[PATCH 32/98] doxygen: score: adjust doc in object.h to doxygen guidelines
Tue May 7 05:39:37 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/object.h | 45 +++++++++++++++++++++----------------
 1 file changed, 26 insertions(+), 19 deletions(-)
diff --git a/cpukit/include/rtems/score/object.h b/cpukit/include/rtems/score/object.h
index b387410c3c..6f4bea95ae 100644
--- a/cpukit/include/rtems/score/object.h
+++ b/cpukit/include/rtems/score/object.h
@@ -1,6 +1,8 @@
  * @file
+ * @ingroup RTEMSScoreObject
  * @brief Constants and Structures Associated with the Object Handler
  * This include file contains all the constants and structures associated
@@ -33,8 +35,9 @@ extern "C" {
  * @ingroup RTEMSInternal
  * @brief Provides services for all APIs.
  * @defgroup RTEMSScoreCPU CPU Architecture Support
@@ -42,15 +45,17 @@ extern "C" {
  * @brief Provides CPU architecture dependent services.
- *  @defgroup RTEMSScoreObject Object Handler
+ * @defgroup RTEMSScoreObject Object Handler
- *  @ingroup RTEMSScore
  *  The following type defines the control block used to manage
@@ -241,11 +246,11 @@ typedef enum {
     (uint32_t)(_C4) )
- * This function returns the API portion of the ID.
+ * @brief Returns the API portion of the ID.
- * @param[in] id is the object Id to be processed.
+ * @param id The object Id to be processed.
- * @return This method returns an object Id constructed from the arguments.
+ * @return An object Id constructed from the arguments.
 RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API(
   Objects_Id id
@@ -255,9 +260,11 @@ RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API(
- * This function returns the class portion of the ID.
+ * @brief Returns the class portion of the ID.
+ * @return The class portion of the ID.
 RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_class(
   Objects_Id id
@@ -268,11 +275,11 @@ RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_class(
- * This function returns the node portion of the ID.
+ * @brief Returns the node portion of the ID.
- * @return This method returns the node portion of an object ID.
+ * @return Returns the node portion of an object ID.
 RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node(
   Objects_Id id
@@ -282,11 +289,11 @@ RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node(
- * This function returns the index portion of the ID.
+ * @brief Returns the index portion of the ID.
- * @param[in] id is the Id to be processed
+ * @param id is the Id to be processed.
- * @return This method returns the class portion of the specified object ID.
+ * @return Returns the index portion of the specified object ID.
 RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index(
   Objects_Id id
@@ -331,9 +338,9 @@ RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index(
 #define _Objects_Maximum_per_allocation( maximum ) \
   ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS))
 #ifdef __cplusplus
2.16.4
