[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for termios.h
Joel Sherrill
joel at rtems.org
Tue May 7 19:56:40 UTC 2019
Thank you.
This is now pushed.
Does a ticket need to be updated for this? I am having trouble remembering
how we tracked what .h files still needed work.
On Mon, May 6, 2019 at 2:02 PM Jacob Shin <jacobshin313 at gmail.com> wrote:
> testsuites/psxtests/Makefile.am | 11 ++++
> .../psxtests/psxhdrs/termios/cfgetispeed.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/cfgetospeed.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/cfsetispeed.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/cfsetospeed.c | 50 ++++++++++++++++++
> testsuites/psxtests/psxhdrs/termios/tcdrain.c | 49 ++++++++++++++++++
> testsuites/psxtests/psxhdrs/termios/tcflow.c | 50 ++++++++++++++++++
> testsuites/psxtests/psxhdrs/termios/tcflush.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/tcgetattr.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/tcgetsid.c | 49 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/tcsendbreak.c | 50 ++++++++++++++++++
> .../psxtests/psxhdrs/termios/tcsetattr.c | 51 +++++++++++++++++++
> 12 files changed, 560 insertions(+)
> mode change 100644 => 100755 testsuites/psxtests/Makefile.am
> create mode 100755 testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcdrain.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcflow.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcflush.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcgetsid.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
> create mode 100755 testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> old mode 100644
> new mode 100755
> index 749258cc0c..e7be09a0e9
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1832,6 +1832,17 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
> ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
> ## lib_a_SOURCES += psxhdrs/monetary/strfmon.c
> ## lib_a_SOURCES += psxhdrs/monetary/strfmon_l.c
> +## lib_a_SOURCES += psxhdrs/termios/cfgetispeed.c
> +## lib_a_SOURCES += psxhdrs/termios/cfsetispeed.c
> +## lib_a_SOURCES += psxhdrs/termios/tcdrain.c
> +## lib_a_SOURCES += psxhdrs/termios/tcflush.c
> +## lib_a_SOURCES += psxhdrs/termios/tcgetsid.c
> +## lib_a_SOURCES += psxhdrs/termios/tcsetattr.c
> +## lib_a_SOURCES += psxhdrs/termios/cfgetospeed.c
> +## lib_a_SOURCES += psxhdrs/termios/cfsetospeed.c
> +## lib_a_SOURCES += psxhdrs/termios/tcflow.c
> +## lib_a_SOURCES += psxhdrs/termios/tcgetattr.c
> +## lib_a_SOURCES += psxhdrs/termios/tcsendbreak.c
> ## Specific issues that tickets are tracking
> ## lib_a_SOURCES += psxhdrs/dirent/dirfd.c See ticket #3371
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> new file mode 100755
> index 0000000000..4b2b88bc6d
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief cfgetispeed() API Conformance Test
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019 Jacob Shin
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <termios.h>
> +int test( void );
> +int test( void )
> + struct termios term;
> + speed_t rate;
> + rate = cfgetispeed(&term);
> + (void) rate;
> + return 0;
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> index 0000000000..4c55229645
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief cfgetospeed() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + speed_t rate;
> + rate = cfgetospeed(&term);
> + (void) rate;
> + return 0;
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> index 0000000000..3af199c5e6
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief cfsetispeed() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + speed_t speed = B0;
> + result = cfsetispeed(&term, speed);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> index 0000000000..4f2707ef6e
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief cfsetospeed() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + result = cfsetospeed(&term, speed);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcdrain.c
> b/testsuites/psxtests/psxhdrs/termios/tcdrain.c
> index 0000000000..1de8862f65
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcdrain.c
> @@ -0,0 +1,49 @@
> + * @file
> + * @brief tcdrain() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + result = tcdrain(fildes);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcflow.c
> b/testsuites/psxtests/psxhdrs/termios/tcflow.c
> index 0000000000..5b7d1dab39
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcflow.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief tcflow() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + int action = TCOOFF;
> + result = tcflow(fildes, action);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcflush.c
> b/testsuites/psxtests/psxhdrs/termios/tcflush.c
> index 0000000000..4beccb89d5
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcflush.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief tcflush() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + int queue_selector = TCIFLUSH;
> + result = tcflush(fildes, queue_selector);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> index 0000000000..d00336b214
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief tcgetattr() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + result = tcgetattr(fildes, &term);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcgetsid.c
> b/testsuites/psxtests/psxhdrs/termios/tcgetsid.c
> index 0000000000..8700742166
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcgetsid.c
> @@ -0,0 +1,49 @@
> + * @file
> + * @brief tcgetsid() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + pid_t result;
> + int fildes = 0;
> + result = tcgetsid(fildes);
> + return (int) result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
> b/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
> index 0000000000..7ef4de0b7f
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcsendbreak.c
> @@ -0,0 +1,50 @@
> + * @file
> + * @brief tcsendbreak() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + int duration = 0;
> + result = tcsendbreak(fildes, duration);
> + return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> index 0000000000..e2bd6980a9
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> @@ -0,0 +1,51 @@
> + * @file
> + * @brief tcsetattr() API Conformance Test
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +int test( void );
> +int test( void )
> + int result;
> + int fildes = 0;
> + int optional_actions = 0;
> + result = tcsetattr(fildes, optional_actions, &term);
> + return result;
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190507/f0e1be07/attachment-0001.html>
