RTEMS Requirement Management Tools
Fri Mar 22 20:17:22 UTC 2019
On Fri, Mar 22, 2019 at 8:03 AM Sebastian Huber <
> On 21/03/2019 14:32, Joel Sherrill wrote:
> > 5. Is it possible to have custom fields? I worked on a project where
> > requirements were
> > tagged with project phase and HW/SW. Alternatively, can we add
> > comments to the YAML
> > files. Or who cares since the author information is in git.
> According to the Doorstep documentation:
> https://doorstop.readthedocs.io/en/latest/reference/items/
> "Extended attributes
> In addition to the standard attributes, Doorstop will allow any number
> of custom attributes (key-value pairs) in the YAML file. The extended
> attributes will not be part of a published document, but they can be
> queried by a 3rd party application through the REST interface or the
> Python API.
> Example:
> In this example, an extended attribute invented-by is added to the item.
> invented-by: some.guy at email.com"
> Use of a standard format such as YAML is nice since it enables us to
> read these requirements files quite easily.
This is awesome! Chris and I discussed that it would be desirable to
generate
our requirement documents in Rest. If this is implemented, then that tool
could
know the extended attributes.
> > Is the documentation and/or tutorial sufficient to get us started?
> > Whatever tool is adopted,
> > common tasks will have to be documented like we do with git use.
> Similar to the Git overview in
> https://docs.rtems.org/branches/master/eng/vc-authors.html
> we need something similar for the requirements tool.
+1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190322/aab7c48e/attachment-0002.html>
