[PATCH 72/98] doxygen: score: adjust doc in stack.h to doxygen guidelines
Tue May 7 05:40:17 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/stack.h | 27 ++++++++++++++++-----------
 1 file changed, 16 insertions(+), 11 deletions(-)
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index 3f80a1e12c..1158f3472e 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -1,11 +1,13 @@
- *  @file
+ * @file
- *  @brief Information About the Thread Stack Handler
+ * @ingroup RTEMSScoreStack
- *  This include file contains all information about the thread
- *  Stack Handler.  This Handler provides mechanisms which can be used to
- *  initialize and utilize stacks.
+ * @brief Information About the Thread Stack Handler
+ * This include file contains all information about the thread
+ * Stack Handler.  This Handler provides mechanisms which can be used to
+ * initialize and utilize stacks.
@@ -27,14 +29,17 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScoreStack Stack Handler
+ * @defgroup RTEMSScoreStack Stack Handler
+ * @brief Stack Handler
- *  @ingroup RTEMSScore
+ * This handler encapsulates functionality which is used in the management
+ * of thread stacks.
- *  This handler encapsulates functionality which is used in the management
- *  of thread stacks.
  *  The following constant defines the minimum stack size which every
@@ -59,7 +64,7 @@ typedef struct {
 extern uint32_t rtems_minimum_stack_size;
 #ifdef __cplusplus
2.16.4
