[PATCH 2/2] rcmd.c: Removed references to unsupported functions
Mon May 6 05:02:23 UTC 2019
On 05/05/2019 03:00, Chris Johns wrote:
> On 5/5/19 12:21 am, Joel Sherrill wrote:
>> Sorry for missing that it actually was referenced
>> Rcmd can and should work. Rcmdsh will not ever and should be removed
>> from libbsd.
>> Does rcmd need testing? It clearly had no test since it wouldn't have
>> linked.
> Yes that would be great. Testing libbsd is a complicated.
If it is used by applications it should be tested, otherwise we should
remove it from the build to make it a little faster and reduce the
maintenance costs of libbsd.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
