[PATCH 68/98] doxygen: score: adjust doc in smplockmcs.h to doxygen guidelines
Tue May 7 05:40:13 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/smplockmcs.h | 21 ++++++++++++++-------
 1 file changed, 14 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/rtems/score/smplockmcs.h b/cpukit/include/rtems/score/smplockmcs.h
index 977f807fe8..9c003fde6e 100644
--- a/cpukit/include/rtems/score/smplockmcs.h
+++ b/cpukit/include/rtems/score/smplockmcs.h
@@ -104,11 +104,11 @@ typedef struct {
 #define SMP_MCS_LOCK_INITIALIZER { { ATOMIC_INITIALIZER_UINTPTR( 0 ) } }
- * @brief Initializes an SMP MCS lock.
+ * @brief Initializes the SMP MCS lock.
  * Concurrent initialization leads to unpredictable results.
- * @param lock The SMP MCS lock control.
+ * @param[in, out] lock The SMP MCS lock control.
 static inline void _SMP_MCS_lock_Initialize( SMP_MCS_lock_Control *lock )
@@ -116,17 +116,24 @@ static inline void _SMP_MCS_lock_Initialize( SMP_MCS_lock_Control *lock )
- * @brief Destroys an SMP MCS lock.
+ * @brief Destroys the SMP MCS lock.
  * Concurrent destruction leads to unpredictable results.
+ * @param[out] lock The SMP MCS lock control.
 static inline void _SMP_MCS_lock_Destroy( SMP_MCS_lock_Control *lock )
   (void) lock;
+ * @brief Acquires the SMP MCS lock.
+ * @param[in, out] lock The lock to acquire.
+ * @param[in, out] context The lock context.
+ * @param stats the SMP lock statistics.
 static inline void _SMP_MCS_lock_Do_acquire(
   SMP_MCS_lock_Control   *lock,
   SMP_MCS_lock_Context   *context
@@ -199,8 +206,8 @@ static inline void _SMP_MCS_lock_Do_acquire(
  * @brief Releases an SMP MCS lock.
- * @param context The SMP MCS lock context.
+ * @param[in, out] context The SMP MCS lock context.
 static inline void _SMP_MCS_lock_Release(
@@ -251,7 +258,7 @@ static inline void _SMP_MCS_lock_Release(
   _Atomic_Store_uint( &next->locked, 0, ATOMIC_ORDER_RELEASE );
 #ifdef __cplusplus
2.16.4
