POSIX Compilance- #2966, GSoC Project 2019
Tue Mar 19 17:12:42 UTC 2019
On Tue, Mar 19, 2019 at 10:29 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Mon, Mar 18, 2019 at 4:40 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Sun, Mar 17, 2019 at 2:24 PM Joel Sherrill <joel at rtems.org> wrote:
>> > On Sun, Mar 17, 2019, 12:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> >> I did cloned RTEM source, newlib and rtems-libbsd.
>> >> Kept them in same folder so as to get easy with 'grep' and 'find'.
>> >> $ ls
>> >> newlib-cygwin  rtems  rtems-libbsd
>> >> $ grep -r grantpt ./
>> >> ./newlib-cygwin/winsup/doc/posix.xml:    grantpt
>> >> ./newlib-cygwin/winsup/doc/posix.xml:return -1 and set errno to
>> ENOSYS.  <function>grantpt</function> and
>> >> ./newlib-cygwin/winsup/cygwin/tty.cc:grantpt (int fd)
>> >> ./newlib-cygwin/winsup/cygwin/libc/bsdlib.cc:      grantpt (master);
>> >> ./newlib-cygwin/winsup/cygwin/common.din:grantpt NOSIGFE
>> >> ./newlib-cygwin/winsup/cygwin/include/cygwin/stdlib.h:int grantpt
>> (int);
>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-1997:    *
>> cygwin.din: srandom, ptsname, grantpt, unlockpt - new exports.
>> (grantpt): new
>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2001:    *
>> tty.cc (grantpt): Fix definition.
>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2011:    *
>> tty.cc (grantpt): Check for valid fd.
>> >> ./newlib-cygwin/newlib/ChangeLog-2015:    * libc/include/stdlib.h: add
>> ptsname, grantpt, unlockpt to cygwin
>> >> ./rtems/testsuites/psxtests/Makefile.am:## lib_a_SOURCES +=
>> psxhdrs/stdlib/grantpt.c              See ticket #3645
>> >> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c: *  @brief
>> grantpt() API Conformance Test
>> >> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c:    return_value
>> = grantpt(fildes);
>> >> As I analyzed the output, I find no file that contains implementation
>> of 'grantpt()', means ticket #3645(https://devel.rtems.org/ticket/3645)
>> still needs to be addressed.
>> >> But then how this method is used in rtems testsuites?. (refer last two
>> lines of output for grep command).
>> >> Am I doing something wrong? or I am missing something.
>> > You haven't done anything wrong.
>> > The grantpt() method is in a winsup subdirectory which indicates it is
>> a Cygwin specific implementation.
>> > The psxhdrs test just checks that the prototype us right in the header
>> file.
>> > All said, I don't know if grantpt makes sense on RTEMS or not. That's a
>> different discussion.
>> >> Thanks
>> >> Vaibhav Gupta
>> >> On Fri, Mar 8, 2019 at 5:31 AM Joel Sherrill <joel at rtems.org> wrote:
>> >>> I'm about to head home so not going to dig into each of those but I
>> >>> will point out for GSoC, we need to get you where you can answer
>> >>> these questions yourself.
>> >>> 1) clone the newlib (sourceware.org/newlib) source, RTEMS source, and
>> >>>     rtems-libbsd source. rtems-libbsd is the source for networking
>> APIs.
>> >>> 2) use "grep -r" (recursive grep) and find (ex: find . -name "XXX")
>> to help you
>> >>>     find implementations.
>> >>> For #3676, RTEMS supports aio but aio.h is one of only a handful of
>> POSIX
>> >>> .h files in RTEMS and not in newlib. That's why the Google Code-In
>> student
>> >>> couldn't find it in newlib. Just scanning the cpukit/include, I see 3
>> POSIX .h
>> >>> files which could be moved to newlib. This is worth discussing on
>> devel@
>> >>> For the rest, I think they are still open to be implemented. Now
>> whether the
>> >>> method makes sense or not on RTEMS or requires more infrastructure
>> than
>> >>> a simple method to be added is something to determine on a case by
>> case
>> >>> basis.
>> >>> --joel
>> >>> On Thu, Mar 7, 2019 at 5:51 PM Vaibhav Gupta <
>> vaibhavgupta40 at gmail.com> wrote:
>> >>>> It will be very helpful to know the current status of the following
>> tickets, and if I can choose sub-tasks from them, for GSoC project.
>> >>>> #3676 - Add support for aio.h
>> >>>> #3642 - Add iswalnum(), iswalpha() ... (and 18 others) to <wchar.h>
>> header
>> >>>> #3371 - Add dirfd() and fdopendir() methods in dirent.h
>> >>>> #3656 - Function prototypes for posix_fadvise() and
>> posix_fallocate() missing in <fcntl.h> header file
>> >>>> #3652- Add support for sys/resource.h method - getpriority
>> >>>> #3653 - Add support for sys/resource.h method - getrlimit
>> >>>> #3654 - Add support for sys/resource.h method - setpriority
>> >>>> #3655 - Add support for sys/resource.h method - setrlimit
>> >>>> #3644 - Add support for stdlib.h method - getsubopt
>> >>>> #3645 - Add support for stdlib.h method - grantpt
>> >>>> #3646 - Add support for stdlib.h method - posix_openpt
>> >>>> #3647 - Add support for stdlib.h method - ptsname
>> >>>> #3648 - Add support for stdlib.h method - unlockpt
>> >>>> #3643 - Add support for uchar.h header
>> >>>> #3633 - add getdelim() and getline() to stdio.h
>> >>>> Vaibhav Gupta
>> >>>> On Thu, 7 Mar, 2019, 9:57 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com
>> wrote:
>> >>>>> Hello,
>> >>>>> I was exploring open projects and got very much intrested in the
>> following ticket:
>> >>>>> #2966 - POSIX Compilance : https://devel.rtems.org/ticket/2966
>> >>>>> As on the page, the project is divided into multiple sub-tasks. For
>> many of them I am not able to find their current status and if enough work
>> is left on them to be included as a GSoC project.
>> >>>>> I would like to know the good combinations of sub-tasks which can
>> compile into a good GSoC project under the "POSIX" ticket. I am very much
>> interested to take this project. It would be great if someone mentors this
>> project, I want to discuss further on this.
>> >>>>> Also if there are new any new projects which are not mentioned on
>> open-projects page? That can be taken up as GSoC project, I would love to
>> explore them as well.
>> >>>>> Thankyou
>> >>>>> Vaibhav Gupta
>> I also just wanted to follow-up that for this particular project, you
>> will need to be able to build newlib and produce patches for it. I
>> suggest you do that during the proposal-writing period. Also, make
>> sure your mentor approves all patches that are intended for newlib
>> BEFORE you post to their mailing list. We had some issues in the past
>> when student patches were not in a great shape, and the newlib folks
>> got a little upset about having to do a lot of work that was really
>> the responsibility of an RTEMS Mentor.
> Yes, I have successfully build newlib-cygwin,
> by following steps from blog of Aditya https://adityupa.wordpress.com/
> and as I have created git-patches before, for  RTEMS, so I guess
> I will have no problem creating patch for newlib. I just need to get
> familiar with their code-formatting styles, comment-formatting style,
> commit-formatting styles etc.
Awesome!
Aditya/Gedare.. wouldn't it be nice to get the newlib editing and autoconf
maintenance instructions in the SW Engineering Guide?
--joel
> Thanks
> Vaibhav Gupta
>> Gedare
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190319/6f7ca5da/attachment-0002.html>
