devel Digest, Vol 90, Issue 37 --> RTEMS 5.0 error occurred in 'make' while --enable- tests
Aby Tom
abythayil at gmail.com
Tue May 7 14:17:56 UTC 2019
Dear Joel,
thanks for the quick response.
my command was:
$HOME/dev/kernel/rtems/configure --prefix=$HOME/dev/rtems/5
--target=arm-rtems5 --enable-rtemsbsp=tms570lc4357 --enable-maintainer-mode
--enable-tests
Thanks and Regards,
Aby
On Tue, May 7, 2019, 3:59 PM <devel-request at rtems.org> wrote:
> Send devel mailing list submissions to
> devel at rtems.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> devel-owner at rtems.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of devel digest..."
> Today's Topics:
> 1. RTEMS 5.0 error occurred in 'make' while --enable- tests are
> done (Aby Tom)
> 2. Re: RTEMS 5.0 error occurred in 'make' while --enable- tests
> are done (Joel Sherrill)
> Message: 1
> Date: Tue, 7 May 2019 15:44:38 +0200
> From: Aby Tom <abythayil at gmail.com>
> To: devel at rtems.org
> Subject: RTEMS 5.0 error occurred in 'make' while --enable- tests are
> done
> Message-ID:
> <CADH5PD1CL8A2CRQruERf2rp1iPJyBHk-NHuYCWT8D8qUoR=
> TOQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello everyone,
> I am new to RTEMS, and was trying to build a new bsp for RTEMS 5 for tms570
> family of boards.
> While doing the make, i come across this error.
> I had done --enable-tests in the previous command.
> Can anyone help me with this? Output from terminal is shown below.
> (.... represent some omitted output results)
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/nfs.c: In
> function 'nfs_fsunmount_me':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/nfs.c:1928:7:
> warning: variable 'status' set but not used [-Wunused-but-set-variable]
> int status;
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:
> In function 'rpcUdpServerCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:567:11:
> error: 'llock' undeclared (first use in this function); did you mean
> 'clock'?
> MU_LOCK( llock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:204:54:
> note: in definition of macro 'MU_LOCK'
> #define MU_LOCK(mutex) rtems_recursive_mutex_lock(&(mutex))
> note: each undeclared identifier is reported only once for each function it
> appears in
> MU_LOCK( llock );
> In function 'rpcUdpXactCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:667:11:
> error: 'hlock' undeclared (first use in this function); did you mean
> 'clock'?
> MU_LOCK(hlock);
> In function 'rpcUdpXactDestroy':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:711:11:
> 'clock'?
> MU_LOCK(hlock);
> In function 'rpcUdpRcv':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:813:19:
> rtems_status_code status;
> In function 'rpcUdpInit':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:938:15:
> 'clock'?
> MU_CREAT( &hlock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:208:54:
> note: in definition of macro 'MU_CREAT'
> #define MU_CREAT(pmutex) rtems_recursive_mutex_init((pmutex), "RPCl")
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:939:15:
> 'hlock'?
> MU_CREAT( &llock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:924:19:
> warning: variable 'wkup' set but not used [-Wunused-but-set-variable]
> struct sockwakeup wkup;
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:922:19:
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:921:7:
> warning: variable 's' set but not used [-Wunused-but-set-variable]
> int s;
> In function 'rpcio_daemon':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1173:12:
> 'clock'?
> MU_LOCK(hlock);
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1149:19:
> In function 'rpcUdpXactPoolCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1508:19:
> Makefile:11245: recipe for target 'libfs/src/nfsclient/src/rpcio.o' failed
> make[4]: *** [libfs/src/nfsclient/src/rpcio.o] Error 1
> make[4]: Leaving directory
> Makefile:1221: recipe for target 'cpukit' failed
> make[3]: *** [cpukit] Error 2
> make[3]: Leaving directory
> Makefile:715: recipe for target 'all-recursive' failed
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> Makefile:289: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> Makefile:410: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> Thank you.
> Regards,
> Aby
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.rtems.org/pipermail/devel/attachments/20190507/0933795b/attachment-0001.html
> Message: 2
> Date: Tue, 7 May 2019 08:58:44 -0500
> From: Joel Sherrill <joel at rtems.org>
> To: Aby Tom <abythayil at gmail.com>
> Cc: "rtems-devel at rtems.org" <devel at rtems.org>
> Subject: Re: RTEMS 5.0 error occurred in 'make' while --enable- tests
> are done
> Message-ID:
> <CAF9ehCUPi0yKAO=
> KFGWMAFX6cHB02cHjep3ukfkV36qzNcZOrQ at mail.gmail.com>
> This BSP builds for me off the master. There are multiple variants within
> this
> BSP family and various configurations you could have used. Could you
> share your configure command?
> Mine was:
> ../rtems/configure --target=arm-rtems5
> --enable-rtemsbsp=tms570ls3137_hdk_sdram
> --prefix=/home/joel/rtems-work/tools/5/bsp-install --enable-networking
> --enable-posix --disable-smp --disable-multiprocessing
> --disable-rtems-debug --disable-profiling --enable-tests --enable-cxx
> Thanks.
> --joel
> On Tue, May 7, 2019 at 8:44 AM Aby Tom <abythayil at gmail.com> wrote:
> > Hello everyone,
> > tms570 family of boards.
> > In function 'nfs_fsunmount_me':
> > int status;
> > 'clock'?
> > MU_LOCK( llock );
> it
> > appears in
> > MU_LOCK( llock );
> > 'clock'?
> > MU_LOCK(hlock);
> > 'clock'?
> > MU_LOCK(hlock);
> > 'clock'?
> > MU_CREAT( &hlock );
> > 'hlock'?
> > MU_CREAT( &llock );
> > int s;
> > 'clock'?
> > MU_LOCK(hlock);
> failed
> > Thank you.
> > Regards,
> > Aby
> > devel mailing list
> > devel at rtems.org
> URL: <
> http://lists.rtems.org/pipermail/devel/attachments/20190507/15d73ec9/attachment.html
> Subject: Digest Footer
> devel mailing list
> devel at rtems.org
> End of devel Digest, Vol 90, Issue 37
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190507/e7123c98/attachment-0001.html>
