[PATCH 15/98] doxygen: score: adjust doc in corerwlockimpl.h to doxygen guidelines
Tue May 7 05:39:20 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/corerwlockimpl.h | 68 ++++++++++++++++++++++-------
 1 file changed, 52 insertions(+), 16 deletions(-)
diff --git a/cpukit/include/rtems/score/corerwlockimpl.h b/cpukit/include/rtems/score/corerwlockimpl.h
index 508879d022..c06427a37e 100644
--- a/cpukit/include/rtems/score/corerwlockimpl.h
+++ b/cpukit/include/rtems/score/corerwlockimpl.h
@@ -1,6 +1,8 @@
  * @file
+ * @ingroup RTEMSScoreRWLock
  * @brief Inlined Routines Associated with the SuperCore RWLock
  * This include file contains all of the inlined routines associated
@@ -87,16 +89,23 @@ typedef struct {
 }   CORE_RWLock_Control;
- *  @brief Initialize a RWlock.
+ * @brief Initializes a RWlock.
- *  This routine initializes the RWLock based on the parameters passed.
+ * This routine initializes the RWLock.
- *  @param[in] the_rwlock is the RWLock to initialize
+ * @param[out] the_rwlock is the RWLock to initialize.
 void _CORE_RWLock_Initialize(
   CORE_RWLock_Control *the_rwlock
+ * @brief Destroys a RWlock.
+ * This routine destroys the RWLock.
+ * @param[out] the_rwlock is the RWLock to destroy.
 RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
@@ -104,6 +113,14 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
   (void) the_rwlock;
+ * @brief Acquires the RWlock.
+ * @param[in, out] the_rwlock The RWlock to acquire.
+ * @param queue_context The thread queue context.
+ * @return The executing thread.
 RTEMS_INLINE_ROUTINE Thread_Control *_CORE_RWLock_Acquire(
   CORE_RWLock_Control  *the_rwlock,
   Thread_queue_Context *queue_context
@@ -124,6 +141,12 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_RWLock_Acquire(
   return executing;
+ * @brief Releases the RWlock.
+ * @param[in, out] the_rwlock The RWlock to release.
 RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
@@ -136,12 +159,18 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
- *  @brief Obtain RWLock for reading.
+ * @brief Obtains RWLock for reading.
+ * This routine attempts to obtain the RWLock for read access.
- *  This routine attempts to obtain the RWLock for read access.
+ * @param[in, out] the_rwlock is the RWLock to wait for
+ * @param wait Indicates whether the calling thread is willing to wait.
- *  @param[in] the_rwlock is the RWLock to wait for
- *  @param[in] wait is true if the calling thread is willing to wait
+ * @retval STATUS_SUCCESSFUL The RWlock was successfully seized.
+ * @retval STATUS_UNAVAILABLE The RWlock is currently locked for writing
+ *          and the calling thread is not willing to wait.
+ * @retval STATUS_TIMEOUT A timeout occured.
 Status_Control _CORE_RWLock_Seize_for_reading(
@@ -151,12 +180,19 @@ Status_Control _CORE_RWLock_Seize_for_reading(
- *  @brief Obtain RWLock for writing.
+ * @brief Obtains RWLock for writing.
+ * This routine attempts to obtain the RWLock for write exclusive access.
- *  This routine attempts to obtain the RWLock for write exclusive access.
+ * @param[in, out] the_rwlock The RWLock to wait for.
+ * @retval STATUS_SUCCESSFUL The RWLock was successfully obtained for write
+ *          exclusive access.
+ * @retval STATUS_UNAVAILABLE The RWlock is currently locked and the calling
+ *          thread is not willing to wait.
+ * @retval STATUS_TIMEOUT A timeout occurred.
 Status_Control _CORE_RWLock_Seize_for_writing(
@@ -165,14 +201,14 @@ Status_Control _CORE_RWLock_Seize_for_writing(
- *  @brief Release the RWLock.
+ * @brief Releases the RWLock.
- *  This routine manually releases @a the_rwlock.  All of the threads waiting
- *  for the RWLock will be readied.
+ * This routine manually releases @a the_rwlock.  All of the threads waiting
+ * for the RWLock will be readied.
- *  @param[in] the_rwlock is the RWLock to surrender
+ * @param[in, out] the_rwlock The RWLock to surrender.
- *  @retval Status is returned to indicate successful or failure.
+ * @return STATUS_SUCCESSFUL This method is always successful.
 Status_Control _CORE_RWLock_Surrender( CORE_RWLock_Control *the_rwlock );
2.16.4
