[PATCH 21/98] doxygen: score: adjust doc in heapimpl.h to doxygen guidelines
Tue May 7 05:39:26 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/heapimpl.h | 366 ++++++++++++++++++++++++++++------
 1 file changed, 301 insertions(+), 65 deletions(-)
diff --git a/cpukit/include/rtems/score/heapimpl.h b/cpukit/include/rtems/score/heapimpl.h
index 12da2defea..cd213ec2d8 100644
--- a/cpukit/include/rtems/score/heapimpl.h
+++ b/cpukit/include/rtems/score/heapimpl.h
@@ -26,8 +26,9 @@ extern "C" {
  * @addtogroup RTEMSScoreHeap
  * @brief See also @ref Heap_Block.size_and_flag.
@@ -50,18 +51,19 @@ typedef enum {
 } Heap_Resize_status;
- * @brief Gets the first and last block for the heap area with begin
- * @a heap_area_begin and size @a heap_area_size.
- * A page size of @a page_size and minimal block size of @a min_block_size will
- * be used for calculation.
+ * @brief Gets the first and last block for the heap area.
  * Nothing will be written to this area.
- * In case of success the pointers to the first and last block will be returned
- * via @a first_block_ptr and @a last_block_ptr.
+ * @param heap_area_begin The starting address of the heap area.
+ * @param heap_area_size The size of the heap area.
+ * @param page_size The page size for the calculation.
+ * @param min_block_size The minimal block size for the calculation.
+ * @param[out] first_block_ptr The pointer to the first block in the case of success
+ * @param[out] last_block_ptr The pointer to the last block in the case of success
- * Returns @c true if the area is big enough, and @c false otherwise.
+ * @retval true The area is big enough.
+ * @retval false The area is not big enough.
 bool _Heap_Get_first_and_last_block(
   uintptr_t heap_area_begin,
@@ -73,14 +75,19 @@ bool _Heap_Get_first_and_last_block(
- * @brief Initializes the heap control block @a heap to manage the area
- * starting at @a area_begin of size @a area_size bytes.
+ * @brief Initializes the heap control block.
  * Blocks of memory are allocated from the heap in multiples of @a page_size
  * byte units.  If the @a page_size is equal to zero or is not multiple of
  * @c CPU_ALIGNMENT, it is aligned up to the nearest @c CPU_ALIGNMENT boundary.
- * Returns the maximum memory available, or zero in case of failure.
+ * @param[out] heap The heap control block to manage the area.
+ * @param area_begin The starting address of the area.
+ * @param area_size The size of the area in bytes.
+ * @retval some_value The maximum memory available.
+ * @retval 0 The initialization failed.
  * @see Heap_Initialization_or_extend_handler.
@@ -92,22 +99,22 @@ uintptr_t _Heap_Initialize(
- * @brief Allocates a memory area of size @a size bytes from the heap @a heap.
- * If the alignment parameter @a alignment is not equal to zero, the allocated
- * memory area will begin at an address aligned by this value.
- * If the boundary parameter @a boundary is not equal to zero, the allocated
- * memory area will fulfill a boundary constraint.  The boundary value
- * specifies the set of addresses which are aligned by the boundary value.  The
- * interior of the allocated memory area will not contain an element of this
- * set.  The begin or end address of the area may be a member of the set.
+ * @brief Allocates an aligned memory area with boundary constraint.
  * A size value of zero will return a unique address which may be freed with
  * _Heap_Free().
- * Returns a pointer to the begin of the allocated memory area, or @c NULL if
- * no memory is available or the parameters are inconsistent.
+ * @param[in, out] heap The heap to allocate a memory are from.
+ * @param size The size of the desired memory are in bytes.
+ * @param alignment The allocated memory area will begin at an address aligned by this value.
+ * @param boundary The allocated memory area will fulfill a boundary constraint,
+ *      if this value is not equal to zero.  The boundary value specifies
+ *      the set of addresses which are aligned by the boundary value.  The
+ *      interior of the allocated memory area will not contain an element of this
+ *      set.  The begin or end address of the area may be a member of the set.
+ * @retval pointer The starting address of the allocated memory area.
+ * @retval NULL No memory is available of the parameters are inconsistent.
 void *_Heap_Allocate_aligned_with_boundary(
   Heap_Control *heap,
@@ -117,7 +124,17 @@ void *_Heap_Allocate_aligned_with_boundary(
- * @brief See _Heap_Allocate_aligned_with_boundary() with boundary equals zero.
+ * @brief Allocates an aligned memory area.
+ * A size value of zero will return a unique address which may be freed with
+ * _Heap_Free().
 RTEMS_INLINE_ROUTINE void *_Heap_Allocate_aligned(
   Heap_Control *heap,
@@ -129,8 +146,16 @@ RTEMS_INLINE_ROUTINE void *_Heap_Allocate_aligned(
- * @brief See _Heap_Allocate_aligned_with_boundary() with alignment and
- * boundary equals zero.
+ * @brief Allocates a memory area.
+ * _Heap_Free().
 RTEMS_INLINE_ROUTINE void *_Heap_Allocate( Heap_Control *heap, uintptr_t size )
@@ -138,22 +163,29 @@ RTEMS_INLINE_ROUTINE void *_Heap_Allocate( Heap_Control *heap, uintptr_t size )
- * @brief Frees the allocated memory area starting at @a addr in the heap
- * @a heap.
+ * @brief Frees the allocated memory area.
  * Inappropriate values for @a addr may corrupt the heap.
- * Returns @c true in case of success, and @c false otherwise.
+ * @param[in, out] heap The heap of the allocated memory area.
+ * @param addr The starting address of the memory area to be freed.
+ * @retval true The allocated memory area was successfully freed.
+ * @retval false The method failed.
 bool _Heap_Free( Heap_Control *heap, void *addr );
- * @brief Walks the heap @a heap to verify its integrity.
+ * @brief Verifies the integrity of the heap.
- * If @a dump is @c true, then diagnostic messages will be printed to standard
- * output.  In this case @a source is used to mark the output lines.
+ * Walks the heap to verify its integrity.
- * Returns @c true if no errors occurred, and @c false if the heap is corrupt.
+ * @param heap The heap whose integrity is to be verified.
+ * @param source If @a dump is @c true, this is used to mark the output lines.
+ * @param dump Indicates whether diagnostic messages will be printed to standard output.
+ * @retval true No errors occured, the heap´s integrity is not violated.
+ * @retval false The heap is corrupt.
 bool _Heap_Walk(
   Heap_Control *heap,
@@ -179,8 +211,10 @@ typedef bool (*Heap_Block_visitor)(
  * @brief Iterates over all blocks of the heap.
- * For each block the @a visitor with the argument @a visitor_arg will be
- * called.
+ * @param[in, out] heap The heap to iterate over.
+ * @param visitor This will be called for each heap block with
+ *      the argument @a visitor_arg.
+ * @param[in, out] visitor_arg The argument for all calls of @a visitor.
 void _Heap_Iterate(
   Heap_Control *heap,
@@ -189,11 +223,18 @@ void _Heap_Iterate(
- * @brief Greedy allocate that empties the heap.
+ * @brief Greedily allocates and empties the heap.
+ * Afterwards, the heap has at most @a block_count allocatable blocks of sizes
+ * specified by @a block_sizes.  All other blocks are used.
- * Afterwards the heap has at most @a block_count allocatable blocks of sizes
- * specified by @a block_sizes.  The @a block_sizes must point to an array with
- * @a block_count members.  All other blocks are used.
+ * @param[in, out] heap The heap to operate upon
+ * @param block_sizes The sizes of the allocatable blocks.  Must point to an
+ *      array with @a block_count members.
+ * @param block_count The maximum number of allocatable blocks of sizes
+ *      specified by @block_sizes.
+ * @return Pointer to the first allocated block.
  * @see _Heap_Greedy_free().
@@ -204,11 +245,16 @@ Heap_Block *_Heap_Greedy_allocate(
- * @brief Greedy allocate all blocks except the largest free block.
+ * @brief Greedily allocates all blocks except the largest free block.
  * Afterwards the heap has at most one allocatable block.  This block is the
- * largest free block if it exists.  The allocatable size of this block is
- * stored in @a allocatable_size.  All other blocks are used.
+ * largest free block if it exists.  All other blocks are used.
+ * @param[in, out] heap The heap to operate upon.
+ * @param[out] allocatable_size Stores the size of the largest free block of
+ *      the heap after the method call.
@@ -220,7 +266,8 @@ Heap_Block *_Heap_Greedy_allocate_all_except_largest(
  * @brief Frees blocks of a greedy allocation.
- * The @a blocks must be the return value of _Heap_Greedy_allocate().
+ * @param blocks Must be the return value of _Heap_Greedy_allocate().
 void _Heap_Greedy_free(
   Heap_Control *heap,
@@ -228,8 +275,10 @@ void _Heap_Greedy_free(
- * @brief Returns information about used and free blocks for the heap @a heap
- * in @a info.
+ * @brief Returns information about used and free blocks for the heap.
+ * @param heap The heap to get the information from.
+ * @param[out] info Stores the information of the @a heap after the method call.
 void _Heap_Get_information(
   Heap_Control *heap,
@@ -237,8 +286,11 @@ void _Heap_Get_information(
- * @brief Returns information about free blocks for the heap @a heap in
- * @a info.
+ * @brief Returns information about free blocks for the heap.
+ * @param[out] info Stores the information about free blocks of @a heap after the
+ *      method call.
 void _Heap_Get_free_information(
   Heap_Control *heap,
@@ -246,8 +298,7 @@ void _Heap_Get_free_information(
- * @brief Returns the size of the allocatable memory area starting at @a addr
- * in @a size.
+ * @brief Returns the size of the allocatable memory area.
  * The size value may be greater than the initially requested size in
  * _Heap_Allocate_aligned_with_boundary().
@@ -255,7 +306,12 @@ void _Heap_Get_free_information(
  * Inappropriate values for @a addr will not corrupt the heap, but may yield
  * invalid size values.
- * Returns @a true if successful, and @c false otherwise.
+ * @param heap The heap to operate upon.
+ * @param addr The starting address of the allocatable memory area.
+ * @param[out] size Stores the size of the allocatable memory area after the method call.
+ * @retval true The operation was successful.
+ * @retval false The operation was not successful.
 bool _Heap_Size_of_alloc_area(
   Heap_Control *heap,
@@ -264,17 +320,25 @@ bool _Heap_Size_of_alloc_area(
- * @brief Resizes the block of the allocated memory area starting at @a addr.
- * The new memory area will have a size of at least @a size bytes.  A resize
- * may be impossible and depends on the current heap usage.
- * The size available for allocation in the current block before the resize
- * will be returned in @a old_size.  The size available for allocation in
- * the resized block will be returned in @a new_size.  If the resize was not
- * successful, then a value of zero will be returned in @a new_size.
+ * @brief Resizes the block of the allocated memory area.
+ * @param addr The starting address of the allocated memory area to be resized.
+ * @param size The least possible size for the new memory area.  Resize may be
+ *      impossible and depends on the current heap usage.
+ * @param[out] old_size Stores the size available for allocation in the current
+ *      block before the resize after the method call.
+ * @param[out] new_size Stores the size available for allocation in the resized
+ *      block after the method call.  In the case of an unsuccessful resize,
+ *      zero is returned in this parameter
+ * @retval HEAP_RESIZE_SUCCESSFUL The resize was successful.
+ * @retval HEAP_RESIZE_UNSATISFIED The least possible size @a size was too big.
+ *      Resize not possible.
+ * @retval HEAP_RESIZE_FATAL_ERROR The block starting at @a addr is not part of
+ *      the heap.
 Heap_Resize_status _Heap_Resize_block(
   Heap_Control *heap,
@@ -285,7 +349,8 @@ Heap_Resize_status _Heap_Resize_block(
- * @brief Allocates the memory area starting at @a alloc_begin of size
+ * @brief Allocates the memory area.
+ * starting at @a alloc_begin of size
  * @a alloc_size bytes in the block @a block.
  * The block may be split up into multiple blocks.  The previous and next block
@@ -297,7 +362,12 @@ Heap_Resize_status _Heap_Resize_block(
  * Inappropriate values for @a alloc_begin or @a alloc_size may corrupt the
  * heap.
- * Returns the block containing the allocated memory area.
+ * @param block The block in which the memory area should be allocated
+ * @param alloc_begin The starting address of the memory area that shall be allocated.
+ * @param alloc_size The size of the desired allocated area in bytes.
+ * @return The block containing the allocated memory area.
 Heap_Block *_Heap_Block_allocate(
   Heap_Control *heap,
@@ -354,8 +424,8 @@ Heap_Block *_Heap_Block_allocate(
  * The default is to free half the delayed free blocks.  This is equal to a
  * fraction value of two.
- * @param[in] heap The heap control.
- * @param[in] fraction The fraction is one divided by this fraction value.
+ * @param[in, out] heap The heap control.
+ * @param fraction The fraction is one divided by this fraction value.
 RTEMS_INLINE_ROUTINE void _Heap_Protection_set_delayed_free_fraction(
   Heap_Control *heap,
@@ -370,26 +440,59 @@ RTEMS_INLINE_ROUTINE void _Heap_Protection_set_delayed_free_fraction(
 #endif
+ * @brief Returns the head of the free list of the heap.
+ * @return The head of the free list.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Free_list_head( Heap_Control *heap )
   return &heap->free_list;
+ * @brief Returns the tail of the free list of the heap.
+ * @return The tail of the free list.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Free_list_tail( Heap_Control *heap )
+ * @brief Returns the first block of the free list of the heap.
+ * @return The first block of the free list.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Free_list_first( Heap_Control *heap )
   return _Heap_Free_list_head(heap)->next;
+ * @brief Returns the last block of the free list of the heap.
+ * @return The last block of the free list.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Free_list_last( Heap_Control *heap )
   return _Heap_Free_list_tail(heap)->prev;
+ * @brief Removes the block from the free list.
+ * @param block The block to be removed.
 RTEMS_INLINE_ROUTINE void _Heap_Free_list_remove( Heap_Block *block )
   Heap_Block *next = block->next;
@@ -399,6 +502,12 @@ RTEMS_INLINE_ROUTINE void _Heap_Free_list_remove( Heap_Block *block )
   next->prev = prev;
+ * @brief Replaces one block in the free list by another.
+ * @param old_block The block in the free list to replace.
+ * @param new_block The block that should replace @a old_block.
 RTEMS_INLINE_ROUTINE void _Heap_Free_list_replace(
   Heap_Block *old_block,
   Heap_Block *new_block
@@ -414,6 +523,12 @@ RTEMS_INLINE_ROUTINE void _Heap_Free_list_replace(
   prev->next = new_block;
+ * @brief Inserts a block after an existing block in the free list.
+ * @param block_before The block that is already in the free list.
+ * @param new_block The block to be inserted after @a block_before.
 RTEMS_INLINE_ROUTINE void _Heap_Free_list_insert_after(
   Heap_Block *block_before,
@@ -427,6 +542,12 @@ RTEMS_INLINE_ROUTINE void _Heap_Free_list_insert_after(
   next->prev = new_block;
+ * @brief Inserts a block before an existing block in the free list.
+ * @param new_block The block to be inserted before @a block_before.
 RTEMS_INLINE_ROUTINE void _Heap_Free_list_insert_before(
   Heap_Block *block_next,
@@ -440,6 +561,15 @@ RTEMS_INLINE_ROUTINE void _Heap_Free_list_insert_before(
   block_next->prev = new_block;
+ * @brief Checks if the value is aligned to the given alignment.
+ * @param value The value to check the alignment of.
+ * @param alignment The alignment for the operation.
+ * @retval true The value is aligned to the given alignment.
+ * @retval false The value is not aligned to the given alignment.
 RTEMS_INLINE_ROUTINE bool _Heap_Is_aligned(
   uintptr_t value,
   uintptr_t alignment
@@ -448,6 +578,14 @@ RTEMS_INLINE_ROUTINE bool _Heap_Is_aligned(
   return (value % alignment) == 0;
+ * @brief Returns the aligned value, truncating.
+ * @param value The value to be aligned
+ * @return The aligned value, truncated.
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Align_down(
   uintptr_t value,
   uintptr_t alignment
@@ -458,6 +596,11 @@ RTEMS_INLINE_ROUTINE uintptr_t _Heap_Align_down(
  * @brief Returns the block which is @a offset away from @a block.
+ * @param block The block for the relative calculation.
+ * @param offset The offset for the calculation.
+ * @return The address of the block which is @a offset away from @a block.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Block_at(
   const Heap_Block *block,
@@ -467,6 +610,13 @@ RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Block_at(
   return (Heap_Block *) ((uintptr_t) block + offset);
+ * @brief Returns the address of the previous block.
+ * @param block The block of which the address of the previous block is requested.
+ * @return The address of the previous block.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Prev_block(
@@ -474,6 +624,13 @@ RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Prev_block(
   return (Heap_Block *) ((uintptr_t) block - block->prev_size);
+ * @brief Returns the first address in the block without the heap header.
+ * @param block The block for the operation.
+ * @return The first address after the heap header.
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Alloc_area_of_block(
@@ -481,6 +638,14 @@ RTEMS_INLINE_ROUTINE uintptr_t _Heap_Alloc_area_of_block(
   return (uintptr_t) block + HEAP_BLOCK_HEADER_SIZE;
+ * @brief Returns the starting address of the block corresponding to the allocatable area.
+ * @param alloc_begin The starting address of the allocatable area.
+ * @return The Starting address of the corresponding block of the allocatable area.
 RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Block_of_alloc_area(
   uintptr_t alloc_begin,
   uintptr_t page_size
@@ -490,11 +655,24 @@ RTEMS_INLINE_ROUTINE Heap_Block *_Heap_Block_of_alloc_area(
     - HEAP_BLOCK_HEADER_SIZE);
+ * @brief Returns the block size.
+ * @param block The block of which the size is requested.
+ * @return The block size.
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Block_size( const Heap_Block *block )
   return block->size_and_flag & ~HEAP_PREV_BLOCK_USED;
+ * @brief Sets the block size.
+ * @param[in, out] block The block of which the size shall be set.
+ * @param size The new size of the block.
 RTEMS_INLINE_ROUTINE void _Heap_Block_set_size(
   Heap_Block *block,
   uintptr_t size
@@ -505,11 +683,28 @@ RTEMS_INLINE_ROUTINE void _Heap_Block_set_size(
   block->size_and_flag = size | flag;
+ * @brief Returns if the previous heap block is used.
+ * @param block The block of which the information about the previous
+ *      block is requested.
+ * @retval true The previous block is used.
+ * @retval false The previous block is not used.
 RTEMS_INLINE_ROUTINE bool _Heap_Is_prev_used( const Heap_Block *block )
   return block->size_and_flag & HEAP_PREV_BLOCK_USED;
+ * @brief Returns if the heap block is used.
+ * @param block The block of which the information is requested.
+ * @retval true The block is used.
+ * @retval false The block is not used.
 RTEMS_INLINE_ROUTINE bool _Heap_Is_used(
@@ -520,6 +715,14 @@ RTEMS_INLINE_ROUTINE bool _Heap_Is_used(
   return _Heap_Is_prev_used( next_block );
+ * @brief Returns if the heap block is free.
+ * @retval true The block is free.
+ * @retval false The block is not free.
 RTEMS_INLINE_ROUTINE bool _Heap_Is_free(
@@ -527,6 +730,15 @@ RTEMS_INLINE_ROUTINE bool _Heap_Is_free(
   return !_Heap_Is_used( block );
+ * @brief Returns if the block is part of the heap.
+ * @param heap The heap to test if the @a block is part of it.
+ * @retval true The block is part of the heap.
+ * @retval false The block is not part of the heap.
 RTEMS_INLINE_ROUTINE bool _Heap_Is_block_in_heap(
   const Heap_Control *heap,
@@ -537,7 +749,7 @@ RTEMS_INLINE_ROUTINE bool _Heap_Is_block_in_heap(
- * @brief Sets the size of the last block for heap @a heap.
+ * @brief Sets the size of the last block for the heap.
  * The next block of the last block will be the first block.  Since the first
  * block indicates that the previous block is used, this ensures that the last
@@ -546,6 +758,8 @@ RTEMS_INLINE_ROUTINE bool _Heap_Is_block_in_heap(
  * This feature will be used to terminate the scattered heap area list.  See
  * also _Heap_Extend().
+ * @param[in, out] heap The heap to set the last block size of.
 RTEMS_INLINE_ROUTINE void _Heap_Set_last_block_size( Heap_Control *heap )
@@ -559,17 +773,39 @@ RTEMS_INLINE_ROUTINE void _Heap_Set_last_block_size( Heap_Control *heap )
  * @brief Returns the size of the allocatable area in bytes.
  * This value is an integral multiple of the page size.
+ * @param heap The heap to get the allocatable area from.
+ * @return The size of the allocatable area in @a heap in bytes.
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Get_size( const Heap_Control *heap )
   return heap->stats.size;
+ * @brief Returns the bigger one of the two arguments.
+ * @param a The parameter on the left hand side of the comparison.
+ * @param b The parameter on the right hand side of the comparison.
+ * @retval a If a > b.
+ * @retval b If b >= a
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Max( uintptr_t a, uintptr_t b )
   return a > b ? a : b;
+ * @brief Returns the smaller one of the two arguments.
+ * @retval a If a < b.
+ * @retval b If b <= a
 RTEMS_INLINE_ROUTINE uintptr_t _Heap_Min( uintptr_t a, uintptr_t b )
   return a < b ? a : b;
2.16.4
