rid of the full file path.
This is important to reduce the read-only data of test files and make
them build system independent.
Update #3199.
 testsuites/automake/compile.am             |   1 +
 testsuites/libtests/Makefile.am            |  10 ++
 testsuites/libtests/configure.ac           |   1 +
 testsuites/libtests/ttest01/init.c         | 164 +++++++++++++++++++++++++++++
 testsuites/libtests/ttest01/t-self-test.h  |  46 ++++++++
 testsuites/libtests/ttest01/test-example.c |  57 ++++++++++
 testsuites/libtests/ttest01/ttest01.doc    |  19 ++++
 testsuites/libtests/ttest01/ttest01.scn    |  26 +++++
 8 files changed, 324 insertions(+)
 create mode 100644 testsuites/libtests/ttest01/init.c
 create mode 100644 testsuites/libtests/ttest01/t-self-test.h
 create mode 100644 testsuites/libtests/ttest01/test-example.c
 create mode 100644 testsuites/libtests/ttest01/ttest01.doc
 create mode 100644 testsuites/libtests/ttest01/ttest01.scn
diff --git a/testsuites/automake/compile.am b/testsuites/automake/compile.am
index 83d4ab111c..66ea9a8421 100644
--- a/testsuites/automake/compile.am
+++ b/testsuites/automake/compile.am
@@ -11,6 +11,7 @@ STRIP = @STRIP@
 TEST_LD_FLAGS = -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar
 AM_CPPFLAGS = $(TEST_FLAGS) @RTEMS_CPPFLAGS@ @RTEMS_BSP_CPPFLAGS@
+AM_CPPFLAGS += -DT_FILE_NAME='"$(notdir $<)"'
 AM_CFLAGS   = $(TEST_C_FLAGS)
 AM_CXXFLAGS = $(TEST_CXX_FLAGS)
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 789380ce72..3952979228 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1448,6 +1448,16 @@ top_SOURCES = top/init.c top/task1.c top/task2.c top/task3.c \
 top_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_top) $(support_includes)
 endif
+if TEST_ttest01
+lib_tests += ttest01
+lib_screens += ttest01/ttest01.scn
+lib_docs += ttest01/ttest01.doc
+ttest01_SOURCES = ttest01/init.c
+ttest01_SOURCES += ttest01/test-example.c
+ttest01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_ttest01) \
+	$(support_includes)
+endif
 if TEST_tztest
 lib_tests += tztest
 lib_screens += tztest/tztest.scn
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 3bcc0ec5c4..015f9eafa0 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -225,6 +225,7 @@ RTEMS_TEST_CHECK([termios07])
 RTEMS_TEST_CHECK([termios08])
 RTEMS_TEST_CHECK([termios09])
 RTEMS_TEST_CHECK([top])
+RTEMS_TEST_CHECK([ttest01])
 RTEMS_TEST_CHECK([tztest])
 RTEMS_TEST_CHECK([uid01])
 RTEMS_TEST_CHECK([unlink])
diff --git a/testsuites/libtests/ttest01/init.c b/testsuites/libtests/ttest01/init.c
new file mode 100644
index 0000000000..141b89c93f
--- /dev/null
+++ b/testsuites/libtests/ttest01/init.c
@@ -0,0 +1,164 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018, 2019 embedded brains GmbH
+ * are met:
+#include <t.h>
+#include <sys/time.h>
+#include <string.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include "t-self-test.h"
+#include <tmacros.h>
+const char rtems_test_name[] = "TTEST 1";
+#define test_assert(e) (e) ? (void)0 : test_failed(__LINE__, #e)
+RTEMS_LINKER_ROSET(t_self_test, const char *);
+typedef struct {
+	const char *c;
+	BSP_output_char_function_type output_char;
+	size_t case_begin_count;
+	size_t case_end_count;
+} test_context;
+static test_context test_instance;
+static void
+test_failed(int line, const char *e)
+	BSP_output_char = test_instance.output_char;
+	printk("FAILED:%i:%s\n", line, e);
+	rtems_test_exit(1);
+static void
+output_char(char c)
+	test_context *ctx;
+	ctx = &test_instance;
+	if (c != '\r' && ctx->c != NULL) {
+		test_assert(*ctx->c == c);
+		++ctx->c;
+	(*ctx->output_char)(c);
+static void
+case_begin(const char *name)
+	const char **item;
+	ssize_t n;
+	++ctx->case_begin_count;
+	n = strlen(name);
+	RTEMS_LINKER_SET_FOREACH(t_self_test, item) {
+		const char *to;
+		to = *item;
+		if (strncmp(name, to, n) == 0 && to[n] == ':') {
+			ctx->c = to + n + 1;
+			return;
+	test_assert(0);
+static void
+case_end(const char *name)
+	++ctx->case_end_count;
+	test_assert(ctx->c != NULL);
+	test_assert(*ctx->c == '\0');
+	ctx->c = NULL;
+static Atomic_Ulong counter;
+static T_time
+now(void)
+	return _Atomic_Fetch_add_ulong(&counter, SBT_1MS, ATOMIC_ORDER_RELAXED);
+static const T_config config = {
+	.name = "ttest01",
+	.verbosity = T_VERBOSE,
+	.case_begin = case_begin,
+	.case_end = case_end,
+	.now = now
+static void
+Init(rtems_task_argument arg)
+	int exit_code;
+	size_t case_count;
+	(void)arg;
+	TEST_BEGIN();
+	ctx->output_char = BSP_output_char;
+	BSP_output_char = output_char;
+	test_assert(!T_is_runner());
+	T_register();
+	exit_code = T_main(&config);
+	test_assert(exit_code == 1);
+	case_count = RTEMS_LINKER_SET_ITEM_COUNT(t_self_test);
+	test_assert(ctx->case_begin_count == case_count);
+	test_assert(ctx->case_end_count == case_count);
+	TEST_END();
+	rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/ttest01/t-self-test.h b/testsuites/libtests/ttest01/t-self-test.h
index 0000000000..1035872c9d
--- /dev/null
+++ b/testsuites/libtests/ttest01/t-self-test.h
@@ -0,0 +1,46 @@
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+#ifndef THE_T_TEST_FRAMEWORK_SELF_TEST_H
+#define THE_T_TEST_FRAMEWORK_SELF_TEST_H
+#include <rtems/linkersets.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+RTEMS_LINKER_ROSET_DECLARE(t_self_test, const char *);
+#define T_TEST_OUTPUT(name, output) \
+    RTEMS_LINKER_ROSET_ITEM(t_self_test, const char *, name) = #name ":" output
+#ifdef __cplusplus
+#endif /* THE_T_TEST_FRAMEWORK_SELF_TEST_H */
diff --git a/testsuites/libtests/ttest01/test-example.c b/testsuites/libtests/ttest01/test-example.c
index 0000000000..bcbf7b33b0
--- /dev/null
+++ b/testsuites/libtests/ttest01/test-example.c
@@ -0,0 +1,57 @@
+#include <t.h>
+T_TEST_CASE(example)
+	T_true(true, "test passes, no message output");
+	T_true(false, "test fails");
+	T_quiet_true(true, "quiet test passes, no output at all");
+	T_quiet_true(false, "quiet test fails");
+	T_step_true(2, true, "step test passes, no message output");
+	T_step_true(3, false, "step test fails");
+	T_assert_false(true, "this is a format %s", "string");
+T_TEST_OUTPUT(example,
+"B:example\n"
+"P:0:0:UI1:test-example.c:5\n"
+"F:1:0:UI1:test-example.c:6:test fails\n"
+"F:*:0:UI1:test-example.c:8:quiet test fails\n"
+"P:2:0:UI1:test-example.c:9\n"
+"F:3:0:UI1:test-example.c:10:step test fails\n"
+"F:4:0:UI1:test-example.c:11:this is a format string\n"
+"E:example:N:5:F:4:D:0.001000\n");
+ * SPDX-License-Identifier: CC-BY-SA-4.0
+ * are met:
+ * ALTERNATIVELY, this software may be distributed under the terms of the
+ * Creative Commons Attribution-ShareAlike 4.0 International Public License as
+ * published by Creative Commons, PO Box 1866, Mountain View, CA 94042
+ * (https://creativecommons.org/licenses/by-sa/4.0/legalcode).
diff --git a/testsuites/libtests/ttest01/ttest01.doc b/testsuites/libtests/ttest01/ttest01.doc
index 0000000000..37d9ff8535
--- /dev/null
+++ b/testsuites/libtests/ttest01/ttest01.doc
@@ -0,0 +1,19 @@
+This file describes the directives and concepts tested by this test set.
+test set name: ttest01
+The test-*.c files must place the license header at the bottom of the file.
+This allows a copy and past of the test code into documentation sources and
+enables a constent line numbering between the documentation code fragements and
+the actual test output.  For the same reason the T_TEST_OUTPUT() macros must be
+placed after the actual test cases.  The test source files are dual licensesd
+BSD-2-Clause and CC-BY-SA-4.0.
+directives:
+  - T Test Framework
+concepts:
+  - Provide examples for the T Test Framework.
+  - Ensure that the T Test Framework works.
diff --git a/testsuites/libtests/ttest01/ttest01.scn b/testsuites/libtests/ttest01/ttest01.scn
index 0000000000..05bd1eaa3e
--- /dev/null
+++ b/testsuites/libtests/ttest01/ttest01.scn
@@ -0,0 +1,26 @@
+*** BEGIN OF TEST TTEST 1 ***
+*** TEST VERSION: 5.0.0.286e9354e008b08983e6390a68f8ecc5071de069
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB e0aec65182449a4e22b820e773087636edaf5b32, Newlib 1d35a003f)
+A:ttest01
+S:Platform:RTEMS
+S:Compiler:7.4.0 20181206 (RTEMS 5, RSB e0aec65182449a4e22b820e773087636edaf5b32, Newlib 1d35a003f)
+S:Version:5.0.0.286e9354e008b08983e6390a68f8ecc5071de069
+S:BSP:erc32
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:example
+P:0:0:UI1:test-example.c:5
+F:1:0:UI1:test-example.c:6:test fails
+F:*:0:UI1:test-example.c:8:quiet test fails
+P:2:0:UI1:test-example.c:9
+F:3:0:UI1:test-example.c:10:step test fails
+F:4:0:UI1:test-example.c:11:this is a format string
+E:example:N:5:F:4:D:0.001000
+Z:ttest01:C:1:N:5:F:4:D:0.003000
+*** END OF TEST TTEST 1 ***
2.16.4
