How can I use the covoar tool?
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Mar 20 15:50:19 UTC 2019
On Wed, 20 Mar 2019 at 21:11, Sebastian Huber <
> Hello,
> thanks for your hints.
> On 20/03/2019 16:31, Vijay Kumar Banerjee wrote:
> > On Wed, 20 Mar 2019 at 17:46, Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > Hello,
> > the RTEMS project has a covoar tool:
> > https://git.rtems.org/rtems-tools/tree/tester/covoar
> > I have seen some reports generated by it, but I never used it
> > myself. I
> > have trouble to find out how it works. There is nothing in the
> > documentation:
> > cd rtems-docs
> > grep -ri covoar .
> > There is some documentation available here:
> https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage
> > If I invoke the rtems-test like this in the erc32 BSP build
> > directory, I
> > get an error:
> > rtems-test --rtems-bsp=erc32-sis --rtems-tools=/build/rtems/5
> > --coverage
> > --target=sparc-rtems5 .
> > RTEMS Testing - Tester, 5.0.not_released
> > Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=erc32-sis
> > --rtems-tools=/build/rtems/5 --coverage --target=sparc-rtems5 .
> > Python: 3.6.5 (default, Mar 31 2018, 19:45:04) [GCC]
> > Host: Linux-4.12.14-lp150.12.48-default-x86_64-with-glibc2.3.4 (Linux
> > huber-nb-linux.suse 4.12.14-lp150.12.48-default #1 SMP Tue Feb 12
> > 14:01:48 UTC 2019 (268f014) x86_64 x86_64)
> > Traceback (most recent call last):
> > File "/build/rtems/5/share/rtems/tester/rt/cmd-test.py", line
> > 42, in
> > <module>
> > test.run(sys.argv[1:], command_path = base)
> > File "/build/rtems/5/share/rtems/tester/rt/test.py", line 300,
> > in run
> > trace = cov_trace)
> > File "/build/rtems/5/share/rtems/tester/rt/coverage.py", line
> > 363, in
> > __init__
> > self.target = self.macros['target']
> > File "/build/rtems/5/share/rtems/rtemstoolkit/macros.py", line
> > 181,
> > in __getitem__
> > raise IndexError('key: %s' % (key))
> > IndexError: key: target
> > Hi,
> > The covoar needs the .cov files to run which is supposed to be
> > generated by a command like
> > this
> > $HOME/development/rtems/5/bin/sparc-rtems5-sis -nouartrx -r -tlim 600
> > s -cov
> $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples/hello.exe
> > But this runs into a segmentation fault. If my command is right
> > (Please correct me if it isn't)
> > then I think it's because the sis coverage is not supported for erc32. :/
> Yes, I get also a segmentation fault. For the leon3 it seems to work:
> sparc-rtems5-sis -leon3 -nouartrx -r -tlim 200 s -cov
> ./sparc-rtems5/c/leon3/testsuites/samples/hello.exe
> SIS - SPARC/RISCV instruction simulator 2.13, copyright Jiri Gaisler
> 2019
> Bug-reports to jiri at gaisler.se
> LEON3 emulation enabled, 1 cpus online, delta 50 clocks
> *** BEGIN OF TEST HELLO WORLD ***
> *** TEST VERSION: 5.0.0.45e418f922af81c9cb8d485c789ba73c95bda813
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
> c41b9d0df7e5b4a5056ca50c2534380a44e92769, Newlib 3e24fbf6f)
> Hello World
> *** END OF TEST HELLO WORLD ***
> cpu 0 in error mode (tt = 0x80)
> 165222 400103e0 91d02000 ta 0
> saved code coverage to
> ./sparc-rtems5/c/leon3/testsuites/samples/hello.exe.cov
> > about rtems-test,
> > I have attached a patch that adds erc32-sis-cov.ini, this will fix the
> > KeyError you're seeing,
> > but it will return with error 10 as it's trying to run the above
> > command. If you run rtems-test
> > with `--no-clean` and `--coverage` options, you'll have a
> > erc32-sis-symbols.ini file (and the .cov
> > files, when they're supported, like in leon3), which can be used to
> > run covoar directly like
> > below ( but this won't run now as we don't have .cov file )
> I tried to use leon3-sis-cov and I get:
> rtems-test --rtems-bsp=leon3-sis-cov --rtems-tools=/build/rtems/5
> --coverage .
> Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=leon3-sis-cov
> --rtems-tools=/build/rtems/5 --coverage .
> File "/build/rtems/5/share/rtems/tester/rt/cmd-test.py", line 42, in
> <module>
> File "/build/rtems/5/share/rtems/tester/rt/test.py", line 300, in run
> trace = cov_trace)
> File "/build/rtems/5/share/rtems/tester/rt/coverage.py", line 363, in
> __init__
> File "/build/rtems/5/share/rtems/rtemstoolkit/macros.py", line 181,
> in __getitem__
> this works fine for me ...
$HOME/development/rtems/rtems-tools/tester/rtems-test
--rtems-tools=$HOME/development/rtems/5 --rtems-bsp=leon3-qemu-cov
--coverage --log=leon3-test.log
/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe
The leon3-sis-cov was added recently, so you might need to rebase to
current master. If
it still gives error with python 3. Then you can try `export
RTEMS_PYTHON_OVERRIDE='python2'`
to force it to use python2.
> > covoar -S
> $HOME/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/erc32-sis-symbols.ini
> > -O coverage
> -E$HOME/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
> > -p RTEMS-5 sparc-rtems5/c/erc32/testsuites/samples/hello.exe
> Do I have to call rtems-test first and then covoar or is it called by
> rtems-test itself?
> The rtems-test automatically calls covoar, there's no need to call covoar
separately unless
for debugging purpose.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190320/641d98f6/attachment-0002.html>
