[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for nl_types.h
Jacob Shin jacobshin313 at gmail.com
Sat May 4 02:52:05 UTC 2019
 bootstrap                                     | 326 ------------------
 testsuites/psxtests/Makefile.am               |   3 +
 .../psxtests/psxhdrs/nl_types/catclose.c      |  49 +++
 .../psxtests/psxhdrs/nl_types/catgets.c       |  53 +++
 .../psxtests/psxhdrs/nl_types/catopen.c       |  51 +++
 5 files changed, 156 insertions(+), 326 deletions(-)
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catclose.c
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catgets.c
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catopen.c
diff --git a/bootstrap b/bootstrap
index 7ed592d435..e69de29bb2 100755
--- a/bootstrap
+++ b/bootstrap
@@ -1,326 +0,0 @@
-#!/bin/sh
-# helps bootstrapping, when checked out from CVS
-# requires GNU autoconf and GNU automake
-# this is not meant to be exported outside the source tree
-# NOTE: Inspired by libtool's autogen script
-# to be run from the toplevel directory of RTEMS'
-# source tree
-progname=`basename $0`
-top_srcdir=`dirname $0`
-LC_ALL=C
-export LC_ALL
-verbose=""
-quiet="false"
-mode="autoreconf"
-force=0
-usage()
-  echo
-  echo "usage: ${progname} [-c|-h|-H] [-q][-v]"
-  echo
-  echo "options:"
-  echo "	-c .. clean, remove all aclocal/autoconf/automake generated files"
-  echo "	-h .. display this message and exit"
-  echo "	-H .. regenerate headers.am files"
-  echo "	-q .. quiet, don't display directories"
-  echo "	-v .. verbose, pass -v to autotools"
-  echo
-  exit 1
-if test ! -f $top_srcdir/aclocal/version.m4; then
-  echo "${progname}:"
-  echo "	Installation problem: Can't find file aclocal/version.m4"
-  exit 1
-fi
-while test $# -gt 0; do
-case $1 in
--h|--he|--hel|--help)
-  usage ;;
--q|--qu|--qui|--quie|--quiet)
-  quiet="true"
-  shift;;
--v|--ve|--ver|--verb|--verbo|--verbos|--verbose)
-  verbose="-v"
-  shift;;
--c|--cl|--cle|--clea|--clean)
-  mode="clean"
-  shift;;
--f|--fo|--for|--forc|--force)
-  force=`expr $force + 1`
-  shift;;
--H|--headers)
-  mode="headers"
-  shift;;
--r|--re|--rec|--reco|--recon|--reconf)
-  mode="autoreconf"
-  shift;;
--g|--ge|--gen|--gene|--gener|--genera|--generat|--generate)
-  mode="generate"
-  shift;;
--*) echo "unknown option $1"
-  usage ;;
-*) echo "invalid parameter $1"
-  usage ;;
-esac
-done
-case $mode in
-headers)
-  if test "." != "$top_srcdir"; then
-    echo "To generate the headers.am you must call the script via \"./$progname -H\""
-    exit 1
-  fi
-  base="$PWD"
-  # Generate cpukit/header-dirs.am
-  tmp="$base/cpukit/header-dirs.am.new"
-  hdr_dirs=`for i in cpukit/include cpukit/libnetworking cpukit/score/cpu/*/include ; do
-    cd "$i"
-    find -mindepth 1 -type d
-    cd "$base"
-  done | sort -u | sed 's%^\./%%'`
-  echo '## This file was generated by "./boostrap -H".' > "$tmp"
-  echo 'include_HEADERS =' >> "$tmp"
-  for dir in $hdr_dirs ; do
-    am_dir=`echo $dir | sed 's%[/-]%_%g'`
-    echo "include_${am_dir}dir = \$(includedir)/$dir" >> "$tmp"
-    echo "include_${am_dir}_HEADERS =" >> "$tmp"
-  done
-  diff -q "$tmp" "cpukit/header-dirs.am" || mv "$tmp" "cpukit/header-dirs.am"
-  rm -f "$tmp"
-  # Generate cpukit/*/headers.am
-  tmp="$base/headers.am.new"
-  cpukit="$base/cpukit"
-  cd "$cpukit"
-  for inc in include score/cpu/*/include ; do
-    hdr=`dirname $inc`
-    am_dir=""
-    cd $inc
-    for b in `find -type d | sort` ; do
-      for j in `find $b -mindepth 1 -maxdepth 1 -name '*.h' | sed 's%^\.%%' | sed 's%^/%%' | sort` ; do
-        dir=`dirname $j`
-        if test x$dir != x. ; then
-          am_dir="_$am_dir"
-        else
-          am_dir=""
-        fi
-        echo "include${am_dir}_HEADERS += $inc/$j" >> "$tmp"
-      done
-    done
-    cd "$cpukit"
-    diff -q "$tmp" "${hdr}/headers.am" || mv "$tmp" "${hdr}/headers.am"
-  done
-  rm -f "$tmp"
-  cd "$base"
-  # Generate bsps/*/headers.am
-  for i in bsps/include bsps/*/include bsps/*/*/include ; do
-    dir=""
-    am_dir=""
-    case $i in
-      bsps/*/*/include)
-        hdr="../"
-        inc="../../../../../../$i/"
-      bsps/*/include)
-        hdr="../"
-        inc="../../../../../$i/"
-      bsps/include)
-        hdr="../"
-        inc="../../$i/"
-        hdr=""
-        inc=""
-    esac
-    cd $i
-      for j in `find $b -mindepth 1 -maxdepth 1 -name '*.h' -or -name '*.inc' | sed 's%^\.%%' | sed 's%^/%%' | sort` ; do
-        d=`dirname $j`
-        if test x$d != x$dir ; then
-          dir=$d
-          if test x$d != x. ; then
-            am_dir="_$am_dir"
-            printf "\ninclude%sdir = \$(includedir)/$dir\n" "$am_dir" >> "$tmp"
-          else
-            am_dir=""
-            echo "" >> "$tmp"
-          fi
-          echo "include${am_dir}_HEADERS =" >> "$tmp"
-        fi
-        echo "include${am_dir}_HEADERS += $inc$j" >> "$tmp"
-        if test $j = bsp.h ; then
-          echo "include_HEADERS += include/bspopts.h" >> "$tmp"
-        fi
-      done
-    done
-    cd "$base"
-    diff -q "$tmp" "$i/${hdr}headers.am" || mv "$tmp" "$i/${hdr}headers.am"
-  done
-  rm -f "$tmp"
-generate)
-  AUTOCONF=${AUTOCONF-autoconf}
-  if test -z "$AUTOCONF"; then
-    echo "You must have autoconf installed to run $program"
-    exit 1
-  fi
-  AUTOHEADER=${AUTOHEADER-autoheader}
-  if test -z "$AUTOHEADER"; then
-    exit 1
-  fi
-  AUTOMAKE=${AUTOMAKE-automake}
-  if test -z "$AUTOMAKE"; then
-    echo "You must have automake installed to run $program"
-    exit 1
-  fi
-  ACLOCAL=${ACLOCAL-aclocal}
-  if test -z "$ACLOCAL"; then
-    exit 1
-  fi
-  case $top_srcdir in
-  /* ) aclocal_dir=$top_srcdir
-  *) aclocal_dir=`pwd`/$top_srcdir
-  esac
-  confs=`find . \( -name 'configure.in' -o -name 'configure.ac' \) -print`
-  for i in $confs; do
-  dir=`dirname $i`
-  configure=`basename $i`
-  ( test "$quiet" = "true" || echo "$dir"
-    cd $dir
-    pat="s,\$(RTEMS_TOPdir),${aclocal_dir},g"
-    aclocal_args=`grep '^[ ]*ACLOCAL_AMFLAGS' Makefile.am | \
-      sed -e 's%.*ACLOCAL_AMFLAGS.*\=[ ]*%%g' -e $pat `
-    test "$verbose" = "-v" && echo "${ACLOCAL} $aclocal_args"
-    ${ACLOCAL} $aclocal_args
-    test -n "`grep CONFIG_HEADER ${configure}`" && ${AUTOHEADER} \
-      && test "$verbose" = "-v" && echo "${AUTOHEADER}"
-    test -n "`grep RTEMS_BSP_CONFIGURE ${configure}`" && ${AUTOHEADER} \
-    test -f Makefile.am && ${AUTOMAKE} -a -c $verbose
-    ${AUTOCONF}
-    test -f Makefile.am && test -n "`grep 'stamp-h\.in' Makefile.in`" \
-      && echo timestamp > stamp-h.in
-  done
-autoreconf)
-  AUTORECONF=${AUTORECONF-autoreconf}
-  if test -z "$AUTORECONF"; then
-    echo "You must have autoreconf installed to run $program"
-    exit 1
-  fi
-  confs=`find . -name 'configure.ac' -print`
-  dir=`dirname $i`
-    cd $dir
-    ${AUTORECONF} -i --no-recursive $verbose
-  done
-clean)
-  test "$quiet" = "true" || echo "removing automake generated Makefile.in files"
-  files=`find . -name 'Makefile.am' -print | sed -e 's%\.am%\.in%g'`
-  for i in $files; do
-    if test -f $i; then
-      rm -f $i
-      test "$verbose" = "-v" && echo "$i"
-    fi
-  done
-  test "$quiet" = "true" || echo "removing configure files"
-  files=`find . -name 'configure' -print`
-      rm -f $i
-    fi
-  done
-  if test $force -gt 0; then
-    needles=""
-    if test $force -gt 1; then
-      # Manually maintained
-      needles="$needles config.sub"
-      needles="$needles config.guess"
-    fi
-      # Inherited from automake
-      needles="$needles compile"
-      needles="$needles depcomp"
-      needles="$needles install-sh"
-      needles="$needles missing"
-      needles="$needles mdate-sh"
-    fi
-    for j in $needles; do
-      files=`find . -name "$j" -print`
-          rm -f $i
-        fi
-      done
-    done
-  fi
-  test "$quiet" = "true" || echo "removing aclocal.m4 files"
-  files=`find . -name 'aclocal.m4' -print`
-  test "$verbose" = "-v" && test -n "$files" && echo "$files"
-      rm -f $i
-    fi
-  done
-  find . -name '*~' -print | xargs rm -f
-  find . -name 'bspopts.h.in' -print | xargs rm -f
-  find . -name '*.orig' -print | xargs rm -f
-  find . -name '*.rej' -print | xargs rm -f
-  find . -name 'config.status' -print | xargs rm -f
-  find . -name 'config.log' -print | xargs rm -f
-  find . -name 'config.cache' -print | xargs rm -f
-  find . -name 'Makefile' -print | xargs rm -f
-  find . -name '.deps' -print | xargs rm -rf
-  find . -name '.libs' -print | xargs rm -rf
-  find . -name 'stamp-h.in' | xargs rm -rf
-  find . -name 'autom4te*.cache' | xargs rm -rf
-esac
-exit 0
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 749258cc0c..71f076ba1d 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1832,6 +1832,9 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
 ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
 ## lib_a_SOURCES += psxhdrs/monetary/strfmon.c
 ## lib_a_SOURCES += psxhdrs/monetary/strfmon_l.c
+## lib_a_SOURCES += psxhdrs/nl_types/catclose.c
+## lib_a_SOURCES += psxhdrs/nl_types/catopen.c
+## lib_a_SOURCES += psxhdrs/nl_types/catgets.c
 ## Specific issues that tickets are tracking
 ## lib_a_SOURCES += psxhdrs/dirent/dirfd.c               See ticket #3371
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catclose.c b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
new file mode 100755
index 0000000000..72e0206580
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
@@ -0,0 +1,49 @@
+ *  @file
+ *  @brief catclose() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <nl_types.h>
+int test( void );
+int test( void )
+  nl_catd catd = (nl_catd) 0;
+  int result;
+  result = catclose(catd);
+  return result;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catgets.c b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
index 0000000000..bc4bebd8c8
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
@@ -0,0 +1,53 @@
+ *  @file
+ *  @brief catgets() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+  char *ptr;
+  int set_id = 0;
+  int msg_id = 0;
+  char *s = "message";
+  ptr = catgets(catd, set_id, msg_id, s);
+  (void) ptr;
+  return 0;
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catopen.c b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
index 0000000000..d73d93b34d
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
@@ -0,0 +1,51 @@
+ *  @file
+ *  @brief catopen() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+  char *name = "/";
+  int oflag = 0;
+  nl_catd ptr;
+  ptr = catopen(name, oflag);
+  (void) ptr;
+  return 0;
2.17.1
