POSIX Compilance- #2966, GSoC Project 2019
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Mar 19 18:08:55 UTC 2019
On Tue, Mar 19, 2019 at 11:34 PM Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> On Tue, 19 Mar 2019, 22:42 Joel Sherrill, <joel at rtems.org> wrote:
>> On Tue, Mar 19, 2019 at 10:29 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> On Mon, Mar 18, 2019 at 4:40 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Sun, Mar 17, 2019 at 2:24 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> > On Sun, Mar 17, 2019, 12:45 PM Vaibhav Gupta <
>>>> vaibhavgupta40 at gmail.com> wrote:
>>>> >> I did cloned RTEM source, newlib and rtems-libbsd.
>>>> >> Kept them in same folder so as to get easy with 'grep' and 'find'.
>>>> >> $ ls
>>>> >> newlib-cygwin rtems rtems-libbsd
>>>> >> $ grep -r grantpt ./
>>>> >> ./newlib-cygwin/winsup/doc/posix.xml: grantpt
>>>> >> ./newlib-cygwin/winsup/doc/posix.xml:return -1 and set errno to
>>>> ENOSYS. <function>grantpt</function> and
>>>> >> ./newlib-cygwin/winsup/cygwin/tty.cc:grantpt (int fd)
>>>> >> ./newlib-cygwin/winsup/cygwin/libc/bsdlib.cc: grantpt (master);
>>>> >> ./newlib-cygwin/winsup/cygwin/common.din:grantpt NOSIGFE
>>>> >> ./newlib-cygwin/winsup/cygwin/include/cygwin/stdlib.h:int grantpt
>>>> (int);
>>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-1997: *
>>>> cygwin.din: srandom, ptsname, grantpt, unlockpt - new exports.
>>>> (grantpt): new
>>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2001: *
>>>> tty.cc (grantpt): Fix definition.
>>>> >> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2011: *
>>>> tty.cc (grantpt): Check for valid fd.
>>>> >> ./newlib-cygwin/newlib/ChangeLog-2015: * libc/include/stdlib.h:
>>>> add ptsname, grantpt, unlockpt to cygwin
>>>> >> ./rtems/testsuites/psxtests/Makefile.am:## lib_a_SOURCES +=
>>>> psxhdrs/stdlib/grantpt.c See ticket #3645
>>>> >> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c: * @brief
>>>> grantpt() API Conformance Test
>>>> return_value = grantpt(fildes);
>>>> >> As I analyzed the output, I find no file that contains
>>>> implementation of 'grantpt()', means ticket #3645(
>>>> https://devel.rtems.org/ticket/3645) still needs to be addressed.
>>>> >> But then how this method is used in rtems testsuites?. (refer last
>>>> two lines of output for grep command).
>>>> >> Am I doing something wrong? or I am missing something.
>>>> > You haven't done anything wrong.
>>>> > The grantpt() method is in a winsup subdirectory which indicates it
>>>> is a Cygwin specific implementation.
>>>> > The psxhdrs test just checks that the prototype us right in the
>>>> header file.
>>>> > All said, I don't know if grantpt makes sense on RTEMS or not. That's
>>>> a different discussion.
>>>> >> Thanks
>>>> >> Vaibhav Gupta
>>>> >> On Fri, Mar 8, 2019 at 5:31 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> >>> I'm about to head home so not going to dig into each of those but I
>>>> >>> will point out for GSoC, we need to get you where you can answer
>>>> >>> these questions yourself.
>>>> >>> 1) clone the newlib (sourceware.org/newlib) source, RTEMS source,
>>>> and
>>>> >>> rtems-libbsd source. rtems-libbsd is the source for networking
>>>> APIs.
>>>> >>> 2) use "grep -r" (recursive grep) and find (ex: find . -name "XXX")
>>>> to help you
>>>> >>> find implementations.
>>>> >>> For #3676, RTEMS supports aio but aio.h is one of only a handful of
>>>> POSIX
>>>> >>> .h files in RTEMS and not in newlib. That's why the Google Code-In
>>>> student
>>>> >>> couldn't find it in newlib. Just scanning the cpukit/include, I see
>>>> 3 POSIX .h
>>>> >>> files which could be moved to newlib. This is worth discussing on
>>>> devel@
>>>> >>> For the rest, I think they are still open to be implemented. Now
>>>> whether the
>>>> >>> method makes sense or not on RTEMS or requires more infrastructure
>>>> than
>>>> >>> a simple method to be added is something to determine on a case by
>>>> case
>>>> >>> basis.
>>>> >>> --joel
>>>> >>> On Thu, Mar 7, 2019 at 5:51 PM Vaibhav Gupta <
>>>> >>>> It will be very helpful to know the current status of the
>>>> following tickets, and if I can choose sub-tasks from them, for GSoC
>>>> project.
>>>> >>>> #3676 - Add support for aio.h
>>>> >>>> #3642 - Add iswalnum(), iswalpha() ... (and 18 others) to
>>>> <wchar.h> header
>>>> >>>> #3371 - Add dirfd() and fdopendir() methods in dirent.h
>>>> >>>> #3656 - Function prototypes for posix_fadvise() and
>>>> posix_fallocate() missing in <fcntl.h> header file
>>>> >>>> #3652- Add support for sys/resource.h method - getpriority
>>>> >>>> #3653 - Add support for sys/resource.h method - getrlimit
>>>> >>>> #3654 - Add support for sys/resource.h method - setpriority
>>>> >>>> #3655 - Add support for sys/resource.h method - setrlimit
>>>> >>>> #3644 - Add support for stdlib.h method - getsubopt
>>>> >>>> #3645 - Add support for stdlib.h method - grantpt
>>>> >>>> #3646 - Add support for stdlib.h method - posix_openpt
>>>> >>>> #3647 - Add support for stdlib.h method - ptsname
>>>> >>>> #3648 - Add support for stdlib.h method - unlockpt
>>>> >>>> #3643 - Add support for uchar.h header
>>>> >>>> #3633 - add getdelim() and getline() to stdio.h
>>>> >>>> Vaibhav Gupta
>>>> >>>> On Thu, 7 Mar, 2019, 9:57 PM Vaibhav Gupta <
>>>> vaibhavgupta40 at gmail.com wrote:
>>>> >>>>> Hello,
>>>> >>>>> I was exploring open projects and got very much intrested in the
>>>> following ticket:
>>>> >>>>> #2966 - POSIX Compilance : https://devel.rtems.org/ticket/2966
>>>> >>>>> As on the page, the project is divided into multiple sub-tasks.
>>>> For many of them I am not able to find their current status and if enough
>>>> work is left on them to be included as a GSoC project.
>>>> >>>>> I would like to know the good combinations of sub-tasks which can
>>>> compile into a good GSoC project under the "POSIX" ticket. I am very much
>>>> interested to take this project. It would be great if someone mentors this
>>>> project, I want to discuss further on this.
>>>> >>>>> Also if there are new any new projects which are not mentioned on
>>>> open-projects page? That can be taken up as GSoC project, I would love to
>>>> explore them as well.
>>>> >>>>> Thankyou
>>>> >>>>> Vaibhav Gupta
>>>> I also just wanted to follow-up that for this particular project, you
>>>> will need to be able to build newlib and produce patches for it. I
>>>> suggest you do that during the proposal-writing period. Also, make
>>>> sure your mentor approves all patches that are intended for newlib
>>>> BEFORE you post to their mailing list. We had some issues in the past
>>>> when student patches were not in a great shape, and the newlib folks
>>>> got a little upset about having to do a lot of work that was really
>>>> the responsibility of an RTEMS Mentor.
>>> Yes, I have successfully build newlib-cygwin,
>>> by following steps from blog of Aditya https://adityupa.wordpress.com/
>>> and as I have created git-patches before, for RTEMS, so I guess
>>> I will have no problem creating patch for newlib. I just need to get
>>> familiar with their code-formatting styles, comment-formatting style,
>>> commit-formatting styles etc.
>> Awesome!
>> Aditya/Gedare.. wouldn't it be nice to get the newlib editing and autoconf
>> maintenance instructions in the SW Engineering Guide?
> Yes !! That would be helpful for others.
> I am just looking through the previous mail from Corrinna and other
> maintainers. I will update my blog with what is required to send a patch to
> newlib and autoconf version related issues.
I would like to contribute with that autoconf version thing.
> Last time, I was also facing the same issues with autoconf version and
> then I had built that manually.
>> --joel
>>> Thanks
>>> Vaibhav Gupta
>>>> Gedare
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190319/004f7ad2/attachment-0002.html>
