[PATCH 2/2] rcmd.c: Removed references to unsupported functions
dufault at hda.com
dufault at hda.com
Mon May 6 13:48:48 UTC 2019
> On May 6, 2019, at 01:02 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 05/05/2019 03:00, Chris Johns wrote:
>> On 5/5/19 12:21 am, Joel Sherrill wrote:
>>> Sorry for missing that it actually was referenced
>>> Rcmd can and should work. Rcmdsh will not ever and should be removed from libbsd.
>>> Does rcmd need testing? It clearly had no test since it wouldn't have linked.
>> Yes that would be great. Testing libbsd is a complicated.
> If it is used by applications it should be tested, otherwise we should remove it from the build to make it a little faster and reduce the maintenance costs of libbsd.
It is used. The use may be removed (this is a port from vxWorks) but as part of a baseline it is used.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190506/5081e746/attachment.html>
