[PATCH 1/2] namespace.h: Reversed additional hidden names.
Tue May 7 05:04:58 UTC 2019
On 06/05/2019 19:39, Lou Woods wrote:
> +#define _select				select
The use of select() in RTEMS is a bit dangerous due to small FD_SETSIZE.
If it is used, then you should make sure that it works with an arbitrary
maximum number of file descriptors.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
