[PATCH 3/3] main_edit.c: Use strncpy() to eliminate potential buffer overflow.
Thu Mar 14 13:50:23 UTC 2019
On Thu, Mar 14, 2019 at 9:22 AM Joel Sherrill <joel at rtems.org> wrote:
>  cpukit/libmisc/shell/main_edit.c | 9 +++++----
>  1 file changed, 5 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_edit.c
> b/cpukit/libmisc/shell/main_edit.c
> index 079e9ff..e43ff68 100644
> --- a/cpukit/libmisc/shell/main_edit.c
> +++ b/cpukit/libmisc/shell/main_edit.c
> @@ -286,7 +286,7 @@ static struct editor *find_editor(struct env *env,
> char *filename) {
>    struct editor *ed = env->current;
>    struct editor *start = ed;
> -  if (!realpath(filename, fn)) strcpy(fn, filename);
> +  if (!realpath(filename, fn)) strncpy(fn, filename, FILENAME_MAX);
>    do {
>      if (strcmp(fn, ed->filename) == 0) return ed;
> @@ -297,7 +297,7 @@ static struct editor *find_editor(struct env *env,
> char *filename) {
>  static int new_file(struct editor *ed, char *filename) {
>    if (*filename) {
> -    strcpy(ed->filename, filename);
> +    strncpy(ed->filename, filename, FILENAME_MAX);
if strlen(filename) > FILENAME_MAX, ed->filename will not be NUL-terminated.
>    } else {
>      sprintf(ed->filename, "Untitled-%d", ++ed->env->untitled);
>      ed->newfile = 1;
Unrelated: why doesn't 'ed->newfile = 1;' happen down the other code path
(when a filename is given)?
> @@ -1752,7 +1752,7 @@ static void read_from_stdin(struct editor *ed) {
>      insert(ed, pos, (unsigned char*) buffer, n);
>      pos += n;
> -  strcpy(ed->filename, "<stdin>");
> +  strncpy(ed->filename, "<stdin>", FILENAME_MAX);
overkill -- "<stdin>" has a fixed known size.
>    ed->newfile = 1;
>    ed->dirty = 0;
> @@ -1775,7 +1775,8 @@ static void save_editor(struct editor *ed) {
>          return;
> -    strcpy(ed->filename, (const char*) ed->env->linebuf);
> +    strncpy(
> +      ed->filename, (const char*) ed->env->linebuf, FILENAME_MAX);
>      ed->newfile = 0;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190314/235072ff/attachment-0002.html>
