Sub-Tickets selected for POSIX Compilance GSoc Project
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Mar 21 14:04:30 UTC 2019
On Thu, Mar 21, 2019 at 6:10 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 21, 2019, 2:43 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello,
>> After series of discussions and exploring things, I got Idea about
>> various things in this project.
>> I have got Interested in following sub-tickets:
>> -- #2970 - Add ftw.h to Newlib : https://devel.rtems.org/ticket/2970
>> -- #2971 - Add fenv.h to Newlib : https://devel.rtems.org/ticket/2971
>> -- #2972 - Add ndbm.h support : https://devel.rtems.org/ticket/2972
>> -- #3639 - Add fmtmsg.h to Newlib : https://devel.rtems.org/ticket/3639
>> -- #3650 - Add sys/ipc.h to Newlib : https://devel.rtems.org/ticket/3650
> This should be low priority.
> -- #2973 - Enable getdate() in Newlib :
>> https://devel.rtems.org/ticket/2973
>> -- #2974 - Enable search.h functionality in Newlib :
>> https://devel.rtems.org/ticket/2974
>> -- Requrement from FACE GPP :
>> - -- math functions:
>> - fpclassify()
>> - isfinite()
>> - isgreater()
>> - isgreaterequal()
>> - isless()
>> - islessequal()
>> - islessgreater()
>> - isnormal()
>> - isunordered()
>> - nexttowardf()
>> - signbit()
> This is fenv.h and IMO is higher priority for architectures where you are
> porting existing implementations.
Yah, so during my SoC time I will start with them first.
I guess I may find them on FreeBSD, had a little search on net.
Will get deeper in the topic once the sub-tasks are confirmed,
as for now I am going through tickets for POSIX Compliance.
>> - -- pselect() from <sys/select.h>
>> - -- sockatmark() from <sys/socket.h>
>> Sebastian.. are these not in the new tcpip stack?
> And agree with Sebastian on the *at methods.
That's great. I am ready to work on them.
>> - -- confstr() from <unistd.h>
>> - -- spawn function:
>> - posix_spawn()
>> - posix_spawn_file_actions_addclose()
>> - posix_spawn_file_actions_adddup2()
>> - posix_spawn_file_actions_addopen()
>> - posix_spawn_file_actions_destroy()
>> - posix_spawn_file_actions_init()
>> - posix_spawnattr_destroy()
>> - posix_spawnattr_getflags()
>> - posix_spawnattr_getpgroup()
>> - posix_spawnattr_getschedparam()
>> - posix_spawnattr_getschedpolicy()
>> - posix_spawnattr_getsigdefault()
>> - posix_spawnattr_getsigmask()
>> - posix_spawnattr_init()
>> - posix_spawnattr_setflags()
>> - posix_spawnattr_setpgroup()
>> - posix_spawnattr_setschedparam()
>> - posix_spawnattr_setschedpolicy()
>> - posix_spawnattr_setsigdefault()
>> - posix_spawnattr_setsigmask()
>> - posix_spawnp(
>> Spawn is a safer alternative to fork and exec. This requires
> multi-process support and thus these are not implementable on RTEMS.
Yah, i had this query in my mind, but then they were also not tagged as
POSIX_MULTI_PROCESS in FACE Technical Standards 3.0
and as you said about multi-process functions to be optional, i was not
able to conclude about them.
So I will leave it.
> If there is an existing ticket, it needs to state this.
>> If they all compile into a good GSoC project, I would like to start
>> writing a draft proposal.
>> Thanks
>> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190321/b01537d4/attachment-0002.html>
