[PATCH] sb/config: Fix os and arch conditional logic.
chrisj at rtems.org
chrisj at rtems.org
Mon May 6 23:14:42 UTC 2019
Correctly split the argument list and check each element.
Closes #3743
source-builder/sb/config.py | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index b7bf403..df81d42 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -959,7 +959,8 @@ class file:
isos = False
if isvalid:
os = self.define('_os')
- for l in ls:
+ ls = ' '.join(ls).split()
+ for l in ls[1:]:
if l in os:
isos = True
break
@@ -969,7 +970,8 @@ class file:
isnos = True
if isvalid:
- for l in ls:
+ for l in ls[1:]:
if l in os:
isnos = False
break
@@ -979,7 +981,8 @@ class file:
isarch = False
if isvalid:
arch = self.define('_arch')
- for l in ls:
+ for l in ls[1:]:
if l in arch:
isarch = True
break
2.19.1
