[PATCH 57/98] doxygen: score: adjust doc in schedulersimple.h to doxygen guidelines
Tue May 7 05:40:02 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/schedulersimple.h | 67 +++++++++++++++++++++-------
 1 file changed, 52 insertions(+), 15 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulersimple.h b/cpukit/include/rtems/score/schedulersimple.h
index 3f67e138af..028a5d6262 100644
--- a/cpukit/include/rtems/score/schedulersimple.h
+++ b/cpukit/include/rtems/score/schedulersimple.h
@@ -1,10 +1,12 @@
- *  @file
+ * @file
- *  @brief Manipulation of Threads Simple-Priority-Based Ready Queue
+ * @ingroup RTEMSScoreSchedulerSimple
- *  This include file contains all the constants and structures associated
- *  with the manipulation of threads on a simple-priority-based ready queue.
+ * @brief Manipulation of Threads Simple-Priority-Based Ready Queue
+ * This include file contains all the constants and structures associated
+ * with the manipulation of threads on a simple-priority-based ready queue.
@@ -26,11 +28,14 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScoreSchedulerSimple Simple Priority Scheduler
+ * @defgroup RTEMSScoreSchedulerSimple Simple Priority Scheduler
+ * @brief Simple Priority Scheduler
- *  @ingroup RTEMSScoreScheduler
 #define SCHEDULER_SIMPLE_MAXIMUM_PRIORITY 255
@@ -73,50 +78,82 @@ typedef struct {
 } Scheduler_simple_Context;
- *  @brief Initialize simple scheduler.
+ * @brief Initializes simple scheduler.
- *  This routine initializes the simple scheduler.
+ * This routine initializes the simple scheduler.
+ * @param scheduler The scheduler to be initialized.
 void _Scheduler_simple_Initialize( const Scheduler_Control *scheduler );
- *  This routine sets the heir thread to be the next ready thread
- *  on the ready queue by getting the first node in the scheduler
- *  information.
+ * @brief Schedules threads.
+ * This routine sets the heir thread to be the next ready thread
+ * on the ready queue by getting the first node in the scheduler
+ * information.
- *  @param[in] scheduler The scheduler instance.
- *  @param[in] the_thread causing the scheduling operation.
+ * @param scheduler The scheduler instance.
+ * @param the_thread causing the scheduling operation.
 void _Scheduler_simple_Schedule(
   const Scheduler_Control *scheduler,
   Thread_Control          *the_thread
+ * @brief Performs the yield of a thread.
+ * @param[in, out] the_thread The thread that performed the yield operation.
+ * @param node The scheduler node of @a the_thread.
 void _Scheduler_simple_Yield(
   Thread_Control          *the_thread,
   Scheduler_Node          *node
+ * @brief Blocks the thread.
+ * @param[in, out] the_thread The thread to block.
+ * @param[in, out] node The @a thread's scheduler node.
 void _Scheduler_simple_Block(
+ * @brief Unblocks the thread.
+ * @param[in, out] the_thread The thread to unblock.
 void _Scheduler_simple_Unblock(
+ * @brief Updates the priority of the node.
+ * @param the_thread The thread for the operation.
+ * @param node The thread's scheduler node.
 void _Scheduler_simple_Update_priority(
 #ifdef __cplusplus
2.16.4
