[PATCH 36/98] doxygen: score: adjust doc in prioritybitmap.h to doxygen guidelines
Tue May 7 05:39:41 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/prioritybitmap.h | 21 +++++++++++++--------
 1 file changed, 13 insertions(+), 8 deletions(-)
diff --git a/cpukit/include/rtems/score/prioritybitmap.h b/cpukit/include/rtems/score/prioritybitmap.h
index b6b566dfa9..608eb58892 100644
--- a/cpukit/include/rtems/score/prioritybitmap.h
+++ b/cpukit/include/rtems/score/prioritybitmap.h
@@ -1,10 +1,12 @@
- *  @file
+ * @file
- *  @brief Manipulation Routines for the Bitmap Priority Queue Implementation
+ * @ingroup RTEMSScorePriorityBitmap
- *  This include file contains all thread priority manipulation routines for
- *  the bit map priority queue implementation.
+ * @brief Manipulation Routines for the Bitmap Priority Queue Implementation
+ * This include file contains all thread priority manipulation routines for
+ * the bit map priority queue implementation.
@@ -26,11 +28,14 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScorePriorityBitmap Bitmap Priority Thread Routines
+ * @defgroup RTEMSScorePriorityBitmap Bitmap Priority Thread Routines
+ * @brief Bitmap Priority Thread Routines
- *  @ingroup RTEMSScore
 typedef uint16_t Priority_bit_map_Word;
@@ -69,7 +74,7 @@ typedef struct {
   Priority_bit_map_Word  block_minor;
 } Priority_bit_map_Information;
 #ifdef __cplusplus
2.16.4
