[PATCH] [PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for nl_types.h
Jacob Shin jacobshin313 at gmail.com
Sat May 4 21:11:44 UTC 2019
This is just an updated patch since the one before deleted the bootstrap file for some reason.
 testsuites/psxtests/Makefile.am               |  3 ++
 .../psxtests/psxhdrs/nl_types/catclose.c      | 49 +++++++++++++++++
 .../psxtests/psxhdrs/nl_types/catgets.c       | 53 +++++++++++++++++++
 .../psxtests/psxhdrs/nl_types/catopen.c       | 51 ++++++++++++++++++
 4 files changed, 156 insertions(+)
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catclose.c
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catgets.c
 create mode 100755 testsuites/psxtests/psxhdrs/nl_types/catopen.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 749258cc0c..e1e5a0fd67 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1832,6 +1832,9 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
 ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
 ## lib_a_SOURCES += psxhdrs/monetary/strfmon.c
 ## lib_a_SOURCES += psxhdrs/monetary/strfmon_l.c
+## lib_a_SOURCES += psxhdrs/nl_types/catclose.c
+## lib_a_SOURCES += psxhdrs/nl_types/catgets.c
+## lib_a_SOURCES += psxhdrs/nl_types/catopen.c
 ## Specific issues that tickets are tracking
 ## lib_a_SOURCES += psxhdrs/dirent/dirfd.c               See ticket #3371
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catclose.c b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
new file mode 100755
index 0000000000..72e0206580
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
@@ -0,0 +1,49 @@
+ *  @file
+ *  @brief catclose() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <nl_types.h>
+int test( void );
+int test( void )
+  nl_catd catd = (nl_catd) 0;
+  int result;
+  result = catclose(catd);
+  return result;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catgets.c b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
index 0000000000..bc4bebd8c8
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
@@ -0,0 +1,53 @@
+ *  @file
+ *  @brief catgets() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+  char *ptr;
+  int set_id = 0;
+  int msg_id = 0;
+  char *s = "message";
+  ptr = catgets(catd, set_id, msg_id, s);
+  (void) ptr;
+  return 0;
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catopen.c b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
index 0000000000..d73d93b34d
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
@@ -0,0 +1,51 @@
+ *  @file
+ *  @brief catopen() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+  char *name = "/";
+  int oflag = 0;
+  nl_catd ptr;
+  ptr = catopen(name, oflag);
+  (void) ptr;
+  return 0;
2.17.1
