[PATCH 09/98] doxygen: score: adjust doc in coremsg.h to doxygen guidelines
Tue May 7 05:39:14 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/coremsg.h | 25 +++++++++++++++----------
 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/score/coremsg.h b/cpukit/include/rtems/score/coremsg.h
index e2dd14bd24..cabf08b0ca 100644
--- a/cpukit/include/rtems/score/coremsg.h
+++ b/cpukit/include/rtems/score/coremsg.h
@@ -1,10 +1,12 @@
- *  @file
+ * @file
- *  @brief Constants and Structures Associated with the Message Queue Handler.
+ * @ingroup RTEMSScoreMessageQueue
- *  This include file contains all the constants and structures associated
- *  with the Message queue Handler.
+ * @brief Constants and Structures Associated with the Message Queue Handler.
+ * This include file contains all the constants and structures associated
+ * with the Message queue Handler.
@@ -29,14 +31,17 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScoreMessageQueue Message Queue Handler
+ * @defgroup RTEMSScoreMessageQueue Message Queue Handler
+ * @brief Message Queue Handler
- *  @ingroup RTEMSScore
+ * This handler encapsulates functionality which provides the foundation
+ * Message Queue services used in all of the APIs supported by RTEMS.
- *  This handler encapsulates functionality which provides the foundation
- *  Message Queue services used in all of the APIs supported by RTEMS.
  *  This macro is defined when an API is enabled that requires that the
@@ -171,7 +176,7 @@ struct CORE_message_queue_Control {
   Chain_Control                      Inactive_messages;
 #ifdef __cplusplus
2.16.4
