rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Mar 16 22:52:36 UTC 2019
On Sat, 16 Mar 2019 at 01:00, Christian Mauderer <list at c-mauderer.de> wrote:
> Am 15.03.19 um 19:20 schrieb Vijay Kumar Banerjee:
> > On Fri, 15 Mar 2019 at 21:47, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
> > > Hello,
> > > I am trying to `./waf install` the libbsd but getting some error,
> > need help
> > > with that. The commands used and the errors are given below ...
> > > configured using: `./waf configure --buildset=buildset/default.ini
> > > --prefix=$HOME/development/rtems/5 --rtems-arch=arm`
> > > configure was successful.
> > > then : `./waf install`
> > > Error ...
> > > Build failed
> > > -> task in 'lex__nsyy' failed with exit status 1 (run with -v to
> > > display more information)
> > > -> task in 'yacc__nsyy' failed with exit status 1 (run with -v to
> > > -> task in 'lex_pcap' failed with exit status 1 (run with -v to
> > display
> > > more information)
> > > -> task in 'yacc_pcap' failed with exit status 1 (run with -v to
> > > -> task in 'objs01' failed with exit status 1 (run with -v to
> display
> > > more information)
> display
> > > more information)
> > > -> task in 'yacc_pfctly' failed with exit status 1 (run with -v to
> > > Thanks
> > > --vijay
> > Hello Vijay,
> > did you try to build before the install? I don't see the call.
> > Normally it's
> > waf configure ...
> > waf
> > waf install
> > If you did that: It seems that some of the lex / yacc files should be
> > regenerated. Did you enable --enable-auto-regen somewhen during an
> > earlier configuration run (not necessary except if you import yacc or
> > lex files)? Did you import some yacc or lex files?
> > I had to install `byacc` package using yum in fedora, then I used the
> > --enable-auto-regen
> > option, that worked.
> > However, it's still not building and I'm seeing a lot of warnings, I
> > think this is because of the
> > files I imported from the freebsd source, maybe they depend on some
> > other headers that
> > I didn't include. Any suggestion on how to debug, if this is the case?
> > Best regards
> > Christian
> Hello Vijay,
> normally you shouldn't need the --enable-auto-regen option. It only
> changes a lot of files that you don't want to change. Especially: If you
> use Fedora (or some other Linux) you get GPL licensed output. We
> normally use FreeBSD for that step and check in the generated files so
> that no user has to use --enable-auto-regen.
> Regarding how to start such a port: Normally it's a good idea to get
> some overview over what's missing. For that you import the files that
> you think are relevant (like you already did). Then you can build with
> `waf -k -j1` which continues even if some files are not compilable (-k
> is for continue, -j1 so that you receive the messages in order). You
> should get a lot of compiler errors during that run.
> Now comes the hard part: You have to analyse the errors and try to find
> out what's the reason for them. If some big part is missing you most
> likely get a lot of similar errors (like "header xy.h not found"). Most
> likely you can identify some groups. With that you can estimate what has
> to be ported besides the files you already imported.
> Identifying these groups is a quite relevant step for planning the
> amount of work for your GSoC proposal. If you are unsure, try to ask on
> the mailing list. You can also post the build output and an assumption
> what groups you estimate to get some feedback.
> Best regards
> Christian
Hi
I figured out that there were some unnecessary imports I was doing and also
some necessary
header files that I'm missing, after adding those most of the warnings
vanished. The error I'm
seeing now is due to a missing '.m' header file. The error looks like this
../../freebsd/sys/arm/ti/am335x/tda19988.c:56:10: fatal error:
rtems/bsd/local/iicbus_if.h: No such file or directory
#include <rtems/bsd/local/iicbus_if.h>
There's an iicbus_if.m file in the freebsd source which is being included as
``#include "iicbus_if.h"``
How to work with the .m files ?
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190317/eee6d637/attachment-0002.html>
