[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for termios.h
Jacob Shin
jacobshin313 at gmail.com
Mon May 6 19:01:44 UTC 2019
testsuites/psxtests/Makefile.am | 11 ++++
.../psxtests/psxhdrs/termios/cfgetispeed.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/cfgetospeed.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/cfsetispeed.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/cfsetospeed.c | 50 ++++++++++++++++++
testsuites/psxtests/psxhdrs/termios/tcdrain.c | 49 ++++++++++++++++++
testsuites/psxtests/psxhdrs/termios/tcflow.c | 50 ++++++++++++++++++
testsuites/psxtests/psxhdrs/termios/tcflush.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/tcgetattr.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/tcgetsid.c | 49 ++++++++++++++++++
.../psxtests/psxhdrs/termios/tcsendbreak.c | 50 ++++++++++++++++++
.../psxtests/psxhdrs/termios/tcsetattr.c | 51 +++++++++++++++++++
12 files changed, 560 insertions(+)
mode change 100644 => 100755 testsuites/psxtests/Makefile.am
create mode 100755 testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcdrain.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcflow.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcflush.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcgetattr.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcgetsid.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
create mode 100755 testsuites/psxtests/psxhdrs/termios/tcsetattr.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
old mode 100644
new mode 100755
index 749258cc0c..e7be09a0e9
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1832,6 +1832,17 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
## lib_a_SOURCES += psxhdrs/monetary/strfmon.c
## lib_a_SOURCES += psxhdrs/monetary/strfmon_l.c
+## lib_a_SOURCES += psxhdrs/termios/cfgetispeed.c
+## lib_a_SOURCES += psxhdrs/termios/cfsetispeed.c
+## lib_a_SOURCES += psxhdrs/termios/tcdrain.c
+## lib_a_SOURCES += psxhdrs/termios/tcflush.c
+## lib_a_SOURCES += psxhdrs/termios/tcgetsid.c
+## lib_a_SOURCES += psxhdrs/termios/tcsetattr.c
+## lib_a_SOURCES += psxhdrs/termios/cfgetospeed.c
+## lib_a_SOURCES += psxhdrs/termios/cfsetospeed.c
+## lib_a_SOURCES += psxhdrs/termios/tcflow.c
+## lib_a_SOURCES += psxhdrs/termios/tcgetattr.c
+## lib_a_SOURCES += psxhdrs/termios/tcsendbreak.c
## Specific issues that tickets are tracking
## lib_a_SOURCES += psxhdrs/dirent/dirfd.c See ticket #3371
diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
new file mode 100755
index 0000000000..4b2b88bc6d
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief cfgetispeed() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <termios.h>
+int test( void );
+int test( void )
+ struct termios term;
+ speed_t rate;
+ rate = cfgetispeed(&term);
+ (void) rate;
+ return 0;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
index 0000000000..4c55229645
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief cfgetospeed() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ speed_t rate;
+ rate = cfgetospeed(&term);
+ (void) rate;
+ return 0;
diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
index 0000000000..3af199c5e6
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief cfsetispeed() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ speed_t speed = B0;
+ result = cfsetispeed(&term, speed);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
index 0000000000..4f2707ef6e
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief cfsetospeed() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ result = cfsetospeed(&term, speed);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcdrain.c b/testsuites/psxtests/psxhdrs/termios/tcdrain.c
index 0000000000..1de8862f65
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcdrain.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief tcdrain() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ result = tcdrain(fildes);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcflow.c b/testsuites/psxtests/psxhdrs/termios/tcflow.c
index 0000000000..5b7d1dab39
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcflow.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief tcflow() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ int action = TCOOFF;
+ result = tcflow(fildes, action);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcflush.c b/testsuites/psxtests/psxhdrs/termios/tcflush.c
index 0000000000..4beccb89d5
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcflush.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief tcflush() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ int queue_selector = TCIFLUSH;
+ result = tcflush(fildes, queue_selector);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcgetattr.c b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
index 0000000000..d00336b214
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief tcgetattr() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ result = tcgetattr(fildes, &term);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcgetsid.c b/testsuites/psxtests/psxhdrs/termios/tcgetsid.c
index 0000000000..8700742166
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcgetsid.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief tcgetsid() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ pid_t result;
+ int fildes = 0;
+ result = tcgetsid(fildes);
+ return (int) result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c b/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
index 0000000000..7ef4de0b7f
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief tcsendbreak() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ int duration = 0;
+ result = tcsendbreak(fildes, duration);
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/termios/tcsetattr.c b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
index 0000000000..e2bd6980a9
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
@@ -0,0 +1,51 @@
+ * @file
+ * @brief tcsetattr() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ int fildes = 0;
+ int optional_actions = 0;
+ result = tcsetattr(fildes, optional_actions, &term);
+ return result;
2.17.1
