[PATCH] Fully disabled seemingly unsupported zynq_uart_set_attributes handler
Wed Mar 27 18:28:40 UTC 2019
On Wed, Mar 27, 2019 at 1:10 AM Sebastian Huber <
> On 26/03/2019 15:17, Lou Woods wrote:
> > From: Lou Woods <Lou.Woods at OARCorp.com>
> >   bsps/arm/xilinx-zynq/console/zynq-uart.c | 16 +++++++++++-----
> >   1 file changed, 11 insertions(+), 5 deletions(-)
> > diff --git a/bsps/arm/xilinx-zynq/console/zynq-uart.c
> b/bsps/arm/xilinx-zynq/console/zynq-uart.c
> > index fa91f3f..9c21f6f 100644
> > --- a/bsps/arm/xilinx-zynq/console/zynq-uart.c
> > +++ b/bsps/arm/xilinx-zynq/console/zynq-uart.c
> > @@ -262,12 +262,16 @@ static void zynq_uart_write_support(
> >   #endif
> > + * Disable this because the initialization is done by code generated
> > + * by the Xilinx code generator.
> The main purpose of the set attributes function is to apply the settings
> specified by the user via the Termios interface. Returning false just
> indicates that this function is not implemented. If you want to hide
> this fact from the user, then you can simply return true ...
We discussed this alternative with Chris and this was the end result.
git blame shows that Chris added the if 0 and then you added the return
false
which broke the callers. From that point forward, no interactive test ran
successfully.
> > +#if 0
> >   static bool zynq_uart_set_attributes(
> >     rtems_termios_device_context *context,
> >     const struct termios *term
> > -#if 0
> >     volatile zynq_uart *regs = zynq_uart_get_regs(minor);
> >     uint32_t brgr = 0;
> >     uint32_t bauddiv = 0;
> > @@ -283,14 +287,16 @@ static bool zynq_uart_set_attributes(
> >     regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
> >     return true;
> > -#else
> > -  return false;
> ... here.
> > -#endif
> > +#endif
> >   const rtems_termios_device_handler zynq_uart_handler = {
> >     .first_open = zynq_uart_first_open,
> > -  .set_attributes = zynq_uart_set_attributes,
> > +#if 0
> > +  .set_attributes = zynq_uart_set_attributes;
> > +#else
> > +  .set_attributes = NULL,
> > +#endif
> >     .write = zynq_uart_write_support,
> >   #ifdef ZYNQ_CONSOLE_USE_INTERRUPTS
> >     .last_close = zynq_uart_last_close,
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190327/c478470c/attachment-0002.html>
